Recently I replaced the front suspension (except for the air shocks) on my A8 4.2L 2012.
Everything went well, just had to re-align the steering.
When I got home, I used VCDS to check for errors, and surely the Audi didn't like the geometry change.
Cleared all errors everything was fine.
So, I kept reading and found the steering angle sensor calibration screen on VCDS, and I swear it was by mistake I clicked on "next" and the thing recalibrated.
I immediately got a MIL error on the dashboard (a yellow steering wheel).
I've tried all the steering angle sensor reset procedures. Recalibration, full right lock, full left lock, drive under 20kph for more than 500 m. Everything.
Reset using vcds all the errors. But the steering MIL will not go away.
What else can I try?
The MIL error causes the ESP and Air Suspension to have error messages as well.
Please help!
I had an "active steering error", see below, but that was cleared after I cleared all errors. but the MIL steering remains as well as ESP and active suspension. See errors below.
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 A HW: 4H0 907 144 A
Component: DYNAMIKLENK. H06 0080
Revision: 51001005 Serial number: --------------
Coding: 8B0000
Shop #: WSC 02311 785 00200
VCID: 2616FC1EB8E6C2D7775-8072
3 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 220
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:49
Freeze Frame:
Count: 40
Count: 1
Hex Value: 0x05CD
Hex Value: 0x05D0
Hex Value: 0x1399
Hex Value: 0x8A00
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:49
Freeze Frame:
Count: 56
Count: 1
Hex Value: 0x0089
Hex Value: 0x8C08
Hex Value: 0x0000
Hex Value: 0x3704
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 220
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:50
Freeze Frame:
Count: 47
Count: 52
Hex Value: 0x0289
Hex Value: 0x8C0B
Hex Value: 0x0000
Hex Value: 0x4C00
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008004
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_VW51.rod
VCID: 2C020E36A68AF887A11-8078
2 Faults Found:
0085 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Date: 2000.00.00
Time: 00:00:00
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Date: 2000.00.00
Time: 00:00:00
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 B HW: 4H0 907 379 B
Component: ESP PREMIUM H10 0273
Revision: -------- Serial number: --------------
Coding: 44F6A200226F4500E300
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_005_AU64.rod
VCID: 313C1F4281A8956F927-8064
2 Faults Found:
0188 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 31998 km
Date: 2017.06.30
Time: 18:34:24
VzRef: 00
Bit Info 1: C0
Bit Info 2: 07
Bit Info 3: A2
Bit Info 4: 00
F-Path: 2C
F-Type: 33
Uz: 95
0194 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 31997 km
Date: 2017.06.30
Time: 18:15:50
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: A2
Bit Info 4: 00
F-Path: 2B
F-Type: 16
Uz: AF
