I have installed about four short shifters in the past from other venders, and this is a nice looking kit. I looked at others, but was not keen on regular lubing as one manufacturer recommended, so I choose ECS. I had two issues with the ECS Short Shifter, which I installed today.
I'm not sure why the previous thread was closed, as it was very helpful. The comment from ECS that they had gone over all their stock and the wrong assembly being shipped would not happen again, was incorrect as it did, as mine was also incorrectly assembled.
http://www.audizine.com/forum/showth...-Throw-Shifter
Luckily, just before starting the install today, I was able read the post above, so I was able to check everything and once I found the issue I was able to swap the slide plates and re-assemble. I think ECS should go through their stock again, as this does take up some extra time. If by chance, someone did not see these posts, they could install and not be able to engage reverse and then waste time uninstalling and reinstalling. For the price, one would expect that the shifter would come, ready for installation.
The second issue was one of the bolts sheared when tightening the shift retainer plate. To be fair, it failed so fast it must have been a defective bolt from ECS's supplier. Luckily, I had a cap screw with the the same thread, and length and was able to use that.
The install is straight forward. The instructions are quite good, but read through them first. I did not get under the car right away, and removed the spring while the shifter was in the car, so I could install it on the new shifter, and have everything ready. Then, I went under the car to do the work there. I also found it easier to get to the T45 bolt from the top, but the the instructions are still very good. After getting the new shifter installed, and one little bit of fine tuning, I went for a drive.
The biggest issue with the stock shifter, for me, was how loud the shifting was. The plastic ball and socket made a terrible noise, and felt flimsy. I actually went in and greased it once, to to get rid of the noise, or at least reduce it. The new shifter is smooth, and provides solid shifts, without the noise. I have the setting in the 3rd hole/setting, the 2nd to last shortest throw. The throws are slightly shorter. Not as short as I would have expected, though I did not want it to short, so it still has a nice feel. I have one more setting if I do want it shorter. Reverse catches with ease. Another nice feature is the adjustment of the shifter height. I went about 1/4' lower than stock, but the adjustability should suit anyone.
All and all a well made shifter, and hopefully ECS can ensure they are assembled correctly.
