Results 1 to 3 of 3
    Jun 26 2009
    Bremerton WA
    Has anyone verified/changed their camshaft bridge?
    I have an 09 that had the engine replaced at 30K miles with the previous owner. This should have been late enough to pick up the camshaft bridge revision but it can't be verified with service records.I plan to remove the upper timing chain cover and look for the correct part number. If anyone has done this task do you have any tips. Does anyone know if the part number is on the timing chain side or as I suspect under the valve cover?
    Edit- I found better pictures and the valve cover stays on and upper timing chain cover is removed.
    VMR 710's, APR software, Eurocode HFC
    Senior Member Two Rings A4BGP's Avatar
    Oct 18 2005
    Dirt and Street bikes, '09 A4Q
    Moncton, NB
    Sure it can be verified. It was put out as a required update rather than a recall from what I understand. This was done under RVU #15D6, ask your dealer that specific question.
    Part number is 06H103144J but the screen(06H103081E) and check valve 06H103176G(11mm) or 06H103176F (12mm) can be ordered separately.
    Jun 26 2009
    Bremerton WA
    I had them check records once before. The service advisor mentioned the motor replacement at 30k miles. They didn't mention if it was a long or short block. It's possible it may have my original head with the newer block. I figure a $20 tube of sealant and a few hours of time may save a camshaft and some metal flake.
