Results 1 to 16 of 16
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    Parts needed for b8 -> b8.5
    So anyone know what parts is needed for the upgrade? Ofcourse i know the obvious parts as hood, fenders, lights bumper etc. I belive a kufatec cable is needed?
    I spoke to some guy from england that did this but he rememberd pretty much the obvious stuff.
    Established Member Two Rings Cameron_'s Avatar
    Sep 08 2015
    2007 BMW 530i
    I don't know OP, might be better off just getting the 8.5 lol.
    May 04 2014
    Sweden
    Since i can probably get all parts for free and its more fun to have a project i rather go that way :)
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    That guy in the UK (I assume it's the same guy) had a build thread here and detailed it pretty well. Unfortunately I can't remember his username to look it up.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Dec 01 2015
    Finland
    Hi, I have done this swap for the front end. Worth it imo if you like your current car and you are planning on keeping it.
    My car is my2008 and had/has bi-xenon headlights.
    Parts I needed:
    - 8K0823029H Bonnet
    - 8K0821105J + 8K0821106J +8K0853823 + 8K0853824 Front wings and rock protector trims
    - 8K0821135H + 8K0821136J + 8K0807283H + 8K0807284H Front wing supports and plastic mounting pieces to the end of the support brackets
    - 8K0805607B + 8K0805608B + 8T0941453D + 8T0941454D Headlight support pieces (2pcs for each light)
    - 2pcs 8K0807333B Headlight support mounting pieces
    - Bumber with grilles and fog lights. Many part numbers depending on version.
    - 8K0807647A Grill for "splitter"
    - 8K0941043B & 8K0941044B Xenon headlights without curve-light function. If swapped from xenon to xenon it is really easy. One change with vcds, the rest is plug'n'play. I would assume that halogen to halogen is an easy swap too.
    - 8K0807081B & 8K0807611B Plastic parts for under & top of the bumber (between bumper and radiator)
    - 8K0821171L + 8K0821172L Inner fenders... Doesnt really need to be changed, there is only one mounting hole in the wrong place. I did not change them, but for 100% correct facelift retrofit you will need them too.
    What you would think that has to be changed but are actually the same parts on post-facelift and facelift models.. So these you do not need:
    - Headlight washers
    - Impact bar and supports
    - Any parts that are mounted to bonnet, all are the same exept for the bonnet itself
    Established Member Two Rings mrw's Avatar
    Aug 20 2008
    RS5 Cab sold, 2009 A4 Avant 3.0 6mt swap-sold, 2021 Jeep 392, 77 Datsun 280Z V8 2017 S6-sold
    Delaware
    earaa Did you have to change any plugs or pins for the head and fog lights?
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by Project Quattro View Post
    Is this the thread?
    http://www.audi-sport.net/xf/threads...-heavy.239262/
    Stumbled upon it today and had it bookmarked. Would love to do this down the line! Probably makes the most sense to find a wrecked car with all the parts that are needed.
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Dec 01 2015
    Finland
    mrw: Headlights are plug and play + vcds.
    If you currently have adaptive xenon curve lights the facelift retrofit is not possible.
    Aug 20 2008
    Delaware
    enraa: I have done the swap now but I am getting a fault for the side marker lights. I have not done the vcds coding. Can you share what the coding is? Thanks[IMG][/IMG]
    Mar 14 2005
    Norway
    Hi guys. I have done the 8 to 8.5 on my 2011 Allroad, and have the exact same problems as other people who have done the conversion : When the main beam turns on, the DRL turns off.
    Anyone wants to share the coding?
    Established Member Two Rings MMiklosz's Avatar
    Mar 27 2014
    Berlin, CT USA
    I shared coding on my post if you are still needing the lights to work correctly
    Junior Member Two Rings
    Oct 02 2012
    Nottingham, UK
    Quote Originally Posted by enraa View Post
    Parts I needed:
    - 8K0823029H Bonnet
    - Headlight washers
    I know that this is from a looong time ago but does the radiator support frame/slam panel need to be changed as well?
    many thanks
    Simon
    Jul 16 2018
    Atlanta
    I assume you mean the lock carrier. Appears there was a separate one for A4 vs S4 up till Jun 6, 2011 (rev J vs rev K), then they all used the same rev L, which is also what the B8.5 used (except the 2.0 TDI starting Sept 30, 2013 started using a rev N). So if you have an L, then it's the same as what the refresh vehicles used. What actually changed between J and L, and is J equally compatible with B8.5? No idea. Feel free to explore:
    https://audi.7zap.com/en/rdw/audi+a4.../8/805-805000/
    Junior Member One Ring
    Jun 20 2013
    ontario
    Coding
    Quote Originally Posted by MMiklosz View Post
    Hi sorry to bother you I was trying to find some coding for headlight and taillights
    Not sure if your able to help me
    Thanks
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by SWALAY View Post
    Thanks
    his post was half a decade ago, may be better emailing or DMing him.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 28 2019
    Washington State
    Quote Originally Posted by mrw View Post
    Were you ever able to figure out the side marker light issues? I did the front end swap, coded the headlight Via VagCom and the side marker lights are the only thing not working.
