The symptom you would get is a low oil pressure because the Bearing looses it's geometry, thus loosing it's pressue from an oval bore.
I had the same low oil pressure symptom once the oil got warmed after a couple of runs. So I was like ohh f**K my block is probably cracked too.
So I decide to attach the engine and have a good look farther deep under. Guess what. My block is not cracked at all.
Guess what was causing my low pressure?
I've found this.
The 'o' ring is done. It's from the pipe that comes from pump to the block, at the block.
Cylinder wall looks very good too. Bearings looks like bran new as well.
Long story short. YOU NEED A DECK PLATE UNDER THOSE BLOCKS!!!!!!
We have a couple of good machinist at Cummins Shop. They know there stuff good. They have to deal with v12, v16, v18 diesel blocks that worth between 150000- 300000$ the block alone. So trust me they save almost every thing. Here's a good explaination they told me.
On an inline 6 engine, there's one major force you have to deal with. It's downward force. On a v6 instead, You have at least 3 forces you got to contain; Downward,, and sidewards on each side. Especially when we boost the crap out of them. Remember. Those Audi V6 is not narow at all. So side loads are more exagerated. You just need to think when for example, piston 2 is pushing hard while the opposed cylinder on same crank rod is only exhausting and all that. My deck plate didn't have upward load at all, but at least it prevented the caps from moving sideways.
What I'll do is put put a little bit of load on the deck plate. Maybe .002'' - .003'' to help forcing things upward, but at least i'm protected from side vibrations.
I'll put some more pictures of the progress when I get some time.
