Results 1 to 32 of 32
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    New MagnaFlow cat back system for 2015 A4 Allroad 2.0T
    We're super excited to announce our new system for the 2015 A4 Allroad 2.0T. It is a fully stainless system consisting of 2.5" piping, 4"x9"x14" mufflers, and dual 4" tips. Like all our stainless exhaust systems, this system has been dyno tested to make power and is backed by our lifetime warranty. It's been designed for a factory-like fit and because its part of our TOURING line of exhausts, it will perfectly suit the character of your Allroad without being too loud or droning on the freeway!
    MagnaFlow TOURING Cat-Back Exhaust for 2015 A4 Allroad 2.0T
    Mar 28 2009
    Minneapolis, MN
    Any video clips where we might be able to hear this exhaust?
    Established Member Two Rings s4Leistung's Avatar
    Mar 22 2015
    2015 S4 Prestige, 2012 Range Rover Sport, 1967 VW Beetle 2332cc
    Orange County
    @ Dropshadow - here is a little clip to hold you over. I personally have heard this system and it sounds amazing on Duan's All-Road as pictured in the Magnaflow AD.
    https://instagram.com/p/yfc4qxpM2A/?taken-by=daohaus
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by s4Leistung View Post
    Thanks! I actually ordered it a couple days ago and it's already here. Just waiting on a couple more parts to arrive before it gets installed.
    Active Member Two Rings JFR's Avatar
    Sep 16 2006
    Norfolk County, MA
    Need exterior video clip STAT!
    -JR
    2015 Allroad
    Sep 16 2006
    Norfolk County, MA
    Bump!!! Where are the sound clips?!?!?
    -JR
    2015 Allroad
    Mar 28 2009
    Minneapolis, MN
    Bumping this to say that I love the sound and the look of the Magnaflow exhaust on my allroad. Highly recommended for any allroad owner.
    Sep 16 2006
    Norfolk County, MA
    Sound clips please?!?!
    -JR
    2015 Allroad
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by JFR View Post
    -JR
    Youtube won't do exhaust clips justice. It's a nice mellow sound at idle, and it makes a lovely noise at full throttle. Sounds very nice outside, and the interior volume is easily controlled by the throttle. I am very pleased with it.
    Jan 26 2015
    Oceanside, CA
    We're ecstatic to read that you love it. Those tips looks pretty awesome protruding from the valence that way, I have to say.
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    Does this exhaust remove the second resonator from the system? looks like there is only the pair of rear mufflers.
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by KFizz View Post
    If you mean the resonator connected to the downpipe, no. The Magnaflow connects to the stock downpipe.
    Dec 27 2009
    Edmonton/Alberta
    No, I meant the one after the downpipe. The factory has another resonator after the downpipe, the Magnaflow system does not seem to have this, it's straight piped until the rear mufflers.
    Kyle
    Aug 12 2015
    2012 Ducati Monster 1100 Evo (red)
    Tampa, FL
    I just put this on my Allroad last night and the very front pipe that connects to the OEM exhaust is straight resting on that small metal structural bracing that runs from the driver to passenger side. I can hear it clunking on it when I drive. Any thoughts?
    Jan 26 2015
    Oceanside, CA
    Quote Originally Posted by Mwhit02 View Post
    Give us a call tomorrow: 1.800.990.0905 or 1.949.858.5900.
    Aug 12 2015
    Tampa, FL
    So I got under the car again and just don't see what I need to adjust to raise the front of this exhaust pipe off the brace. Everything is tight, hangers are pretty much level on both sides. At this point I'm about to just remove the brace. Everytime I call Magnaflow I'm immediately put on hold forever.
    This is looking from the back of the car towards the front..car is jacked up on right side.
    Jan 26 2015
    OC
    I believe this is the same brace I had a challenge with on my AR, just space the brace down and away from the exhaust by using washers between the brace and the chassis. Worked like a champ on my car...
    Aug 12 2015
    Tampa, FL
    so after spending 6+ hours trying to adjust this exhaust and following the tips that Mark Miller from Magnaflow gave me, this exhaust is still fitting like complete $hit. Not only is the exhaust resting on top of the support brace, but the tips are not centered at the bumper (one is perfect, the other is making contact with the top of the bumper and off to one side. I tried explaining to Magnaflow that this exhaust needs to be basically redesigned slightly, as even J_Sims had to use washers to not have the exhaust sit op top of the brace. Magnaflow told me they would not accept this defective exhaust back, as it was MY FAULT it was not fitting properly. THANKS MAGNAFLOW, WAY TO STEP UP!!!
    Aug 12 2015
    Tampa, FL
    as a consequence, I placed a stop payment on my credit card and have already received the funds back to my bank account and notified the better business bureau about what went on. I will follow up with any updates as they become available. I would suggest holding off on purchasing this exhaust or even considering buying a different option until Magnaflow fixes their problems and fixes their customer service.
    Oct 13 2014
    Minneapolis, MN
    I ended up spacing the bracket down with spacers and also used a hose clamp to cinch up the passenger side exhaust hanger.
    I will say 2 things about this exhaust.
    1. The driver's side muffler/tip doesn't appear to center. I happened to have access to 2 sets of these exhausts when I was trying to install mine, so we tried both driver's side mufflers and both hanger brackets are bent just slightly incorrectly so that the tips won't center properly within the exhaust tip opening. I think you'd have to bend the hangar bracket slightly to make it fit perfectly. I used washers on the hangar connection to the car, this helped slightly.
    2. My exhaust drones. I seriously am considering going back to the stock exhaust. I've had loud avants before and I just can't stand the drone, especially now that I just want a nice quiet daily driver. I've considered adding resonators as I really like the look of the exhaust, I wish this was an option from MF. And truth be told there are times when the exhaust is almost stock like quiet while cruising, but other times it rattles the windows in my house and my GF says she can hear me 2 blocks away.
    Jan 26 2015
    Oceanside, CA
    Quote Originally Posted by moonshiner View Post
    Moonshiner, to get the tip positioning perfect, loosen the clamps and try twisting the muffler section and Y pipe slightly. Another tip for installation is to not completely bottom out the slip joints, as this can cause them to not align properly. You want them to sit with some slack in the connection. You can then retighten the clamps, starting at the front of the car and working backwards to the rear muffler.
    You may notice the tone to be a little more bassy than usual in the first 500-1000 miles before the muffler packing material becomes worn in, but normally you should not experience drone like you are describing, unless you have other aftermarket exhaust components like a downpipe, etc. Members Dropshadown, Allroadcorbin and a few others here on the forum run this system, and we have not heard anyone report issues of this sort. They may be able to provide some
    If the tip is not able to be aligned after performing those steps, please give us a call at 1-800-990-0905 so we can further assist you.
    Veteran Member Four Rings AUDacIouS4's Avatar
    Mar 11 2016
    981 Cayman GTS/ 2018 Ford F150 FX4 2.7
    Orange County CA
    I just installed this cat back on my 15 and have the exact same problems. Center pipe resting on the cross brace and tips won't line up. I shouldn't have to redneck engineer anything to make this system work if it was designed correctly. Can someone please explain this bizarre thermal expansion going on here.
    Cold exhaust:
    Hot exhaust:
    Uhhhh.......
    slave of corruption
    Senior Member Two Rings LmG7119's Avatar
    Jun 03 2014
    MNN
    Sorry to bring this out the dead but I got this exhaust install and I have a little annoying drone cruising at 1800-2000 rpm on hwy. Everything below and above sounds ok. Also, in the morning on a cold start, the sound inside the car has so deep noise that it hurts my ear but it sounds fine outside. Is this normal?
    2013 Allroad Premium Plus UM stage 1
    2003 Allroad EPL Stage1+ straight downpipes catless(sold at 187K miles)
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by lepa71 View Post
    Sounds just like mine.
    Jun 03 2014
    MNN
    @dropshadow
    Do you have a stock downpipe? Have you tried anything for the cold start deep tone? Thanks
    Mar 28 2009
    Minneapolis, MN
    @dropshadow
    Yes, stock DP. I had an AWE dp briefly in my black allroad with the Magnaflow exhaust but got rid of it because it droned terribly. Went back to the stock dp.
    The tone you mention on cold start goes away after a couple minutes. Not sure if there's anything that can be done. I don't notice it anymore unless a passenger mentions it.
    Jun 03 2014
    MNN
    What about drone when cruising at 1800-2000 rpm on hwy? This happens when I'm on 494 going around 65 mph(1800-2000 rpm). Just slight tap on the gas gives this light drone noise.
    Mar 28 2009
    Minneapolis, MN
    Can't say I've got the same drone at those speeds. Or maybe I just don't notice since I've usually got music playing. The exhaust is definitely noticeable while driving, but I wouldn't call what I hear a drone.
    Veteran Member Four Rings digdah's Avatar
    Dec 11 2017
    DFW
    It always mystifies me that people change their exhaust system, particularly the down pipes, and are surprised there is a drone at certain RPMs. You just have to manage the manipulation of the RPMs with to your right foot and accept that it will be louder at times. If there was a drone throughout the RPM range I would under stand the concern.
    Jun 03 2014
    MNN
    Quote Originally Posted by digdah View Post
    If you are referring to me then I have a stock downpipe. I was asking those questions because I have nothing to compare to. I'm not bashing Magnaflow but just asking others who had Magnaflow catbacks installed.
    Aug 30 2018
    Washington D.C.
    What’s the rims and tires you running? (Size and Brand)
    Looks super sweet.
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by Ikobzei View Post
    Looks super sweet.
    BBS CH-R
    20x10.5 et25
    Michelin Pilot Super Sports
    255/35/20
