Well, I thought I would have a crack at reversing the +/- changing sequence on the Tiptronic shifter as per the previously posted Video in French.
I was amazed at how simple the job was - literally 45 mins from start to finish and it works like a charm.
Whilst I was doing the change, I figured I would take some photos and post a step by step tutorial for anyone interested.
STEP 1: Place shifter into DRIVE. Pull button outwards, but only enough to slip a small zip tie in between the housing and the button. Secure.
STEP 2: Rotate silver sleeve below the knob clockwise. Pull up using CONTROLLED force. Mine popped off quite easily. *Note, the shifter position in DRIVE. This may make a difference to the ease of removal as per the YouTube Video.
STEP 3: Open the ashtray and using two hands lift the shifter display surround upwards. Once the forward lugs are free, gently use a screwdriver to pry the rear ones up.
These are the four lugs and their relative positions.
STEP 4: Gently pry the four tabs securing the shifter housing to the console bracket whilst using a slight upwards force (otherwise they just clip back into position).
STEP 5: Remove the shaft sleeving from the stick.
STEP 6: Remove the plug from the underside of the shifter housing by depressing the tab and pulling.
STEP 7: Once the plug is removed, push the tabs in that are located on the side of the housing lid to remove the silver cover.
STEP 8: Remove silver cover from housing.
Now we work on the Silver Cover
STEP 9: Gently pry the circuit board from the cover, releasing the small retaining tabs.
STEP 10: Separate the black information board from the silver cover. You can gently pry using a small screwdriver or use the friction from your grip.
