Results 1 to 7 of 7
    Mar 01 2011
    Nanuet NY
    Resurfaced my own flywheel
    For my B7 A4.....
    You can see the progress. Very easy to do and cheap. You can use the same the tool for the rotors as well. The one pictured is the one i bought. The come in 3 different styles; fine, medium, and course. The one I bought is medium.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    What did you mount the plate to so that it could be turned at a specific speed while you honed the surface?
    Stage 2 Banner Advertiser Four Rings Kai@EliteMS's Avatar
    Mar 22 2011
    Lindenhurst NY - Long Island
    Unless you made an apparatus to have it at a set height & speed, I wouldn't trust it being level.
    ELITE MOTORSPORTS
    21 W. SUNRISE HIGHWAY LINDENHURST NY 11757
    www.elitemotorsport.net - www.elitemotorgroupny.com
    P: 631.775.6634
    Follow Us On Facebook
    Follow Us On Instagram #elitemotorsports
    Follow Us On Twitter
    Mar 24 2013
    Oakdale, CT
    The flywheel didn't look to be in terrible shape to start with and all a hone is going to do is deglaze the surface. It won't remove much material. I'm sure it's fine for a stock car.
    -Adam
    Jun 17 2013
    jersey city nj
    If you didnt have clutch chatter before. Very much doubt it will chatter now. All that hone did was any contaminants that was on the surface. Just like using it on brake rotors
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    All in all looks like a job well done.
    Mar 01 2011
    Nanuet NY
    this was just to polish the surface for the clutch and PP. It wasn't chattering before so no need to cut into the rotor. You can also use the same tool on rotors. Gives it a nice clean surface.
