Results 1 to 21 of 21
    Mar 05 2009
    Earth
    2013 B8.5 coding required....please assist
    There are many 2009 to 2012 B8 owners that are attempting various retrofits of 2013 equipment. Coding and Adaptation maps from current 2013 B8 owners would be very helpful to progress these projects.
    If you're a lucky owner of a 2013 A4/Allroad/S4/A5/S5/RS4/RS5 and have access to a VAG-COM cable many of us would really appreciate your current coding details.
    Please include:
    - your model
    - country
    - equipment list...ie. MMI w/ NAV, B&O, single/dual/three zone climate, parking sensors, rear camera etc.
    - full Auto-scan output
    - adaptation maps (info here: http://www.audienthusiasts.com/Artic...tationMap.html)
    The popular and most useful adaptation maps right now would be:
    08 - HVAC
    09 – Cent. Elect
    19 - CAN Gateway
    5F - Information Elec.
    Thanks very much for your help
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by cory_can View Post
    If you're a lucky owner of a 2013 A4/Allroad/S4/A5/S5 and have access to a VAG-COM cable many of us would really appreciate your current coding details.
    Please include:
    - your model
    - country
    08 - HVAC
    09 – Cent. Elect
    19 - CAN Gateway
    Hey cory, going to try as soon as i get the vag-com in....!!!!!!
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Mar 05 2009
    Earth
    Quote Originally Posted by hyperunion View Post
    cool, that would be very helpful.
    Junior Member Two Rings
    Aug 23 2012
    I have a 2013 A4. Had the coding done via vag-com with no problems.
    Mar 05 2009
    Earth
    The question isn't if you can code your car using VcDS, I'm asking if you can please share your current coding and adaptation maps for others to see. They help with retrofitting new equipment and settings.
    Mar 05 2009
    Earth
    Bump. I'm sure someone with a 2013 has a VagCom cable. This is how the useful settings that many use get discovered and tested. Please share your current coding.
    Senior Member Three Rings drdrewusaf's Avatar
    May 31 2012
    San Antonio Texas
    2013 S5 Prestige, US Spec. Only option added was the sport differential. The soundaktor fuse has been pulled, thus the CAN malfunction. The adaptation map is quite the process, not sure if I'll be able to do it any time soon...
    Tuesday,20,November,2012,20:10:03:09117
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Chassis Type: 8R0
    Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53
    56 5F 6C A9
    VIN: WAUVGAFR######### Mileage: 4850km/3013miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CGXC) Labels: None
    Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
    Component: 3.0l V6 TFSIH07 0002
    Revision: --H07---
    Coding: 1A250034052600060000
    Shop #: WSC 06192 000 00000
    ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
    ROD: N/A
    VCID: 387F967B837016D8D95
    No ASAM data for: "EV_ECM30TFS0218K5907551E" (AU48)
    No fault code found.
    Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
    Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
    Component: 0B5 30TFSINAR H01 0004
    Revision: --H01---
    Coding: 000001
    ASAM Dataset: EV_TCMDL501021 001010
    ROD: EV_TCMDL501021_AU48.rod
    VCID: 408FFE9BDBA05E18615
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
    Component: ESP8 quattro H09 0100
    Revision: -------- Serial number: --------------
    Coding: 291D1A
    VCID: 8407B28B0738023885D
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
    Component: BCM2 2.0 H11 0621
    Revision: 00002001
    Coding: 0D804000000000000000
    Shop #: WSC 06325 000 00000
    VCID: 8109BB9F182A1710AEB
    Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
    Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
    Component: MEM-BFS H10 0076
    Revision: AA000000 Serial number: 00000033369482
    Coding: 00037025002C00000000
    VCID: 4581EF8FCC827B30523
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
    Component: KLIMA 3 ZONEN H04 0121
    Revision: C1000000 Serial number: 01270620121143
    Coding: 6602228000
    Shop #: WSC 06342 000 00000
    VCID: 3979937FB07A0FD026B
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
    Component: BCM1 1.0 H16 0103
    Revision: 09016001 Serial number: 00000439050502
    Coding: 26000011863CAFE0210048C300003D0D0F9CD388A209022100 0008004000010200020030000000
    VCID: 7AFB4C73F5FCC4C86F1
    Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 260612 H15 0080
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
    Component: G397_RLFS H06 0002
    Coding: 02005D
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
    Component: USHL4.2 H30 0030
    Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
    H01 0031
    Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
    H01 0031
    Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
    Component: AirbagVW-AU10 H45 0610
    Serial number: 003KJD90DF8E
    Coding: 303343334830303030304A55304C38543053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 4A9BDCB3ED9C9448BF1
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
    Component: BF-Gewichtss. H02 0060
    Serial number: 5810000R1200009FGS
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME665027032
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME6F623215E
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME1E19245AN
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME36182B5CQ
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME751B0240T
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME6C1A17723
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
    Component: Lenks.Modul H07 0171
    Revision: 00000000 Serial number: 20120702000637
    Coding: 000036
    VCID: 51A9CBDF08CAA790FEB
    Component: E221 - MFL H03 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 983 P HW: 8T0 920 983 P
    Component: KOMBIINSTR. H35 0553
    Revision: 00000000 Serial number: RAU55DU6D
    Coding: 8BB701008B01D705020000
    VCID: 4B95D9B7EAE68D40847
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8R0 907 468 J HW: 8R0 907 468 D
    Component: GW-BEM 5CAN-M H11 0051
    Revision: 1Z090025 Serial number: 2541Z126040105
    Coding: 80C303FF00
    VCID: 4683E883F18470285B9
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    1 Fault Found:
    03619 - Control Module for Structural Accoustics
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 118
    Mileage: 2430 km
    Time Indication: 0
    Date: 2012.10.18
    Time: 11:23:00
    Freeze Frame:
    Bin. Bits: 11011
    Voltage: 10.80 V
    Count: 6
    Bin. Bits: 10000
    Time: 0.00 s
    Address 22: AWD (J492) Labels: 8K0-907-163.clb
    Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
    Component: 4 Wheel Drive H13 0100
    Serial number: 002006120001004
    ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
    ROD: EV_AllWheelDiffeQSPCAN.rod
    VCID: 2F6DAD27763ED16088F
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Component: MEM-FS H10 0076
    Revision: AA000000 Serial number: 00000032959657
    Coding: 001B7B25002C00000000
    Address 3C: Lane Change (J769) Labels: None
    Part No SW: 8T0 907 566 A HW: 8T0 907 566
    Component: SWA Master H17 0040
    Serial number: 0178940312
    Coding: 010211
    ASAM Dataset: EV_LaneChangAssis 001020
    ROD: EV_LaneChangAssis.rod
    VCID: 3E738063A15428E8139
    Lane Change Assistant 2:
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
    Component: TSG FA H09 0304
    Coding: 011C13224E00120102
    VCID: 56A338C32124C0A82B9
    Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
    Part No SW: 8K0 909 144 D HW: 8K0 909 144 B
    Component: RCEPS H36 0505
    Revision: 00001000 Serial number: 0020668977
    Coding: 100000010001
    ASAM Dataset: EV_RCEPSAU48X 005010
    ROD: EV_RCEPSAU48X.rod
    VCID: 326BA453650CFC88E71
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0179147048
    Coding: 0106029A00FA400580B0003200000000
    Shop #: WSC 06324 000 00000
    Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
    Component: GTO BF H01 0080
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J245EE20SKB13 H03 0220
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
    Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
    Component: DSP Prem H05 0030
    Revision: 00005001 Serial number: 94813004244702
    VCID: 2D51B72F7432A370BA3
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
    Component: TSG BF H09 0304
    VCID: 55A13FCF3C22CBB0223
    Address 53: Parking Brake (----) Labels: None
    Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
    Component: EPB-4 H01 0003
    Revision: -------- Serial number: 20000000109206
    ASAM Dataset: EV_ParkiBrake 001027
    ROD: EV_ParkiBrake.rod
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 082 D HW: 4G0 035 082
    Component: Radio U SIRIU H60 0112
    Revision: AB001007 Serial number: 156F10C7609880
    Coding: 020007010000000001
    VCID: 21495B1F38EA77100EB
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8R1 035 746 B HW: 8R1 035 746 B
    Component: H-BNT-NA H43 0552
    Revision: -------- Serial number: 204G-0C7503992
    Coding: 140200020206A1EF75028B4E00000403140000000100000000
    VCID: 366398438164E0A8CB9
    Subsystem 1 - Part No SW: 8R0 919 604 HW: 8R0 919 604
    Component: DU7 High H41 0104
    Subsystem 2 - Part No SW: 8T0 919 611 C HW: 8T0 919 611 C
    Component: E0380 Bedient H02 0020
    Subsystem 3 - Part No: 8R0 060 961 D
    Component: CD-Database 4353
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
    Component: J772__Rearview 0040
    Revision: --H07--- Serial number: 525PA8-J24949M
    Coding: 1000008
    VCID: 387F967B4B7016D8D95
    Address A9: Struct. Borne Sound
    Cannot be reached
    End ---------------------------------------------------------------------
    Mar 05 2009
    Earth
    Quote Originally Posted by drdrewusaf View Post
    Thanks for your help
    Mar 14 2013
    Tokyo, Japan
    2013 A5 2.0t (Japan Specs) / standard: electric seats, MMI+ HD, rain/light sensor, keyless entry, foldable/heated mirrors, xenon lamps, start-stop system / options added: tilting sunroof, rearview camera.
    Note: the DRL as of now are not/cannot be activated (coding is rejected for [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2 -> Bit 4)
    Monday,04,March,2013,20:00:54:49966
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 8R0
    Scan: 01 02 03 05 06 08 09 15 16 17 19 36 42 44 46 52 53 56 57 5F
    6C
    VIN: WAUZZZ8T0DAxxxxxx Mileage: 350km/217miles
    57-TV Tuner -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (Japan-CDNC) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K5 907 115 H HW: 8K2 907 115 L
    Component: 2.0l R4/4V TF H09 0002
    Revision: ECH09---
    Coding: 1A250013242601022000
    Shop #: WSC 06208 000 00000
    ASAM Dataset: EV_ECM20TFS0118K5907115H 001004
    ROD: EV_ECM20TFS0118K5907115H.rod
    VCID: 377DFC158E8EAAA0D06
    Readiness: 0000 0000
    Part No SW: 8K2 927 156 G HW: 0B5 927 156 J
    Component: 0B5 20TFSIRdW H01 0003
    Revision: --H01---
    Coding: 000001
    VCID: 3A7BE521BD9CB7C82F8
    Coding: 09554C
    VCID: 8407DBD907D8B138854
    Revision: 00002001
    Coding: 05B04040000000000000
    VCID: 8109D2CD18CAA410AE2
    Revision: AA000000 Serial number: 00000044109420
    Coding: 09237025002400001000
    VCID: 458186DDCC62C83052A
    Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
    Revision: D1000000 Serial number: 01071120120105
    Coding: 642662C000
    VCID: 3A7BE521B59CB7C82F8
    Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
    Revision: 08016001 Serial number: 00000518093902
    Coding: 260000008030AFC00001400300001D0D0F1D43882709020100 0008004001030100000034000000
    VCID: 78FF3F29CB1065D819C
    Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 201112 H13 0080
    Coding: 00FD11
    Coding: 02005D
    Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
    Serial number: 003KFD96VTUR
    Coding: 30533933363030303030554A305238543053
    VCID: 489F8FE9F370D558A9C
    Serial number: 6334MSME7322144EA
    Serial number: 6344MSME72012E4DH
    Serial number: 6352QSME59223C62I
    Serial number: 6362QSME28275174E
    Serial number: 63732SME3F233348/
    Serial number: 63832SME48232756.
    Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
    Component: Lenks.Modul H02 0171
    Revision: 00000000 Serial number: 20121122000433
    Coding: 000036
    VCID: 4FADA4F51E1E0260E86
    Component: E221 - MFL H03 0004
    Part No SW: 8T0 920 931 T HW: 8T0 920 931 T
    Component: KOMBIINSTR. H35 0556
    Revision: 00000000 Serial number: UUS6ANGCD
    Coding: 33A701000201000C0F0000
    VCID: 489F8FE9FB70D558A9C
    Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
    Component: GW-BEM 4CAN-M H11 0055
    Revision: 1Y060027 Serial number: 2741Y12B090086
    Coding: 80CF07FF00
    VCID: 4A9BB5E1E57C2748BF8
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    1 Fault Found:
    00384 - Optical Databus
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 19 km
    Time Indication: 0
    Date: 2013.02.21
    Time: 14:28:17
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 12.10 V
    Count: 11
    Bin. Bits: 00000
    Revision: AA000000 Serial number: 00000044119095
    Coding: 011C12225C01120102
    VCID: 56A3519121C473A82B0
    Part No SW: 8K0 909 144 E HW: 8K0 909 144 B
    Component: RCEPS H37 0506
    Revision: 00001000 Serial number: 0010042442
    Coding: 100000000001
    ASAM Dataset: EV_RCEPSAU48X 006012
    VCID: 3365C8059AF64680ECE
    Revision: 00002001 Serial number: 0187825589
    Coding: 01000E8000B90085813000368000000F
    Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J245EE20SKB13 H04 0220
    Coding: 011C12225E01120102
    VCID: 55A1569D3CC278B022A
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Revision: -------- Serial number: 20000000183448
    VCID: 387FFF298390A5D8D9C
    Part No SW: 4G0 035 083 HW: 4G0 035 083
    Component: Radio U JP H50 0055
    Revision: AB001007
    VCID: DEB3C9B1C9F43BE8F30
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 57: TV Tuner (R78) Labels: None
    Part No SW: 4G1 919 129 A HW: 4G1 919 129
    Component: NGTV-JP H03 0390
    Revision: R0030000 Serial number: 07000700283101
    Coding: 10000000
    VCID: 2C57D3794FC81978AD4
    1 Fault Found:
    02261 - Data Medium
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 42
    Mileage: 6 km
    Time Indication: 0
    Date: 2012.12.06
    Time: 22:45:11
    Part No SW: 8R2 035 678 B HW: 8R2 035 678
    Component: H-BN-JP H18 0271
    Revision: -------- Serial number: K5FAN15ZAJ48Q
    Coding: 13060102000681EF41808B4E00000403FC0000020000000000
    VCID: 3B75E025BAA68EC034E
    Subsystem 1 - Part No: 8R0 060 884 AQ
    Component: JPN-08.08.12. 7614
    Subsystem 2 - Part No SW: 4F0 035 503 E HW: 4F0 035 503 E
    Component: ETC-VICS-Ant. H04 0020
    Subsystem 3 - Part No SW: 4F0 919 813 E HW: 4F0 919 813 E
    Component: Card reader H03 0110
    Subsystem 4 - Part No SW: 8R0 919 604 HW: 8R0 919 604
    Subsystem 5 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
    Component: E0380 Bedient H02 0030
    Subsystem 6 - Part No: 8R0 060 961 E
    Component: CD-Database 4949
    1 Fault Found:
    02067 - Optical Databus; Unpermitted Wake-Up Request
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 19 km
    Time Indication: 0
    Date: 2013.02.21
    Time: 14:26:12
    Freeze Frame:
    Voltage: 12.10 V
    Revision: --H07--- Serial number: 525PA8-J2894SS
    Coding: 1020008
    VCID: 387FFF294B90A5D8D9C
    Forum Moderator Four Rings DirtD1ver's Avatar
    Feb 20 2013
    2017 Allroad, 2020 Q7
    MD
    2013 Allroad Prestige sport package, MMI /w NAV, rear camera, parking sensors, B&O sound, Dual zone climate control
    this coding does have some VAGCOM mods like needle sweep, disable "winking", and a couple others.
    here is a link to download the adaptation map for 09 - Cent. Elect http://sharesend.com/tr2u896q
    I am still working on the other ones.
    __________________________________________________ __________________________________________________ ___
    Sunday,17,March,2013,20:01:01:32694
    VCDS Version: Beta 12.10.3
    Data version: 20130228
    Chassis Type: 8R0
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
    62 6C 6D 72
    VIN: WA1VFBFLXXXXXXXXX Mileage: 3000km/1864miles
    19-CAN Gateway -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (DET-CPMA) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
    Component: 2.0l R4/4V TF H09 0005
    Revision: ECH09---
    Coding: 722A0013242600062000
    ASAM Dataset: EV_ECM20TFS0118K5907115F 001006
    ROD: EV_ECM20TFS0118K5907115F.rod
    VCID: 356B623D943EC0B66C3
    Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
    Part No SW: 8K1 927 158 HW: 0BK 927 156 AL
    Component: 0BK 20TFSIUSA H16 1003
    Revision: --H16---
    Coding: 000002
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMAL551211 002020
    ROD: EV_TCMAL551211_AU48.rod
    VCID: F4ED1F395FC419BE1BD
    Part No SW: 8K9 907 379 M HW: 8K9 907 379 M
    Coding: 0E1D18
    Shop #: WSC 06335 000 00000
    VCID: 4C9D27D9EFB4A17E23D
    Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
    Component: BCM2 2.0 H12 0633
    Revision: 00002001
    Coding: 0D824000000000000000
    VCID: 840D4FF90764293E2BD
    Revision: C1000000 Serial number: 01121220120804
    Coding: 6480208000
    VCID: 39736E0DB02624D688B
    Revision: 09016001 Serial number: 00000524575801
    Coding: 26000015813CAFC00000480300003D0D0F1C4708A209022100 0008004000010200040030000000
    Shop #: WSC 06335 123 12345
    VCID: 7AF1B101F5A0EFCEC11
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 121212 H07 0080
    Coding: 00FD11
    Coding: 02005D
    H01 0031
    H01 0031
    Part No SW: 8K0 959 655 M HW: 8K0 959 655 M
    Component: AirbagVW-AU10 H46 0610
    Serial number: 003KEDA04SPV
    Coding: 303942354A32303030304A55304C384B3053
    VCID: 479718F5FED242260EF
    Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
    Component: BF-Gewichtss. H02 0040
    Serial number: 5810000R120000B1G6
    Serial number: 6334MSME73246A7CO
    Serial number: 6344MSME732433163
    Serial number: 6352QSME6B264474L
    Serial number: 6362QSME012341661
    Serial number: 63732SME06282F44/
    Serial number: 63832SME0E284F78F
    Revision: 00000000 Serial number: 20121211000981
    Coding: 000037
    VCID: 4FA730D51EA29A6646F
    Part No SW: 8K0 920 982 D HW: 8K0 920 982 D
    Revision: 00100000 Serial number: UVN54VCDD
    Coding: 8BB729020B01D705020000
    VCID: 356B623D9C3EC0B66C3
    Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
    Component: GW-BEM 5CAN-M H11 0055
    Revision: 1Z100027 Serial number: 2741Z12B190175
    Coding: 80C303FF00
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0076
    Revision: AA000000 Serial number: 00000045698816
    Coding: 00581B00000000000000
    VCID: 3B7F7405BA1A16C69A7
    Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
    Component: SWA Master H04 0060
    Serial number: 0188712472
    Coding: 010211
    Shop #: WSC 06334 000 00000
    ROD: EV_LaneChangAssis_AU37.rod
    VCID: 3F870015A6020AE6B6F
    Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
    Component: TSG FA H02 0506
    Revision: Serial number: 0000046877739
    Coding: 011C13205E00410001
    Revision: 00001000 Serial number: 0025089060
    VCID: 336F5C259A4ADE86427
    Revision: 00002001 Serial number: 0300012047
    Coding: 0126063A20BA709583B0023200000000
    Shop #: WSC 06334 123 12345
    Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J245 PS150 H08 0043
    Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J394 PS240 H08 0043
    Revision: 00005001 Serial number: 94813008805602
    VCID: 2D5B4A5D746E8876143
    Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
    Component: TSG BF H02 0506
    Revision: Serial number: 0000046916891
    VCID: 4E992DD119A8936E4D9
    Revision: -------- Serial number: 10000000140444
    ROD: EV_ParkiBrake_AU48.rod
    VCID: 38756B09832C3DDE775
    Part No SW: 4G0 035 082 E HW: 4G0 035 082
    Component: Radio U SIRIU H60 0121
    Revision: AB001007 Serial number: 156L+0C7676012
    VCID: 2241A9613DB0470EB91
    Part No SW: 8R1 035 746 C HW: 8R1 035 746 B
    Component: H-BNT-NA H44 0624
    Revision: -------- Serial number: 204L/0C7549261
    Coding: 010200050006A1EF51028B4E00000403140000000000000000
    VCID: 37776835863232A67EF
    Subsystem 1 - Part No: 8R0 060 884 BA
    Component: NAR 2013 0703
    Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
    Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
    Subsystem 4 - Part No: 8R0 060 961 E
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
    Component: TSG HL H01 0506
    Revision: Serial number: 0000046207896
    Coding: 010C13204000210001
    VCID: 468915F1F1D85B2EF59
    Revision: --H07--- Serial number: 525PA8-J2X90Q6
    Coding: 1000007
    VCID: 38756B094B2C3DDE775
    Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
    Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
    Component: J605 Master H52 0330
    Revision: -------- Serial number: 8K9827851A
    VCID: 3C7D7719BF1411FE93D
    Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
    Component: J756 Slave H52 0330
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H01 0506
    Revision: Serial number: 0000046011644
    Established Member Two Rings olliocity's Avatar
    Jun 17 2013
    Glasgow, United Kingdom
    Hi Cory, did you ever get this to work? I am in the middle of retrofitting 3g mmi to my b8 and one of the annoying things is that the climate control used to come up on the old display. I have an 8.5 climate control panel with protection removed and it works with the new mmi screen just fine. However the long coding seems to be miles out, the fan blower won't change, the a.c. button seems to operate the front demister, the front demister button seems to do nothing, the rear demister works, the recirculation seems to work. Iv tried the coding you are using but it only seems to make it worse, any help you can give?
    Marc
    Mar 05 2009
    Earth
    Quote Originally Posted by olliocity View Post
    Marc
    Sorry Marc, I gave up on the B8.5 climate retrofit.....I played with the coding for quite awhile and had to eventually throw in the towel. Mine (mis)behaved exactly like yours. There is coding to get the overlays to work on the 3Gplus MMI but I don't have it immediately handy. BTW, I replaced my 09 climate module (2G) to a '11 climate module (3G). However, I discovered the above coding after the fact and in the end I'm not quite sure if the hardware swap was actually required for the overlays.
    Jun 17 2013
    If the overlays work with the 2g climate control with coding I will gladly put the 2g unit back in, the white display is nice on the 3g unit but never worth all that trouble. If you know where i can get the long coding for the overlays or could post it up later id be extremely grateful. Iv tried a few different coding combos on the new climate controls too, its no wonder you gave up.
    Mar 05 2009
    Earth
    Try Module 17 (instruments) - Byte 1, Bit 6....should be 0.....and I also seem to remember the description in my label file was incorrect....said something completely backwards about 3GMMI being installed/not installed.
    Jun 17 2013
    Hi cory, I had to remove component protection. Again to put the old climatic back on, I tried coding like you said and all it seemed to do was turn my speedometer off. Any other clue as to what other coding I could try changing?
    Mar 05 2009
    Earth
    I checked back and I'm fairly certain that was the coding that did the trick for me.
    Jun 17 2013
    Can I just check with you, I'm using autologics vag tool and not vag com, does your byte count start at 0 or does it start at 1? And does your bit count start at 0 or 1 just incase I'm coding in the wrong place.
    Mar 05 2009
    Earth
    Both start at 0...for instance, needle sweep is byte 1, bit 0
    Jun 17 2013
    So I did change the right bit of code, maybe the climatronics coding needs changed? Could I ask a big favour, could you post up your clumatronic coding and what your car has climate control wise?
    Mar 05 2009
    Earth
    I'll get you the details later today but the coding of my climate control didn't change when I swapped from my original 09 (2G) climate module to the newer module.
    Nov 05 2009
    '09 B8 A4 2.0t quattro '15 Q5 3.0T
    Chicago, IL
    Did either of you guys try Address 08: Byte 01, Bit 4 (air-conditioning setting in MMI)? It's noted in the Kufatec manual that comes with their 3g high MMI retrofit cable set. (I just finished the HW portion of the retrofit. Fingers crossed for the component protection and coding portion outstanding).
