Crank and cats [looking directly up into engine bay]:
Dual mass flywheel and front differential with front half shafts visible [amazing engineering to line this up]:
Front control arms with spherical bearings, back of the AP racing calipers, stainless line going into it:
Brakes and eurocode sways:
Transmission. Front 1/4 is flywheel+clutch. Middle 1/2 is 6 forward gears, 1 reverse. Rear 1/4 is the center torsen differential.
Sports rear differential:
Milltek front section, blue from heat. No one makes a system like this for the B8. Best on the market.
Milltek rear section:
Rear subframe mount and rear cast links:
Rear subframe and diff:
Apikol diff mount:
Shifter linkages. The transmission is a good length in front of the shifter in the cabin:
Below the cat you can see the steering linkage poking out from the cabin:
A lonely driveshaft. I'm not sure why it's two pieces.
