View Poll Results: Did this work for you?
Voters
67. You may not vote on this poll
  • Yes, it worked.
    64 95.52%
  • No, it didn't work.
    3 4.48%
Page 1 of 7 123 ... LastLast
Results 1 to 40 of 280
    Senior Member Two Rings TunTap's Avatar
    Oct 17 2013
    LA
    HOW-TO: Lowering AAS with VCDS
    I finally accomplished lowering the S6 with VCDS. Some said it can't be done, but it most definitely worked for me. It should be entirely reversible in case you decide to revert the settings. All research was done through Google and playing around with software settings, none of this information was provided by Audi or Audi dealers. This method is an alternative to Lowering Links (which are great if you don't have the electronic tools/would rather go the mechanical route), or H&R lowering module (which is also great, and allows for on-the fly adjustments vs. having to mess with car systems).
    I figured that since all the tools and information required to do this have already been made public on the internet, it is just matter of time until someone posts a step-by-step guide, so here it is.
    DISCLAIMER: I am not responsible for anything that these changes may cause, or if your car breaks, or if dealership finds out and denies your warranty if something goes wrong... Try this at your own risk.
    0) Set your car to "Auto" mode (not dynamic, comfort, etc.). Make sure car is on level ground. Close doors. If any doors are opened during the procedure, it will be interrupted. Make sure your car is NOT in a towing or tire changing mode.
    1) Load up VCDS, go to Module 34 - Level Control
    2) Go to "10 - Adaptation", take note of 4 values titled as "Body height front left wheel house edge" - mine were set to around 384 from factory.
    3) Take the values you noted above, and ADD your desired drop in millimeters (mm) to each value, write it down... So if your left front wheel was 384.5, your new value will be 401.5. Repeat for the other wheels. It is not critical to be 100% precise here, rounding the values is fine. Note that maximum Audi-approved drop is 17mm from what I've gathered. You can go lower, but if you go lower, you're also affecting other systems, such as cameras, adaptive cruise, etc., so be careful.
    Technically, if you want this procedure to be done properly, instead of taking existing values, you will measure all 4 wheels after completion of the step 7, and then add your drop value if desired. Suspension height values are measured from the center of the wheel to the edge of the fender.
    4) Go to Security Access, enter code provided on the following website, under VCDS section, item #3 (I'm not posting this directly to avoid spreading sensitive data, although it's been posted on other forums in past) http://www.stemei.de/pages/coding/au...ng-des-aas.php
    5) You should get a message stating that security code has been accepted - if you don't, something failed, stop doing what you're doing
    6) Go to 04 - Basic Settings
    *** IMPORTANT: Whatever you do, DO NOT select "Reset All Adaptations" - this is not undoable, and will require a visit to the dealer. ***
    7) Select "Activate Level Control", hit "Go", wait for it to complete (should only take a second, until it says "not running").
    8) Select "Delete Calibration For Level Control", hit "Go", wait for it to complete, your car will throw a fault code and you will see an error message stating Air Suspension Malfunction - this is normal.
    7) Select "Start Up to Reference Level", hit "Go". This step will take about a minute, and your car will go up/down during the process (you'll hear hissing noises). Wait for it to complete, until it says "not running". DO NOT use the "start up to reference level production" option.
    9) Select "Go Back", go to "10 - Adaptation" on the previous screen.
    10) Next you will need to enter new adaptation values for all 4 wheels. Select "Body height front left wheel house edge", then enter new adaptation value, and hit "Do it", then repeat for the other 3 wheels. I did it in the order the menu was arranged (FL, RL, FR, RR) - not sure if the order matters, but just in case. Each time you enter a value, you should get a message stating that it has been accepted.
    11) After you're done entering adaptation for all 4 wheels, select "Go Back", and return to "04 - Basic Settings" again.
    12) In basic settings, select "Calibrate Level Control" and hit go, it will take a few seconds. Wait for it to say "not running". If you get an error during this step, you either missed a step, or something went horribly wrong.
    13) Select "Activate Level Control", hit "Go"
    14) You're done, now go to "02 - Fault Codes" and Reset codes.
    If this did or didn't work - please share your experience with the rest of us here.
    UPDATE:
    There is an additional setting that will prevent your car from auto-lowering at ~30 mph, as well as allow you to raise the suspension while driving at any speed. Standard settings gray out the "raise" button over a certain speed, and are particularly annoying if your car is lowered via the steps above and you would like to keep it raised for an extended period of time (such as city driving with a lot of dips, bumps, ramps, sloped driveways, etc.)
    1) Launch the green menu by holding Car + Menu buttons. (If you don't know how to enable or use the green menu, see the main VCDS thread)
    2) Go to "car" then "carmenuoperation" menu
    3) Scroll down to "suspension"
    4) Change the value to "5"
    5) Press the center menu knob to save
    6) Reboot the MMI (Menu button +Center knob+Top Right soft button)
    7) Turn the ignition on/off
    Let me know if I missed any steps as I'm posting this off my memory right now.
    Last edited by TunTap; 10-20-2014 at 08:53 AM. Reason: Added raise at any speed instructions
    '05 S4 Avant
    Gone: '13 S6 | '14 SQ5 | '13 S5 | '11 Q5 | '06 A3
    Senior Member Three Rings S6Express's Avatar
    Jan 14 2014
    Miami, FL
    Items for Sale
    Great write-up and research. I can't wait to try it. I have lowering links, but I'll remove them and try this when I get a chance.
    2013 S6
    Ibis White / Black Int / Innovation / Bang & Olufsen / LED Headlights / Carbon Inlays / Black Headliner / Sunshades / Cold Weather
    Mods:
    HRE P47SC 21" x 9.5" Wheels / RS7 Rear Diffuser & Oval Exhaust Tips / Red Bembos / Bigger Rear Spoiler / Dead Pedal S6 Badge / Black Wrapped Grille Slats / Black Wrapped Grille Edge / Black Window Trim / K&N Drop In / Escort Max360 Hardwired w/ Remote SmartCord / VAG COM Mods / 35% Tint
    Veteran Member Four Rings zee007's Avatar
    Jan 12 2010
    2016 RS7; 2017 X5M
    RVA
    Items for Sale
    Fantastic work! I will give this a go next week. I had mine lowered by my dealer, but actually want to raise the rear a couple of mm to even out the reverse rake. Will try this.
    Thank you for sharing.
    - Zee
    Gone: MY16 RS7 | Nardo | Diamond | Carbon Optic | Sport Exhaust | Eurocode | 034M | H&R | TAG | K&N
    Past: MY09 TT | MY10 S5 | MY13 AllRoad | MY15 S6
    Current: MY17 BMW X5M | Loaded | Quick | Brute | Not an Audi
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    I know a guy at the dealer who did this for me in ~5 minutes. However, I know a lot of others had no luck with the dealer doing this for them. +1 Great work.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Jan 14 2014
    Miami, FL
    Items for Sale
    Quote Originally Posted by Xtek View Post
    I tried and they declined me. I then offered to pay - and they declined me.
    2013 S6
    Mods:
    Jun 09 2013
    Quote Originally Posted by S6Express View Post
    The guy I know at the service department just went Audi's #1 service tech award in Germany, beating out the Germans, even.
    - Chad
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Items for Sale
    Awesome writeup!!! I also have the links but on Sunday Im going to put the stock ones back on and try this. Will report back.
    13 HD FatBob
    17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/BMS JB4/CTSTransMount/034Intake/034Strutbrace/034RearSwayBar/034RDPipe
    16 S6 (gone)
    14 S6 (gone)
    14 S6 (gone)
    13 S6 (gone)
    10 S4 (gone)
    ACNA Lifetime Member - 26690
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    Items for Sale
    Looking forward to see further results in the poll.
    Great write-up!
    Some say that the outline of my left nipple is exactly the same shape as the Nürburgring
    Instagram: inferno_rs7
    Veteran Member Four Rings CreoSTi's Avatar
    Feb 22 2004
    2016 Acura RDX
    West L.A.
    See you tomorrow..
    -Mike- : 2001 S4 → 2011 S4 → 2014 S6 → 2016 M3 : Recaro ProSport
    Mortgage Capital Associates
    Senior Member Three Rings JB616's Avatar
    Oct 13 2010
    Pittsburgh, PA
    i am trying it as i type this. will let you know if it works out.
    2014 SQ5
    Oct 13 2010
    Pittsburgh, PA
    TunTap you are awesome. Yes it most definitely works. Lowered 17mm all around from the values that were shown prior to the addition step.
    2014 SQ5
    Oct 17 2013
    LA
    Quote Originally Posted by JB616 View Post
    Fantastic! Looks great
    '05 S4 Avant
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2004 Nissan Titan
    Duluth GA
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Oct 14 2006
    Rocky Mountains
    Items for Sale
    Everything worked for me as well. There were some very, very minor differences that I saw in the instructions compared to what I went through, but it was so negligible that it really didn't change the overall essence of the instructions. Like for step 10, after each corner, I had to select "stop" before moving to the next step. I think that was really the only thing that I didn't see in the instructions, but again, it was so minor that you should be able to figure it out pretty easily.
    I voted in the poll
    GREAT JOB, TUNTAP!!!
    Oct 17 2013
    LA
    Quote Originally Posted by lnferno View Post
    I voted in the poll
    I wonder if this is different for different VCDS versions. I didn't have to select stop after each corner. Using 12.12.something or whatever the latest is.
    '05 S4 Avant
    Oct 14 2006
    Rocky Mountains
    Items for Sale
    Quote Originally Posted by TunTap View Post
    I'm running VCDS Version: Release 12.12.2.
    Again, no complaints. Everything worked like a charm!
    Established Member Two Rings ellisina4's Avatar
    Aug 23 2012
    Chicago, IL
    You are the man. Thank you. It worked for me also.
    I tried adding 17mm but it would not accept the change. Same thing with 16mm, but 15mm worked all around. When I measured, it actually dropped the car 1/2" or about 12-13mm. I actually measured from the top of the alloy wheel to the fender, before and after. I figured measuring from the center of the rim is fairly subjective as you are never sure if you are exactly at the center of the rim.
    Also, when switching to Dynamic mode, it lowers the car another 3/8" and when raising the car via MMI, it raises the car 3/4" or 1/4" above the original height (before lowering it with Vag).
    http://www.audizine.com/gallery/show...=76773&cat=500
    Again, thank you.
    2013 S6 4.0T
    Quartz Grey, Black interior
    Driver Assistance Package, LED headlights, Carbon inlays, Cold Weather Package, Black headliner
    GIAC ECU and DSG tune
    Oct 14 2006
    Rocky Mountains
    Items for Sale
    Tuntap - you should do the honors and add it here.
    Oct 17 2013
    LA
    Hmm, I thought I added it to a thread like that. Will do that one as well.
    '05 S4 Avant
    Feb 23 2013
    2016 Audi S6; 2015 Toyota 4Runner TRDP;2013 Toyota Prius; 2014 Yamaha FZS Waverunner
    Sinking Spring, PA
    Items for Sale
    In step 4, where do I find the security code. Am I just blind for not seeing it. Help please.
    Oct 17 2013
    LA
    Gents, just had a thought - if you do this mod, post the numbers that you used for the adaptation (and pictures are always welcome).
    Also, I'm going to continue looking into the settings to see if maybe there is a way to enable adaptive damping controls. S6/7 cars have the ability to change damping stiffness, but it doesn't look like it's coded to allow changes to factory settings. I believe the RS7 has damping adjustments, if anyone with an RS7 can run some VCDS dumps - let me know.
    '05 S4 Avant
    Oct 17 2013
    LA
    Quote Originally Posted by chudiddy View Post
    Go to the link provided, the entire page is in German, but under the red text in step #3 there's a 5-digit code.
    '05 S4 Avant
    Oct 14 2006
    Rocky Mountains
    Items for Sale
    Quote Originally Posted by ellisina4 View Post
    Again, thank you.
    Do you have 19s or 20s?
    Oct 17 2013
    LA
    Quote Originally Posted by pandi View Post
    Dumb question. Please don't attack! How does one get VCDS?
    Order from Ross Tech - http://www.ross-tech.com
    '05 S4 Avant
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 Mini Cooper S
    Bay Area CA
    Great job! Now I feel a bit silly to buy H&R ETS LOL. Anyway, I would stick with H&R though as I have lowered my car further than 17mm limit.
    2018 Audi TTRS, Daytona Grey: Technology, Black Optic, Sport Exhaust, Blackout Badges, Pedalbox
    Other: 2017 BMW X1 and lots of rental cars
    Gone: 2017 Mini Cooper S, 2014 Audi RS7, 2014 BMW 228i, 2013 Audi S6, 2013 VW Jetta TDI, 2011 Audi S4, 2008 Audi A4, 2008 Subaru Legacy
    Jun 24 2012
    2017 Mini Cooper S
    Bay Area CA
    If you don't mind driving to NorCal, I can do it for you for free
    Active Member One Ring Oni1031's Avatar
    Jun 05 2013
    Beijing
    Thanks man, also worked for China-spec 2013 C7 S6.
    Jan 14 2014
    Miami, FL
    Items for Sale
    Quote Originally Posted by Oni1031 View Post
    Cool, looks like this works for everyone. Up to now, this had been the VAGCOM Davinci Code. Update: Code broken!
    2013 S6
    Mods:
    Oct 17 2013
    LA
    Quote Originally Posted by VeryBadman View Post
    The 17mm limit doesn't seem to be enforced in any way. I may or may not have it 25mm lower than standard right now.
    '05 S4 Avant
    May 04 2010
    Duluth GA
    That's a good point, because "standard" seems to vary. My car had 396/398mm stored for front/rear respectively while TunTap was 384, which is 10mm higher than me. My current values are 406/408 which would be 20mm lower than TunTap.
    Robert Cheng
    Oct 17 2013
    LA
    I see 3 versions.
    Name
    VCDS Ultra Professional Kit $1,299.00
    VCDS 2-Tech Professional Kit $999.00
    VCDS Professional Kit $699.00
    Which one would be needed?
    None of the above. Get the enthusiast kit with can-hex-usb cable for $349.
    '05 S4 Avant
    Established Member Two Rings lobosmd's Avatar
    Dec 15 2013
    2012 LR4
    US
    I see 3 versions.
    Name
    My guess is you don't need the pro kit and can go with:
    http://store.ross-tech.com/shop/VCHUC.html
    Someone correct me if I'm wrong.
    2014 S6 glacier white with black optics, piano black layered aluminum inlays, B&O
    Oct 17 2013
    LA
    I see 3 versions.
    Name
    What car are you using this on? Your profile says A6 , which doesn't have air suspension as far as I know (unless you're in Europe).
    '05 S4 Avant
    Veteran Member Four Rings CanuckRS's Avatar
    Dec 20 2006
    CAN
    all you need is the one that costs $349.
    2016 RS7 | Bathurst 21X10.5 ET32 Michelin PSS 295/25/21
    Veteran Member Four Rings pandi's Avatar
    Apr 15 2012
    AriZona
    Items for Sale
    Quote Originally Posted by lobosmd View Post
    I think this is the one TunTap meant for $349. So let me get this right. I would just connect this between the car and a laptop and I would be able to do this if I had an S6?
    Dec 15 2013
    2012 LR4
    US
    You'd also have to download the software to your laptop:
    http://www.ross-tech.com/vcds/download/current.html
    Oct 17 2013
    LA
    And you need a windows laptop (XP or 7, haven't tried on 8)
    '05 S4 Avant
    May 04 2010
    Duluth GA
    Confirmed to also work in VM Fusion on a Mac.
    Robert Cheng
    Oct 17 2013
    LA
    Quote Originally Posted by maxhawk View Post
    Or that. That's what I use as well.
    '05 S4 Avant
    Mar 20 2004
    Lawrenceville, NJ
    Items for Sale
    Im using mine with 8 and it works but I hate 8(whole other argument).
    13 HD FatBob
    16 S6 (gone)
    14 S6 (gone)
    14 S6 (gone)
    13 S6 (gone)
    10 S4 (gone)
