Page 1 of 36 12311 ... LastLast
Results 1 to 40 of 1403
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Carista app for iOS beta testing [wrench]
    I had the opportunity to beta test the Carista app for iOS on my iPhone and iPad this morning. My initial impressions of the app are good from a user interface perspective.
    Much easier to enable features compared to VCDS, and more convenient as it uses a wifi connection. When connected, it will take some time before you get to the menu screen. I suspect it needs time to read each control module (similar to how long autoscan takes in VCDS).
    As I have previously coded some features using VCDS, Carista appears to recognize which ones are enabled. Will still need to do some comparison testing to confirm which features actually work. Here are some screenshots that I took (some may be cut off as I had to scroll).
    I purchased my ELM 327 wifi OBDII interface for ~$16 which I have been using with Dashcommand. *Make sure not to accidentally get the cheaper bluetooth version.*
    To make things easier, I use it along with a 1 meter long OBDII flat extension cable so I can see the interface LED's working, and not worry about knocking the wifi interface with my foot.
    Opening screen and menu:
    Doors/Windows/Remote:
    Instruments/Displays/Dings:
    Lights:
    Heater & AC:
    Other:
    wifi interface:
    May 06 2014
    Las Vegas, NV
    Where did you get this???
    Nov 10 2014
    Apex, NC
    i need this in my life
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    register as a beta tester for free. the more feedback we provide, the better the app will get.
    http://www.caristaapp.com/ios/
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    Q7, Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    Following
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by audibmi View Post
    done ... so all i need is the wifi ODBCII connector? you mentioned a cable as well .. link or info on that?
    Present:
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    extension cable looks like this:
    Nov 10 2014
    Apex, NC
    ok thanks
    Present:
    Jun 06 2014
    Washington, D.C.
    Just registered. How long did it take for them to grant you access to the beta test? Thanks
    B8 S4 6MT | GIAC Stage II | Milltek Non-Resonated | Hotchkis Sway Bars | ECS Intake | Roc-Euro Short Shifter | Eurocode Alu Kreuz | 034 Transmission Mount | 034 Rear Diff. Mount | RS4 Grille | CR-15 Brace | P3 Gauge | USP SS Clutch Line | ECS Rear Carrier Mounts | 034 Subframe mounts | ECS Street Shield | Moog Endlinks | MercRacing HX | B12 Pro Kit
    B8.5 SQ5 | 034 Stage II | MercRacing HX | RKX Transmission Mount | P3 Gauge
    Senior Member Two Rings bbhbba's Avatar
    Mar 06 2011
    '17 BMW 440i Grand Coupe MPPSK ; '18 Audi SQ5 TDI
    Nor Cal Bay Area
    This looks very interesting. Hopefully the price is reasonable.
    2013 S4 Prestige S-Tronic
    Is this the device here...making sure I get the right one.
    New Version V1.5 ELM327 OBDII OBD2 Bluetooth Car Diagnostic Interface Scanner https://www.amazon.com/dp/B008UR7J6I..._FnhXub08T8AVE
    Nevermind. That^^ is not the right one. This is.
    iSaddle WIFI Wireless OBD2 OBDII Scan Tool Auto Scanner Adapter Check Engine Light & CAN-BUS Auto Diagnostic Tool for Windows & Android Torque & iOS iPhone iPad iPod https://www.amazon.com/dp/B00PB6G9ZS..._wxhXub0PMH6X3
    Guess I should learn to read.
    May 01 2014
    New York State
    So this would replace vag com?
    It's here! - 2015 S4, Sepang Blue, 6MT, Sports Diff, etc
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Reddington View Post
    yeah
    Present:
    Feb 25 2013
    MI
    Quote Originally Posted by doug97gxe View Post
    yeah
    I only see coding changes. Vcds had additional functions like changing adaptation parameters, changing basic settings (opening e brake for instance), and logging internal ecu measurements that are not available on the CAN bus.
    Not saying this doesn't look cool, but interested to see if the features approach vcds. Another big benefit of vcds is being able to work on all Vw/Audi cars, even older ones.
    May 01 2014
    New York State
    Well it looks to be a nice alternative to vcds for those of us that want to easily be able to make coding changes. Removing the "wink" for example. I signed up for the beta.
    Mar 09 2013
    Chicago
    http://www.audizine.com/forum/showth...pp-for-our-car
    lots of good info on the b8 a4 forum (android)
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Signed up for the Beta...great news!
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Aug 20 2009
    2004 r32
    United States
    This is sick. I signed up also
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    For those who just want to make some basic changes this might be an easier way to go.
    Will this allow you to setup the car to start in comfort instead of auto like it does stock?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    Does it work with any ELM 327 scanner?? ANyone try this one? http://www.amazon.com/KingMansion-Wi...ds=WIFI+ELM327
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    Just got the invite for the beta test. Need to pick up the wifi adapter now. I already have VCDS, but want to check this out.
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Sep 05 2012
    Do I sense a price drop coming from Ross Tech?
    Doesn't do all the fancy stuff, but covers a lot of the basics.
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by BigBluu View Post
    same here
    Present:
    Senior Member Three Rings JMUNFORD's Avatar
    Sep 26 2012
    B9 S4, B5 S4, Grand Cherokee Trailhawk
    Tampa,Fl
    Just signed up, hope I get the invite
    Nov 25 2014
    Alabama
    To save the Android users some time there's an Carista Android app but it's not in beta and in the Play Store. I got the wireless OBD2 adapter in the mail today - same ELM 327 adapter as the one above except Bluetooth. Paired it up, works perfectly. Carista app works pretty good but some of the code settings seem off. Like it says my auto windows up with long press is on but it's definitely not. If you change any settings and try to save it the app asks for $19.99 for the full version. Would like to see if it could accurately change something before dropping $20 on it so subscribing to see how the iOS users do. Also if you have a fault code and want to read it, $19.99.
    2018 SQ5 | Monsoon Gray | Prestige
    Nov 10 2014
    Apex, NC
    OP is this true? you have to pay before you can make updates?
    Present:
    May 06 2014
    Las Vegas, NV
    I have the Vgate adapter.... All I get is this:
    Everything is duplicated, and missing half of what everyone else gets as far as options.... Thoughts??? Anyone know who I should contact???
    Nov 25 2014
    Alabama
    I'm just talking about the Android app, not the iOS app. If the iOS app is currently beta it's probably the full app and you can save your settings or read your codes. But once it's out of beta then that's probably what people are going to have to pay. If he's a nice dev then maybe he'll give the beta testers the full app for testing it, but I've seen it go both ways.
    Established Member Two Rings ishowerinjager's Avatar
    Aug 06 2014
    Edmonton, Alberta
    Anyone else try this yet??
    any idea on the consequences if it gets interrupted while processing a change??? or any other consequences if wifi gets dropped?
    2010 S4 - Meteor Grey, 19'' OEM, DSG, Sport Diff, BO, Carbon Atlas, Silver Silk Nappa leather, MMI 3G, Advanced Key, CPO
    Apr 29 2013
    Ottawa
    Quote Originally Posted by ishowerinjager View Post
    Good point. Generally nothing good can come from the connection getting interrupted while writing to the ECU.
    Veteran Member Three Rings EasternLI's Avatar
    Nov 21 2004
    2015 Jeep Grand Cherokee Overland High Altitude
    Sag Harbor, New York
    Received an invite now just waiting for my wifi dongle to show up from Amazon
    2013 S4 l Monsoon l Black Nappa l Sports Diff l MMI Nav l B&O l Advanced Key l Carbon inlays l GIAC Stage 1 & DSG tune
    AKA: Ticketproof
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    similar to android version, the current iOS beta version allows reading of modules, but to save or enable changes, purchasing the app is required.
    Established Member Two Rings javinos's Avatar
    Jan 18 2015
    Orlando, Florida
    Downloaded app and ordered port... Will give it a shot
    Honda 4Dr Civic Si 2008 (CAI/hearders/custom exhaust/hondata) - SOLD
    S4 '14 | Glacier White Metallic | DSG | Black Optic pkg | MMI | B&O | 19" Rotors | RocEuro Intake | LED Fogs and Interior |
    Nov 10 2014
    Apex, NC
    well that sucks
    Present:
    Apr 29 2013
    Ottawa
    well that sucks
    it's $20 vs a $300-$400 VCDS cable...
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by amz View Post
    no prob buying it... want to make sure it works before i do
    Present:
    Mar 01 2006
    Kitchener, ON
    Been running this on my BB and Android using BT. For me all I care about is the simple mods as the app does this automatically for you, and clearing codes / checking codes as mentioned by original DashCommander helps out.
    I like the extension idea!!! to tuck the OBDII device away
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Senior Member Three Rings Black_V!per's Avatar
    Aug 30 2013
    '08 Harley Crossbones, '91 K5 Blazer
    Kingman, AZ
    Quote Originally Posted by RudyH View Post
    Just downloaded the Android App, I've had this Bluetooth adapter for well over a year and didn't know this existed! Woot! Good thing it's releasing for the iFolk too, otherwise I wouldn't have seen this!
    "My car is a toy, not a mistress, I don't need to shower her in diamonds for her to put out."-mecheng
    Daily: 2014 S4 Premium Plus
    Toy1: 2008 Harley Davidson Crossbones Springer
    Toy2: 1991 Chevrolet Blazer K5 4x4
    Senior Member Three Rings focusaudi's Avatar
    May 02 2012
    Wrangler TJ, 2012 S4
    Denver, Colorado
    I have a ODBII bluetooth device and use Carista on Android. It's a little finicky- all of the options don't show up every time. If you don't get all the options the first time, rescan and you may get more the next time. It can take a little while to scan. For the 2 times I scanned, I got all of the ones that OP got except the HEAT/AC category. Has anyone actually changed a value successfully w/ the pro version? I'm definitely going to buy if it works. $40 (adapter + software) vs $400 (vcds cable) is a slick deal.
    One thing to keep in mind is that the last time this android app was updated was 10/27/14.
    2012 S4 | ice silver metallic | DSG | prestige | AWE Exhaust | AWE S-FLO Intake | Alu Kreuz | eurocode sways and end links | 20% tint
