Page 1 of 3 123 LastLast
Results 1 to 40 of 83
    Sep 11 2009
    NE
    Exhaust backpressure fail - why you need large dia exhaust or cutouts
    This is allroad, BillyBoat performance exhaust (dual 2.25") without any cats too just the resonator and mufflers so fairly quiet overall. 3in DPs. Pressure sensors located just before neckdown to 2.25" inside gutted main cat with smooth transitions everywhere.
    Pull done with Tial 770 at 32psi of boost...
    Yes, that about 10psi of backpressure in exhaust at 7k rpms... That's just horrible and explains my less than stellar top-end and torque fall off once getting into 6k rpms area, it pulls like hell of wheels 5-5.5k and then mellows down like it was k04 turbo..
    I will be welding in boost activaed (pneumatic) cut outs sometime in near future, like these:
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Those cutouts looks cool but why not just run a bigger exhaust?
    May 20 2012
    San Jose
    Interesting data, but 2.5 PSI rise from where it's running strong to where it's not doesn't seem like enough to be causing the performance drop-off you're feeling. I'll be interested to see the follow-up data.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by landfill View Post
    Does he really need a bigger exhaust?
    Edit: Logic fail.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Mar 18 2011
    Chicago
    Quote Originally Posted by LINDW4LL View Post
    Does he really need a bigger exhaust? He has a combined 5" catback.
    In terms of cross-sectional area it falls somewhere between a 3" and 3.25" catback. I'm definitely interested in seeing how significant of an effect the cutouts have!
    Current: 2012 Q5 2.0T, 2009 A4 2.0T
    Previous: 2004 A6 2.7T SRM K24, 2005 Allroad 2.7T GTX3576R
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Area of a circle is a nonlinear function.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by rtl5009 View Post
    Area of a circles is a nonlinear function.
    Ahh, good point- duh.
    -Hayden
    Nov 14 2013
    Did I read wrong I interpreted he had too much
    constriction up top. I guess I goofed.
    Sep 11 2009
    NE
    I don't want to redo the exhaust, I like the one I have,very civilized. Adding cutouts will accomplish what I want, no restriction at WOT and while quiet and flowing ok in normal driving.
    Just letting you guys know that unless you have some straight 4" pipes there will always be backpressure in the exhaust stealing your HP since cylinders have to overcome this additional pressure (backpresssure raises pre turbine pressure) to expel spend gases - which means they don't expel as many out as they could with open exhaust.
    Good article on this:
    http://www.autospeed.com/cms/article...x-Blows&A=1770
    Sep 11 2009
    NE
    Quote Originally Posted by oppositelock View Post
    Several things are working against developing proper power as engine goes beyond max torque RPMS: lowering VE of engine (less and less time to get air in ends up in les and less charge in cylinder), increasing IATs of air (less and less oxygen as air heats up) and the rising backpressure resulting in less complete exhaust cycle as it goes up and up so less and less space for new air.
    This log is just an illustration, I was only interested in seeing what kind of backpressure I would see at 6-7k rpms. I did this on local road, in 2nd gear, brake boosting the crap out of car so only really captured around 6-7k window reliably,
    Seeing 10psi just dropped my jaw...
    Feb 10 2013
    Slovenia
    This is interesting, i have same problem with my car, at 6500-7200 rpm wont go smooth as is should.
    May 20 2012
    San Jose
    Quote Originally Posted by julex View Post
    Definitely agree that increasing backpressure + decreasing VE == no bueno. It will be very interesting to see not only delta P but delta T! (FATS) Make sure to wear earplugs on long WOT pulls.
    BTW, what sensor are you running? I searched for 'exhaust pressure sensor' and didn't find much, just some Ford diesel truck stuff on eBay.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    I should be good with 4" single
    RS6 hybrids and corn
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    When I switched from a 3" Borla to 2.5" dual and instantly was over boosting 4psi on my gt28s. Was surprised at the restriction of the 3".
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Sep 11 2009
    NE
    I just used 18mm o2 style to quick connect air hose adapter (my compression tester kit had one) and run the line to my zeitronix sensor which normally reads from manifold vacuum line.
    Nothing melted as it was a brief test :)
    Jul 28 2009
    Philadelphia PA
    Bold move.
    c8 a6 allroad
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Nice info. Kind of surprised at the amount of back pressure, though I don't know what the BB exhaust piping layout looks like.
    Quote Originally Posted by Blue AWD View Post
    The operating pressure is an important factor in this, what were you operating at? A 3 psi increase, from 21 to 24, made a difference when I tried swapping exhausts.
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    http://www.exhaustvideos.com/faq/how...pipe-diameter/
    "A good section of straight pipe will flow about 115 CFM per square inch of area. Here’s a quick table that shows how many CFM each common pipe size will flow, as well as the estimated max horsepower for each pipe size:"
    RIP Daz, you will be missed.
    Nov 23 2004
    NH
    Quote Originally Posted by FlyboyS4 View Post
    I run 30 and when I switched was hitting 34.
    08 3.2 A3 DSG DD
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by Meow View Post
    There's no mention of the pressure drop for those flows, I'm guessing that it is assuming a NA engine which is not a good reference for a forced induction engine.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Agreed. Much, much better option IMO.
    Sep 11 2009
    NE
    Quote Originally Posted by NOTORIOUS VR View Post
    Question of budget I guess. I like current system the way it is, it looks good, it is in excellent condition (all SS everywhere) and works very well for DDing. Only top end seems to be affected which can be remedied by cutouts. Slapping cutouts would be far cheaper...
    Anyway, sometime this week I will disconnect my exhaust at DP V-Bands (3in there) and pull it back to create large gap between DP and exhaust pipes, do a FAT pull or two to see what the difference is. Results will drive my decision about what to do next.
    Jul 28 2009
    Philadelphia PA
    He wants civilized until wot.
    c8 a6 allroad
    Jan 29 2009
    Even if the problem is remedied for now with cut out's you have to deal with an absurd amount of noise pollution with the cutout's open. So it's kind of backwards from what you really want.
    Re-doing the exhaust to properly fit your setup (high boost 770 turbos) is IMO your best option as you've going the wrong way from the beginning trying to keep a restrictive exhaust from the get go.
    A larger diameter exhaust system can be quiet and still flow a ton without ever having to have a blaring cut out open that sounds like complete crap and draw attention to yourself. Plus you have to actively open and close it.
    My vote is for a 3.5" exhaust and be done with it and sell your existing setup instead of hacking it up.
    I'm not sure I follow? Are you trying to say it's not possible to do with a larger exhaust? Because it is, quite easily at that.
    Oct 27 2011
    TOYS
    Philly Suburbs
    A 3.5" exhaust with dual 14151 mufflers is VERY tame sounding FYI. It sounds almost stock from the inside of the car IMO.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    maybe im interpreting this wrong, but a 3" single exhaust can only flow enough to make 339hp
    doesnt make sense to me, like every BT b5 a4 uses 3" and puts down well over 339
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Sep 11 2009
    NE
    Quote Originally Posted by GrapeBandit View Post
    It is not like 3" will suddenly stop flowing at 340hp you know.
    My example mirrors yours almost to the dot. I still make ~550WHP on dual 2.125" (estimated ID with 2.25 OD) which is exact equivalent of single 3" pipe (7.09 vs 7.06 in^2). But, I can probably make 600WHP by just upping the exhaust to dual 3" as per table above which will cause the backpressure to go from 10psi+ to 2-3psi, if even that.
    What the table tells us that with piping properly sized, you will have negligible amount of backpressure and thus very minor power loss due to hampered VE.
    Sep 11 2009
    NE
    I linked the cutouts I want to install above. They will be boost operated and open at around 15psi. So DD condition they will remain closed and automatically open once I cross 15psi which is where I still have no backpressure as that's about 1/2 in RPM to redline and at 2/3 the intake flow potential so about 0.33x the maximum exhaust flow my car tries to push now (I did some more measurement on that).
    I will visit my ghetto muffler place to see what they say. If they give me killer price on dual 3", that's what I will do. If not, cutouts!
    Oct 27 2011
    TOYS
    Philly Suburbs
    I have never personally used cuts, but I hear they don't like backfires and they usually leak when closed. Just something to keep in mind.
    Jan 29 2009
    yep... they never seal well, especially once the carbon gets up in there... To me exhaust leaks are quite annoying, and another reason why I would never consider a cut out. The first reason being they make the car sound like a pile of junk.
    Jan 06 2007
    Mk7 Golf R
    FL
    The table is unlikely to have been intended for a forced induction engine. Leaving the amount of pressure drop out is a critical omission for a turbocharged setup.
    Sent from my PC36100 using Tapatalk 2
    Mar 08 2012
    MI
    Your pressure sensor location can have a large impact on the readings you are getting. You placed it in a location with transitions, nozzles and diffusers all over the place in there depending on how you located it in the main cat. Though I am thoroughly confused now reading your post. You say you have 3 inch downpipes but still have a gutted main cats? Can you clarify the location. Im not doubting your exhaust is too small and that you have back pressure issues, but I am curious of where you located the sensor and what your full exhaust system really is.
    Placing it too close to a transition like a taper down from 3 inch to 2.25 inches can impact the readings.
    Mar 08 2012
    MI
    airflow is airflow, leaving out backpressure means the table was likely intended for turbocharged vehicles as having enough backpressure is tossed out the window when talking about turbocharged car performance and only a discussion of the required airflow is necessary. Only NA cars worry about needing back pressure for maintaining midrange torque. Stop posting in this thread, you have nothing to add and your comments are irrelevant and ignorant.
    Sep 11 2009
    NE
    Anybody has logs from a GT car with a nice open exhaust? I want to compare my logs (where I calculated my engine's relative VE which seems like be tracking RL_W exactly so for all intended purposes RL_W is "virtual" VE...) so that I can see what's my % drop off in RPM range.
    Thanks.
    Jan 06 2007
    Mk7 Golf R
    FL
    I said pressure drop, and when determining air flow rate it's necessary to specify at what pressure drop the flow rate is being measured.
    What you are thinking of is a completely different subject and not what I am referring to.
    Mar 08 2012
    MI
    Flow is what matters, moving volume... pressure is a byproduct of flow restriction, pressure drop is irrelevant, much like your comments.
    Jan 06 2007
    Mk7 Golf R
    FL
    What creates flow?
    Sep 11 2009
    NE
    Part of backpressure mystery solved (besides small dia pipe). View when looking inside of muffler...:
    Yup, series of perforated triangular baffles so the exhaust gas has to go through a series of these and there is also a bend at the end on that obstacle course (or beginning rather). Looks more and more that doing dumps might be in my future (I just can't afford 1k for mandrel SS exhaust right now).
    Jan 06 2007
    Mk7 Golf R
    FL
    Nice that you were able to get some better reason for the pressure reading. How's the pressure sensor oriented, could you be picking up dynamic pressure from the airflow?
    Sep 11 2009
    NE
    Probably. I am not concerned about the sensor placement, I just wanted to see a big ball park. I will do some WOT pulls tomorrow wit exhaust disconnected and plot relative VE to see how things improve. I will continue this thread for others' awareness.
