Official VW/Audi TSB'sRelated to Troubleshooting Parasitic/Static Draw & Battery Drain Issues:
These TSB are dependent upon which BEM module (J376) you have installed in your car.
Battery Diagnostic Module (Ground Cable + Module J367)
WARNING: I am still working this all out.
Part #12 is the BDM Cable/Module
BDM ==> Battery Control Module J367 ==> Audi P/N
- Looks like 8K0915181B is for B8 A4
- Looks like 8K0915181C is for A5
- Looks like 8K0915181E is for A4 Hybrid? 7L7/7L1 PR Codes
Step By Step Guide To Troubleshoot Cars With BDM (B8/B8.5 A4 are included):
http://www.esghotwire.com/bulletins/...nosis_tips.pdf
Audi TSB: [27 13 19 2029010/2 October 7, 2013]
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=181853
VW TSB: [27 07 11 October 2, 2007]
https://wiki.bentleypublishers.com/d....tb.pdf?api=v2
Voltage Draw Matrix
Copyright Belongs to Bentley Publishing, referenced in the above documents:
VW/Audi Self Study Programs Related to B8 Networking and Electrical Systems
B8 A4 SSP 409 Service Training Manual:
https://www.pdf-archive.com/2015/03/...ing-manual.pdf
A5 Networking SSP 395 (referenced by A4 SSP):
http://forum.a8parts.co.uk/attachmen...0&d=1430158262
VCDS Related Battery Operations:
Enabling the Battery Meter via Green Menu:
Warning: This has been removed as of B8.5 as the gauge is really inaccurate!
MMI-2G & MMI-3G
http://mr-fix.info/audi-mmi-battery-level-status-2g-3g/
Enabling the Battery Meter via VCDS:
Concerty/Symphony Non-MMI:
- Select STG 56 (Radio)
- STG adjustment -> function 10
- Channel 39
- Increase value by +16
Measure your Battery via VCDS:
19-CAN gateway > Measuring Blocks > Groups 18,19 and 20
and compare to the battery percentage shown by MMI {if equipped}
Thanks to richardm0025 for the pic.
Check your BEM Battery Coding:
19-CAN Gateway _> Long Adaptation -> Channel 4 -> Battery identification
How to Code your new battery with VCDS DIY:
This is where you could re-code for the new battery. Not always required, but it might help to solve this issue.
http://www.audiforums.com/forum/b8-m...2/#post1430403
