I plan to use the MS8's aux input option (already using it for my phone/iPod) which is working well. I currently have SiriusXM, but am going to cancel that and possibly just use their on-demand service for about the only thing I listen to on it anyway. For streaming music I plan to install Pandora/Slacker/Spotify, and tether the tablet to my phone. However I am also considering picking up a Segate GoFlex wireless drive to use for storing MP3's/movies/podcasts etc to make sure that a) I don't exceed my data plan, and b) for areas with no signal I can still have music. I will likely also pick up a bluetooth OBDII reader and use the Torque app for any monitoring that I might want to do. While I will lose my steering wheel controls, and the radio info on the display, they are both things I can live without. I may even be able to use voice commands for the majority of things anyway.
First thing I plan to do is check to see the size difference between a Kindle Fire and the Nexus, I am fairly certain they are the same size, and since I already have the Kindle Fire I can use that to start test fitting ideas. I can then remove my Symphony II head unit and start trying to figure out a way to mount the tablet. I need to pick up a dash kit from somewhere, Metra, Scosche, I believe Enfig also has one. I want to be able to remove the tablet easily when parked, so need to have some way of opening/closing a bezel, but also have it hold the tablet securely enough that it won't fall out while driving. I most likely will follow something as done by this user S4 Nexus install
I have a couple questions though.... If I remove my stock head unit entirely, is it going to cause me any issues? I am thinking no, but just wanted to be sure. Second, regardless of whether I use the dock or not, I will be using a cigarette lighter charger to keep the tablet charged. Is it easy enough to tap into these wires at the bottom of the center console? I am assuming its just 2 wires. Can I splice 2 sets of wires into this? one for charging the tablet, and the other for the hard drive power/charging?
Hopefully soon I can get started on this and will update with pictures. I have been looking for a new project to work on, and with spring around the corner will be happy spending some time in the garage with something to do!!
Edit: Kindle Fire fits with room to spare...
If you find this thread, and have a DCDC-USB, running in Automotive Mode using the harness from Enfig, connect it this way or you will fry the little box on the harness... White Ignition Wire on DCDC-USB goes to Red Switched 12V, Red Power goes to Yellow Constant 12V/Power and Black ground.
