I decided that I wanted to go with a hard tube, so the only option on the market is the APR Carbino Stage 2 system (about $200). You can't actually have a hard tube all the way through because it would break off when the engine is shaking under load. So on the throttle body end, it has a ribbed cuff. On the airbox end, it has a silicone tube in the same material other vendors use. A clamp goes on both touch points of the tube so secure it to both the airbox and the carbon fiber tube. It looks a little bit band aid-ish but it should get the job done just fine. Note that the throttle body end is slightly smaller than the airbox end - perhaps 3" down to 2.5" but I didn't measure.
The factory, paper air filter is the original one I got with the car. I replaced that with the cotton filter from the AWE S-FLO system, at a cost of around $60. Once a year (every 7000 miles in my case) I'll get it oiled at my service shop.
The car feels noticeably quicker. I think the REVO tune wanted to rip and couldn't get enough air through the throttle body.
The APR stage 1 piece is perfectly fine, I just want to live inside the letter of the law with California CARB. Any modifications to the airbox are grounds for failing the car or a fine. I'm sort of skirting the edge where someone might think the car came this way, since the old RS4 has a similar-ish engine bay treatment. I fully expect the carbon fiber to change color when it gets hot, just as it does in RS4. I'm OK with that.
I should also note that the shop that installed it is 2Bennett Audi Automotive in Sacramento, CA. They're cool guys and did a really great job. Check out their new shop in a defunct Ford dealership. They restore classic Quattro cars for like $100k, if you are into that type of thing. They also make lots of motorsports parts, like custom rolled springs and custom sourced Brembo caliper and some-other-rotor kits, which are a good value proposition. They sponsor the Audi Golden Gate club and seem to have a good relationship with the members.
