Results 1 to 10 of 10
    Established Member Two Rings N'syncro's Avatar
    Feb 04 2010
    FS: Ohlins Stasis Coilovers for C5 allroad (Maybe A6/RS6 as well?) - SOLD
    SOLD!
    Any way for you to confirm these would fit on reg A6's as well?
    Feb 04 2010
    I'll try to find out. I think all the parts are the same, but I have to go down to the Audi dealer soon, so I'll talk with them about it and see what I can find out, and then post here. Stasis instructions are still online here: http://www.stasisengineering.com/sit...tall%20V.2.pdf The only difference that I see are at the top of the fronts, I mine have that rectangular plate that drills into the upper front control arm plate, and the instructions show a round plate bolting into it. If that upper front control arm plate is the same part # for both cars, I think they'll fit.
    EDIT: Apparently Stasis is out of business, so after talking directly to Ohlins, they highly recommended a shop in California called Performance Shock Inc. (PSI) to do the rebuild. I've talked with them, and they told me a typical rebuild (way beyond what Stasis ever did) would be about $225usd+ per corner, so I'll be sucking up that cost, and you'll be getting a much better rebuild.
    Feb 04 2010
    So the upper front control arm plates have different part #'s between the allroad and A6, but I still suspect that all you'd have to do is drill and mount my rectangular mounting plate to the A6 upper front control arm plate. Here's some reference to a guy swapping A6 suspension into his allroad with next to know modifications: http://www.audizine.com/forum/showth...-their-allroad
    If anyone with an A6 wants to take the risk, if they don't fit, i'll refund you your money back if you pay for shipping back to me.
    Feb 04 2010
    Bump
    Is that $3000 or $300?
    Sent from my DROIDX using Tapatalk 2
    Feb 04 2010
    It's $3000.00
    Feb 04 2010
    Bump. Price drop because the USD$ is killing right now and CDN$ is sucking.
    Feb 04 2010
    Bump. I'm about to send these down to PSI for the rebuild
    Apr 02 2010
    San Rafael, CA
    These still available? PM sent.
