Results 1 to 19 of 19
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    Creaking from the driver side front wheel when turning
    Started noticing some pretty loud creaking sounds today coming from the driver side front wheel area. Only notice it when turning (both directions), no noise when driving straight. I'm suspecting a wheel bearing or control arm issue but no chance to look right now or in the next few days. Would love to hear completely wild guesses on what else it could potentially be. :-)
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Quote Originally Posted by phillyquattro View Post
    Wheel bearings from my experience don't creak. Wheel bearing noise will usually get louder turning a specific direction and it is a rotational/cyclical sound. Hard to explain. Steering racks, tie rods, control arms, end links do creak. But that is just stab at it without hearing it.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    San Francisco, CA
    Quote Originally Posted by Baggio View Post
    Thanks for the ideas. My phone decided to brick itself tonight so I haven't been able to record the sound either (or do other more useful things). It's been a solid day for things going wrong. Whatever it ends up being I look forward to Audi fighting me on replacing it under warranty since I'm on coilovers.
    2019 GT3 Touring
    IG: brandongray
    Established Member Two Rings ekpyr's Avatar
    Jul 16 2007
    Long Beach, CA
    Does it happen when you're steering while stationary?
    Apr 11 2012
    Coil bind? loose endlink or control arm? does the correct guess get a prize?
    San Francisco, CA
    Quote Originally Posted by ekpyr View Post
    Yes. While stationary and at low speeds. Backing out of spots, driving through a parking lot, parallel parking, etc. I don't notice it at speed.
    Quote Originally Posted by will13k7 View Post
    You win a free digital high five!
    2019 GT3 Touring
    IG: brandongray
    Jul 16 2007
    Long Beach, CA
    Wheel bearing mount needs grease between mounting surface.
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    Most likely the strut bearing. Unfortunately we've seen a lot of them going bad before the 20,000 mile mark.
    Apr 11 2012
    ^^ never knew those were a weak spot, these any good?
    https://www.ecstuning.com/Audi-8V_S3...rut/ES3111704/
    Feb 11 2014
    Anaheim, CA
    From what we've seen so far, the bushing is not an issue (as the rubber will take years to wear out). It is the bearing which becomes a problem, manifesting itself through creaking and popping noises when you turn the wheel.
    May 24 2016
    Would this be a warranty fix?
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    Are you lowered? I'm at 30k miles and just replaced my top mount with the ECS ones and it got rid of my creaking noise. I'm lowered on Ohlins R&T which bring their own bearing.
    B8.5 3.0T/ B5.5 1.8T
    Sep 14 2006
    Phillyquattro, swaggerwagon posted in this thread. Sounds like the same issue? http://www.audizine.com/forum/showth...ts-Strut-Mount
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    I'm in the strut bearing camp as being your issue.
    2016 Monsoon S3
    My slow build link - Onequick4door
    San Francisco, CA
    Quote Originally Posted by swaggerwagon View Post
    Yes, I'm lowered on Bilstein B14s and it definitely sounds like the same issue SwaggerWagon talks about in that post. I've got an appointment at 034 on Friday morning so I'll see what they say. Those ECS HD strut mounts might be in my future...though based on the ECS product page it looks like the use the OEM strut bearing and the mount is what is different and made by ECS. Incoming possibly dumb question: If what EmmanueleDesign says above is true about the bearing being the issue, is there really any point to replacing anything other than just the bearing?
    2019 GT3 Touring
    IG: brandongray
    Sep 28 2012
    NC
    I don't know about the bearings. Like I mentioned, the Ohlins Road and Track come with their own set of bearings so the strut mount was the culprit in my case.
    San Francisco, CA
    Strut bearing was the culprit. Ordered the heavy duty kit from ECS and hoping to install it next week. Picked up the turbo blanket as well to give that a shot...cause why not?
    2019 GT3 Touring
    IG: brandongray
    Senior Member Two Rings soulflyer's Avatar
    Apr 06 2015
    Ottawa, Canada
    have you looked into those?
    https://www.gmpperformance.com/index...ID=409332&VS=1
    2018 S3 Technik, Ara blue
    SOLD 2015 S3 Technik, Sepang blue
    I have VCDS, will do scans and coding for beer in the Ottawa ON, area. PM me.
    San Francisco, CA
    Quote Originally Posted by soulflyer View Post
    They're on the list for the future, but just wasn't interested in spending that much yesterday. Too many other expenses lately. Maybe after I've installed my BBK next weekend and sold the stock brakes and sold my old Rotiforms.
    2019 GT3 Touring
    IG: brandongray
