PWY24W Front Turn Signals Error Free - Available in White or Amber fits: Audi A3 ? deAutoKey
New LED Footwells for Audi models that are equipped with OEM LED Footwells ? deAutoKey
These LED's work as puddle lights or footwell lights.
194 10pc CREE LED Reverse LED Fits:Audi A3/S3/RS3 + Many More ? deAutoKey
Reverse Lights
Pry off this trim piece towards the rear of the car, there are little alignment tabs that go straight back. There are also two little tabs that hook onto the actual tail light.
Remove the two Torx screws pictured. Make sure they don’t fall down behind the bumper, because that would be a pain in the ass to retrieve them.
Pull the tail light housing straight out.
The reverse light bulb is the top one in the picture. Twist it until it comes loose and pulls out, then replace the stock bulb with the new LED.
Reverse the steps to reinstall.
Puddle lights
Pry the housings from the edge pointing towards the front of the car until it pops out.
Unplug it from the wiring.
There are two clips holding the black part of the housing to the clear diffuser. Use a small flathead to pry it upwards until it comes apart.
I have no pictures of me swapping out the stock bulb, but it is pretty self explanatory when you see it. Not difficult at all.
With these LED’s, I had to bend the pins down about 20-30 degrees until they would insert into the OEM wiring. This wasn’t very difficult but it did take me a couple tries to get it right
Also worth noting, due to the little black piece of plastic holding the pins together, the OEM black housing would only snap into the one clip on the other side of the pins. Honestly, you could probably just get rid of the OEM black housings, but I left them in there.
This is with the new LED’s installed
Snap them back into place, then repeat with the other 3 doors.
Front Turn Signals
Remove the two push pins that hold in the black trim piece right above the grille, and pull out the trim piece.
Remove the rubber bushing that I am pointing to on both headlights.
For the pass side I had to remove the airbox to gain access. Use torx bits to remove the two screws on the right side of the air inlet, and one screw on the left side of the inlet. THIS STEP IS NOT NEEDED ON THE DRIVER SIDE. After removing the screws, the airbox can be pulled up and out. You also have to loosen the air inlet clamp and pull the inlet tube out of your way.
(Right side of air inlet)
Left side
This is the hardest part due to limited work space. You have to jam your had inside the little hole and twist the bulb socket clockwise until it pops loose, then the bulb can be removed.
Install the new LED, and reverse the steps to reinstall/put everything back together.
