I went with a FEBI kit from ECS, in general I have had good results.... So I stuck with what has worked in the past.
Also, it appears that even though my 2003 has sport suspension, it has the standard bushings (I always wondered if they used the S4 bushing in the A4's with sport suspension, unless mine were replaced, the answer is no). This should be an upgrade for handling. I realize there are other options that are stiffer, I went this route because I still want some compliance. Also, I was very happy to see a Febi Germany stamp on all the uppers. I will report back on the lowers...
https://www.ecstuning.com/Audi-B6_S4...ngs/ES2635828/
When I go to press the bushing, I don't risk want to messing up my nice new uppers, so I machined up a set of bushing press tools to make the exchange a bit smoother.
Stock A4 Bushing Center:
B6 S4 V8 Bushing:
Close up of the new upper arms:
Hopefully, I will be able to get the new parts installed next weekend.
