This is my 2009 Audi S5 V8 6 speed manual black on black that has a JHM supercharger installed. The car has a 123k Miles on it(rounded up since I am using it as my daily currently) . All Aftermarket items have been added on in the last 5,000 miles. The reason for selling is I am moving on to an Audi R8 and have no room for this toy. I have had all the maintenance done within the last 2000 miles. This would include every single fluid the car has ( tranny, brake, oil, power steering etc.). All of ball joints in the suspension have been redone as well. Ive had the head gasket seals done, spark plugs, coils done. The car is ready to go with title in hand. I have made sure every aspect of this car was running perfectly before aftermarket items were installed.
Aftermarket parts are:
1 x JHM Supercharger Kit for B8-S5 w/ 4.2L FSI V8, Stage 1
- JHM 6-Rib Kit: Yes, I already have this kit - provide us inv #
- Country: USA - Canada
- Year: 2009 Metal Manifold
- JHM Tuned: Yes, Previously tuned - provide us inv #
- _Flashing Method: Flash Myself, Cable Purchase Required
- Transmission Type: Manual $7,345.00
1 x Motor Mount Pair, Street Density Line (034Motorsport) for B8 S5-RS5 4.2L FSI V8 $369.95
1 x Transmission Mount Upgrade, Street Density (034Motorsport) for B8 A4-S4-RS4 A5-S5-RS5 Q5-SQ5 $25.00
1 x Transmission Mount Insert, Billet Aluminum (034Motorsport) for B8 A4-S4-RS4 A5-S5-RS5 $75.00
1 x Sway Bar End Link Pair, Front, Motorsport Line, Adjustable (034Motorsport) for B8 A4-S4 A5-S5-RS5 Q5-SQ5, C7 A6-S6 $155.00
1 x Sway Bar End Link Pair, Rear, Motorsport Line, Adjustable (034Motorsport) for B8 A4-S4 A5-S5-RS5 Q5-SQ5, C7 A6-S6-A7, D4 A8-S8 $175.00
1 x Sway Bar, Rear (034Motorsport) Solid, Adjustable for B8-B8.5 A4-S4-RS4, A5-S5-RS5 $245.00
1 x Brake Line Kit-Stainless (JHM) Front and Rear Lines for B8 S4-S5 $99.95
1 x Exhaust - Cat-Pipes - Stainless Steel, 2.5" (JHM) for B8-S5 4.2L FSI (32v) $895.00
1 x MAF Hose (034Motorsport) High-Flow, Silicone Throttle Body Inlet Hose for B8-S5 w/ 4.2L FSI V8 $99.75
JHM sales team collected, see comments.
Parts : $9,484.65
Subtotal : $9,484.65
Courtesy Shipping Discount : $-218.21
Courtesy Parts Discount : High Flow Cat Pipes $-181.68
FedEx (Total items: 2 pcs. Total weight: 165.60 lbs.) (Fedex Ground (5 days)): $218.21
Total : $9,302.97
Products
1 x JHM R Series Lightweight Flywheel and Clutch Combo for B8-S5 w/ 4.2L FSI V8
- Throwout Bearing VIN Split: Late, From VIN 8T-8-032-001
- Clutch Disc Material: Stage 3 R (Ceramic / Metal Backed Organic) $2,745.00
Parts : $2,745.00
Subtotal : $2,745.00
Shipping Discount : $-100.00
FedEx (Total items: 1 pcs. Total weight: 48.00 lbs.) (Priority Overnight): $230.28
Total : $2,875.28
JHM Items totel $14,500.00
Also Items I have added
AWE Touring full exhaust $1995.95
Reiger Carbon Fiber Rear Diffuser $400.00
Labor: $10,000.00
All work was done by S2 Dynamics in Rockville MD which is rated the best Audi repair shop in MD area.
Aftermarket 20" RS5 rims and tires $1500.00 (stock rims will be included in sale)
Full Halo EFX True Gloss Paint Job obsidian black including door jambs $2000.00
Paint was done by Rouge Enterprise a company that owner of Halo recommended to me. (best in Maryland)
I have spent nearly 30g in total to make this car a daily driver for myself that runs with no issues. If you have any questions don't hesitate to contact me. I will not let anyone test drive the car unless i see proof of funds first. This has 450+ at the wheels! 500+ at crank. This is AWD HP!!
I am asking for $22,900.00
