Results 1 to 11 of 11
    Nov 21 2010
    WA
    Help with engine noise / 17755
    I was driving the audi home from work one day and noticed that the engine sounded like a diesel. Appears to be misfiring from the three cylinders on driver side of the engine.
    Vagcom is showing the following code:
    17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
    P1347 - 35-00 - Incor. Correl.
    We pressure tested the cylinders and saw that the cylinders on the bad side were ~70-90psi and the cylinders on the good side were ~120psi.
    We also replaced the G163 sensor on both sides without any change in results.
    Video: https://plus.google.com/100727269628...ts/VNRA1N7nuD7
    Does anyone know if this sounds like a cam tensioner or something else?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    That sounds like heavy lifter tapping or a cam tensioner. I had a lifter collapse on me, not fun
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Oh dear, check you timing belt. Correlation code is no bueno. Hate to say it, but Im guessing you have some bent valves.
    Nov 21 2010
    WA
    Quote Originally Posted by zillarob View Post
    I was hoping that wouldn't be the case... Any ideas why the timing belt would only affect one side of the engine and not stop the car from running (catastrophic failure)?
    Nov 16 2010
    WetSide, WA
    tbelt can skip on any or all of the 3 pulleys that matter, depends on what causes it to skip. If the cam sensor is out just a little bit you will get an implausible code, correlation means it is not even in the neighborhood. My guess would be b2 skipped a few teeth and the center intakes are tweaked. Our valves are easy to bend (better than breaking off) so the motor keeps spinning.
    Quickest way to check is pop the tbelt covers off and eyeball where the cam bar goes or just pop the valve covers off and see if the notches on the cams line up at the same time. Going to be in there soon anyway.
    Nov 21 2010
    WA
    Ah, thanks for the insight :)
    Nov 21 2010
    WA
    Darn... took it apart and saw this:
    That's the bolt holding the timing belt tensioner :/ All the plastic covers were ripped by the timing belt. I wonder how the car didn't just explode before I got home ><
    Established Member Two Rings CrazyRobCustoms's Avatar
    Feb 02 2009
    00 S4 Noggy, 2008 F150 SuperCrew
    Nh
    ^ Gooooo. over stretched/ tightened bolt you got there..That sucks.
    Audi Expert level Certified
    A8L technicial Specialist
    I fixem demGerman cars Real Good Man
    Nov 21 2010
    WA
    It was tightened to spec using a torque wrench :/
    Dec 05 2009
    New York
    Quote Originally Posted by olegsomphane View Post
    Damn.. How did you tension the belt?
    Feb 02 2009
    Nh
    Yeah but it a single use stretch bolt. Nobody replaces them. Prob been loosened then tq more than once.
