Results 1 to 11 of 11
    Veteran Member Three Rings S-Liner's Avatar
    Oct 21 2014
    Illinois
    Intermittent/No Start Condition
    Background:
    '10 Avant 2.0T, 85.3K
    Last major mechanical work @ 84K; Stage II oil consumption fix
    Last electrical work @ 85.2K; Battery (OEM/ACM) replacement & proper recoding
    Issue:
    Car has intermittent start issues, at times a simple jump start will work. This time around, I get nothing but a 'CLICK' sound. I'm pretty sure it's not the battery. I had the battery recoded at a reputable local shop. This is really pissing me off. I've searched the forums and have only come across a couple threads where there is talk of a crank position sensor and a relay.
    As it is now, my car is sitting crippled in the parking lot where I work. I'll need a tow truck to recover and drop it off at the dealer this weekend.
    Before I take that route though, are there any ideas out there where I could possibly be looking into myself?
    Thanks in advance
    '10 A4 Avant Prestige Plus S-Line w/sport pkg
    My Oil consumption results..."Oil consumption measurement found to be using 3.26 quarts per 1000 miles"
    Mar 26 2012
    Charlotte, NC
    I had a similar issue.
    That took the dealer a while to fix. I can check the logs when I get home. Mine wouldnt start, but if i jump it it would.
    They did a few things but I think the fix was the ignition module and they added another grounding wire from the battery to the car base in the trunk.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    If you have vag-com you can read the battery as you try to start the car and see what's going on, sounds like you might have a bad battery control module. Did it do this before you replaced the battery?
    Oct 21 2014
    Illinois
    No VAG-COM yet.
    It did this once before, then I decided to replace the battery. I assumed it had gone bad after I had seen it was the original battery after 85K miles.
    SDF1, about how much did you end up spending for the repair?
    Mar 26 2012
    Charlotte, NC
    Warranty :)
    Mar 26 2012
    Charlotte, NC
    Car does not start arrived by towing
    Faults found
    Canbus wire from J519 to canbus post. Replaced Wire 000979009EA (Can Bus Wires)
    Also another wire from J519 to electrical system control module.
    no start issue came back a few days later
    Replaced ignition starter switch 8K0909131C
    no start issue came back a few days after that
    Fault P068A00 found in system.
    Rewired power supply replay J271
    Oct 21 2014
    Illinois
    Damn.
    I really hope they find and fix the actual issue(s) at once versus dicking with it and hoping they've solved the issue repeatedly.
    Oct 21 2014
    Illinois
    Quick update;
    My Avant is up and running, picked it up today from the dealer...with all the relays, modules, and "hi-tech" shit installed in these cars, the starter solenoid failed!
    I spoke with the mechanic who wrenched on my car and he said in the 12 yrs he's been working with Audi, he's only had to replace like 3 or 4 starters. Not bad, right?
    Oct 21 2014
    Illinois
    Problem is back! So pissed off...a $589 repair bill for a starter...FML!
    Same issue, just a click every time it's tried to be started.
    Mar 26 2012
    Charlotte, NC
    It took my dealer 3 times till they figured it out.
    Tell them to reground the battery ground to the car and check for faults.
    Do you have VAG Cable?
    Also try this.
    Connect your car to another car/battery from the hood and try to start the car.
    If it starts. Well I have no clue.
    If it doesn't start. Hummmmm
    Now unplug the car after 10minutes and try to start the car again. If it starts then you have the same problem I had a 2 years ago. I can send the the contact info to my dealer and let the two head mechanics chat.
    Oct 21 2014
    Illinois
    Picked up my car today, 10 days later....problem solved---I hope!
    Tech spent some time shooting wires, ended up replacing the shit below...
    8K0971228 Alternator/starter harness
    06H911021A Starter (warranty)
    So, from what I was told. There was too much resistance in a certain section and mass current draw at another point...yada yada yada
    We'll see if this fixes the problem.
