Page 1 of 18 12311 ... LastLast
Results 1 to 40 of 709
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW!! B8 S4 ECS Kohlefaser Luft-Technik Intake System
    Crafted from hand-laid carbon fiber and utilizing a fiberglass interior layer, the Audi B8 S4 Kohlefaser Luft-Technik Intake sets a new benchmark in appearance and durability - all while resisting the performance-robbing effects of engine heat soak.
    ECS has subjected this system to rigorous real-world testing, including power-gain measurements on our in-house chassis dynometer.
    The convergence of unrivaled beauty, perfected fitment, industry-standard quality, and evidence-based performance claims has resulted in a gorgeous power-enhancer beyond anything available for your 3.0T.
    The New Benchmark
    Fits:
    Audi B8 S4 (2010+)
    Be sure to check out our -----> Installation PDF <-----
    Jason
    Jun 30 2014
    2013 B8.5 S4 Prestige
    Auburn, MA
    How does this differ from the APR Carbonio system?
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by MiniMort View Post
    It differs in a couple ways..
    • First, our intake includes the Carbon Fiber back pipe, which eliminates the baffles and mufflers in the OEM piece meant to silence the supercharger.
    • Second, the filter we use, is our in house designed 3" conical hi-flow reusable unit that features a built in bell mouth inlet which provides the smoothest entry into the throttle body as possible.
    • Third, our intake replaces the entire lower intake box, with an Aluminum powder coated piece which has a twin layer heat shield and utilizes the factory rubber mounting grommets
    More information can be found by clicking the product links.
    Jason
    Senior Member Two Rings SpfldS4's Avatar
    Mar 04 2004
    2005.5 Audi S4
    Wilbraham, MA
    Haha...looks like APR needed more than an authentic Carbonio sticker to protect it's design. Oh well, more products for consumers to choose. Now it boils down to metrics and quality.
    2010 Audi S4 S-tronic Prestige Sepang Blue | Sport Diff w/ ADS | GMG Sway Bar Kit | KW H.A.S Coilover | APR Stage 2+ w/ coolant system | 19" OEM RS4 Wheels | RS5 BBK | NAV | Black Nappa | Piano Black Trim | Black Optic | B&O | Advanced Key | 35% Tint | 3M Clear Bra | Audi exclusive
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    It's actually quite a bit different than the APR (at first look it looks similar). The ECS gets rid of the entire stock airbox, and uses a combination of an aluminum heat shield and CF top plate in conjunction with a larger filter. APR reuses the bottom half of the stock airbox, so the filter is similar in size to stock. ECS also has a full provision for the breather assembly, and it looks like better quality materials. The CF intake tube on the APR system is paper thin.
    The picture above doesn't do the system justice. Look at the pics on the ECS site or the install instructions to get the full picture. Having installed the APR and CTS systems on my car, I can assure you this is the most "engineered" system available; although I can't comment on performance without testing it firsthand.
    Edit: I can add that from a performance standpoint, an intake with an open filter that gets rid of the stock airbox, and uses a heatshield, typically performs the best (both in terms of logging and 1/4 mile times). This ticks those boxes, and adds what appears to be a larger filter and CF top cover.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Oct 20 2008
    Denver
    this thing looks amazing! damn it!
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by jran76 View Post
    Thanks for the feed back! We really did spend countless hours designing this so it hits all aspects when it comes to fit, finish, cost, and notable gains with supporting mods.
    Quote Originally Posted by AudiTFSI3o3 View Post
    It really is a thing of beauty. Show car quality for sure!
    Jason
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Well, damn.... I went ahead and ordered one to test it out. This will be the 4th intake I have tested, so I'll report back with how it stacks up. I won't be going to the track until late May, so probably won't have a full report outside of quality, sound, and logging results until then. In theory, this meets all the criteria I am looking for, but we'll see what the results say....
    Jul 21 2014
    United States
    Looks really well done! Congrats on a nice product! Any dynos on a stock or stage 1 car?
    Deactivated Two Rings
    Apr 22 2014
    Woodbridge, VA
    I want this so hard. I also want the $500 to stay in my bank. Dammit.
    Established Member Two Rings kkS4's Avatar
    Mar 30 2015
    Rochester, MI
    looks sharp..
    Apr 04 2012
    MSP
    Very nice looking system!
    Oct 19 2014
    PA
    Wow that looks nice. I presume the +16whp dyno was done on a Stage 1 car [edit or was it Stage 2?] Look forward to your review jran76.
    Veteran Member Four Rings mojangles69's Avatar
    Jun 03 2013
    2022 BMW X3 M Comp / 2017 Porsche 911 S / 2008 Audi A6 3.2 Wagon / Magic Carpet / Camel / Donkey
    Charlotte / North Carolina
    Dang, jran! HAHAHAHAHA! That was quick!
    Lol, you need to be like an Audizine sponsored tester or tester for our sponsors on the site. With all your tests, data logs and knowledge, someone needs to be compensating you!
    2017 RS7 Performance - Sepang Blue - Performance Design Selection Package w/ Mercato Blue stitching and blue twill in interior carbon fiber components - APR Stage 2 w/ Militek downpipes and exhaust - Aquamist Methanol Kit - Custom Roc-Euro Intake - KW Adjustable coilover springs - K40 Radar/Laser System
    XPEL Ultimate, Ceramic Pro & Apex Huper Optik window tint
    IG
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    I have to say I was impressed with the price. I thought it was going to cost way more. Great looking intake.
    Any possibility of an introductory price?
    2016 S6
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by AZT View Post
    According to their site, it looks like it was on a stage 2 car.
    Oct 02 2006
    Wadsworth,OH
    Thanks for the order! Excited to hear your findings!
    Highest gains were recorded on a Stage 2 vehicle. I'm pretty sure we have documentation of what a Stage 1 vehicle will do with this intake, I'm just waiting for R&D to get back to me with the info.
    Thanks for all the words!
    I'll post Stage 1 data as soon as I have it.
    *Edit*
    Stock gains with ECS intake
    Stage 1 Tune gains with ECS intake
    Jason
    Established Member Two Rings nickskeeta's Avatar
    Nov 30 2014
    Hollister, Ca
    Sounds good, I wonder how it compares to roceuro In terms of how loud the whine is
    @nickskeeta
    2011 S4 6MT Meteor Gray Pearl
    2018 Silverado 6.2 LTZ
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Ordered!
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by aaronz View Post
    Ordered!
    Jason
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by nickskeeta View Post
    My guess is slightly less just based on the fact it has a cover over the top. The bottom is still open, so it will be louder than anything using the stock airbox. On a scale of 1-10.... Stock is a 1, APR/AWE is a 3, and Roc-Euro/CTS/USP is a 9. My guess is this will fall in the 6-7 range, but I'll verify once I get it installed.
    Dec 04 2014
    WOW that’s a thing of beauty, ECS is always pushing their boundaries. Great work! Keep it up
    Established Member Two Rings <3S4PLAY's Avatar
    Mar 24 2015
    Bay Area
    bravo ECS! looks like a beautiful intake setup. Wish i waited a bit longer before I ordered my CTS intake
    Senior Member Two Rings UberBrute's Avatar
    Jan 05 2014
    E91 BMW 328xi 6MT
    Connecticut
    Originally I was just going to go with a eurocode trufit hose and an afe dry filter, but this looks pretty good... decisions decisions
    SOLD 2013 Audi S4 | 6MT | Estoril Blue Crystal | Premium Plus | MMI Nav Plus | Sports Differential | Carbon Atlas Inlays | Alcantara inserts | 19" Peelers |
    Sep 29 2010
    Portland, Oregon
    What a beautiful piece. Now the debate of selling my current intake for this one, haha!
    Who wants to buy my CTS intake?
    Senior Member Three Rings boseephuss's Avatar
    Dec 02 2013
    2000 Dodge Durango (5.9L), 2012 Volvo XC60 T6 (Polestar), 2009 Kawasaki Vulcan 900 SE, Jet Boat
    Houston, TX
    Looks awesome. The rubber hose still looks to be in a a bit of contact with the intake tube (similar to the issue I have with my Roc Euro, regardless of maneuvering done under hood.) Can you speak to this and whether it will create a heat wear problem over time? Thanks!
    2011 Premium +, Meteor Gray Pearl Effect, DSG, Roc Euro, Borla, Eurocode ÜSS, Eurocde Alu Kreuz, Alpha Boost Cooling System, EPL Stage II, EPL TCU Tune
    May 01 2012
    Awesome, good job ECS!
    Veteran Member Four Rings svander's Avatar
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    Interested to see how the carbon fiber holds up to the massive amounts of heat in the engine bay over time. My carbonio/APR piece has yellowed a lot over the last couple of years.
    Established Member Two Rings WeeKenny's Avatar
    Jan 05 2015
    Scotland
    Looks great very well thought out. If I didn't have the stage 2 APR setup I'd get this.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by boseephuss View Post
    We looked into replacing this hose with a new unit, however to simplify the install and to make it more user friendly we opted to retain the factory fuel hose. As some customers are hesitant to touch fuel related components and it increases the difficulty of install, we opted to design the intake to work around this factory component. We have been running this intake for several months on several vehicles at this point as part of the R&D process and have not had any issues with the hose damaging the intake tube.
    Appreciate all the feed back!
    Jason
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    Quote Originally Posted by svander View Post
    +1
    Mar 07 2010
    SW Florida
    Any chance you will offer a fiberglass painted version for those that are more go and less show? Looks amazing in CF but rather spend that money on something I will look at more often.
    Aug 31 2011
    17 Q7 Prem+ (SOLD) 21 BMW X7 M50i
    Blue Bell, PA
    I would get this if this is little bit quieter than roc euro.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by tgsweat View Post
    +1
    One of our goals with every project of this nature is heat management, as can be seen by the twin heat shields on this system. We spent a large amount of time to ensure that all components are kept below a threshold temperature which we have established to prevent damage to composite and hard components as a result of thermal exposure. This not only prevents the carbon from yellowing, but ultimately prevents the parts from failing. Comparing an intake that we have had installed for several months during R&D stages to a brand new unit, we have not seen any yellowing of the resin or damage to the carbon as a result of exposure to elevated temperatures.
    Any carbon will turn colors if exposed to high temperatures or UV for prolong periods of time, however we specifically ensured that if a composite component is going to be near those temperatures that precautions are taken to avoid/lower direct heat exposure for product reliability reasons.
    Quote Originally Posted by M3KILR View Post
    Not Likely, but if there seems to be a high demand for a different material it's something we could consider.
    Quote Originally Posted by jonpark View Post
    The fact that our intake has a lid helps contain the sound, which produces a tolerable supercharger whine, giving hint to the added performance without being intrusive.
    Jason
    Active Member Two Rings cookinsolo's Avatar
    Jun 25 2013
    2014 audi R8 v10, 2015 audi TTRS
    san antonio
    ECS got them fishing hooks out for the spring season and they hungry for your wallets
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I can't speak to have the ECS intake will hold up obviously, but in general, I agree about the yellowing or discoloration factors. It's inevitable with carbon fiber when exposed to high heat for extended periods of time. There is only type of resin/CF that prevents this, and the patent is owned by Chevrolet of all people. My understanding is that to this point, no one else has licensed it, uses it, or has anything similar.
    Jun 10 2008
    Spiders
    Chicago And NJ
    It's not Chevrolet its plasen composites that has the process and materials; Chevy as well as dodge and ford just happen to contract out to them.
    Anyways just placed an order for some additional coverage via DEI reflective material (a la - reflect-a-gold). Will cover areas where radiant heat is typically an issue (side wall of heat shield). Stuffed worked great on the roc-euro.
    @ECS how fast are you getting these shipped out if order was placed this morning? To Chicago so not that far of an adventure from Ohio.
    Oct 02 2006
    Wadsworth,OH
    @ECS how fast are you getting these shipped out of order was placed this morning? To Chicago so not that far of an adventure from Ohio.
    +1 on the Reflet-A-Gold! That stuff is amazing!
    We have plenty in stock so orders placed this morning should go out by days end. Chicago area is usually next day via FedEX once it ships according to our transit maps. Two days for UPS.
    Jason
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Cool. Good info. I knew it was something like that. Either way, very limited who has it (or better who can afford it).
    Oct 20 2008
    Denver
    oh crap. did i really just order this?
