Results 1 to 16 of 16
    Veteran Member Three Rings motionneon's Avatar
    Feb 09 2011
    Honda Odyssey Turbo S
    St. Petersburg, Florida
    H&R vs Eurocode Sway
    I tried searching but couldn't find....
    I seem to remember reading as post from someone who was able to directly compare H&R rear sway vs Eurocode sway system. Does anyone have 1st hand experience with both of these systems installed on same car? I.e changed from H&R to Eurocode? If so, any substantial difference?
    Thanks in advance,
    2011 S4 DSG
    Phantom Black, Black and Magma interior, RS4 Grill, 30% tint all around
    STASIS v1.0 ECU, Strat intake, Milltek non-res exhaust, Deval Rear Valence
    19" Peelers, Michelin Pilot Super Sport A/S
    Feb 09 2011
    Quote Originally Posted by 13S4 View Post
    Thanks, anyone else?
    2011 S4 DSG
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    I think Phil@detailersdomain made that exact switch on his build thread.
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Apr 04 2012
    MSP
    HR only has a rear sway. Eurocode has front and rear.
    I would highly doubt there would be any noticable difference between the HR and Eurocode REAR sways if you were able to compare just the two. Both are going to be a good upgrade from stock. The HR is 24mm non adjustable and will cost you 200 bucks. The Eurocode is 25.5mm and IS adjustable. I don't konw that you can buy only the rear from Eurocode though so it will set you back 550 bucks... So either go with HR if you only want rear. If you want front as well go with Eurocode. I'm not sure that the front sway is necessary especially if you are going with the Alu Kreuz. Going only with the rear will help more against understear and give the rear a little more wiggle than going with front as well...
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    It's a combination of the end links with the sway bars. I'm sure if someone switched my rear bar with the H&R bar (keeping the end links on) I personally wouldn't be able the tell the difference. If you are comparing the full USS system with the H&R rear sway they would be completely different. Spending $1000 on sway bars and end links is definitely not something I would have ever considered, but after reading all of the reviews I decided to try it out. Would I do it again? Definitely.
    Senior Member Three Rings BlueByU's Avatar
    Oct 05 2008
    RS4
    Minnesnowta
    Hotchkis FTW!
    B7 RS4
    Feb 09 2011
    Thanks for your thoughts. I was thinking about purchasing just an H&R rear sway and a set of end links. What do you think about that combo?
    2011 S4 DSG
    May 03 2012
    NA
    Compared to the professionals on this site my thoughts are rather meaningless. I am an engineer and realize that a lot of effort went into the overall design of the car, but the stock end links are garbage. Everyone knows that plastic does not direct nor resist force anywhere close to that of titanium. I'm sure the H&R bar is okay alone, but with the end links it would be that much better.
    Stage 3 Forum Advertiser Four Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    A full set of H&R sway bars (front and rear) retail for $628.00 ($329.00 front and $299.00 rear). We sell our bars for $549 for the set or $279.00 each if purchased ala carte. Our bars also include $48.00 woth of OEM hardware that MUST be replaced each and every time you remove it from the vehicle.
    Of course price is not the only comparison, our rear bar measures 26mm compared to H&R's 24mm and has two adjustment settings (the only rear bar for the B8 that does), our front bar measures 32mm conpared to H&R's 24mm and has two adjustment settings (as well as H&R's) more than size and pricing sets us apart.
    We spent quite abit of time and many product revisions in the quest for what we feel is the perfect balance of handling and drivability. The reviews on our product speak volumes on how it performs. If you have any futher questions please feel free to PM us and we will glasdly answer or you can always give us a call at 310-294-8108.
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
    Apr 04 2012
    MSP
    Quote Originally Posted by motionneon View Post
    That combo would be good...
    Mar 26 2010
    US
    I have the Hotchkis F/R sway bars (already had them on the car), the Eurocode endlinks & Alu Kreuz. It is better than stock for sure.
    BMW M3 Competition X-drive
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    Quote Originally Posted by Info@EuroCode View Post
    Are you guys running any specials at this time, especially on your endlinks?
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Sep 13 2010
    Charlotte, NC
    Who has the rear endlinks? Any improvement there?
    Dec 24 2008
    Torrance
    The majority of our sales are for the entire USS system to include front and rear endlinks. The endlinks are a major improvement over the factory pieces which are made up of ABS plastic and have rubber bushings inside.
    The bushings on the OEM links are pressed into the plastic housing and they do not rotate. This keeps them from articulating when the suspension raises and/or lowers (as in typical driving). We have seen the factory links show pre-mature signs of aging after a few thousand miles.
    Another advantage of the USS link is that with the sealed, spherical bearing the transfer of energy is much more precise and predictable than the rubber bushing found in the OEM end links.
    Torrance, CA 90501
    310-294-8108
    Oct 20 2008
    Just curious, what is the endlinks and the sways made of? How do they hold up against Canadian winter and salty roads?
    "I know it won't create actual downforce at 125 MPH. I know it does make the S4 more stable." - westwest888
    "It doesn't say anywhere in the rule book that a dog can't drive autocross" - westwest888
    "It would be easier if we just accepted my OP as fact in the Audizine sticky wiki. " -westwest888
