Page 3 of 3 FirstFirst 123
Results 81 to 83 of 83
  1. #81
    Oct 08 2013
    South Africa
    Guys i had the same problem mine started after the cambelt broke on 150 000Km/93000Ml so i had to get new valves and redo the Cylinder head
    no one was able to find the problem and i drove it like that until last week let me tell you what went wrong on 220 000Km/136700Ml
    that same noise started while i was on the highway doing 80Mph/130Km/h and didn`t stop at all, took it to the dealer and turns out that noise was coming from the CCT that was faulty so they replaced the CCT when i collected the car from the dealer the oil pressure light came on long story short its still not fixed seems to be the shims on the head is faulty or the oil pump. the dealer also told me the cct works on oil pressure and that the it went faulty because of the low oil pressure to find this out so far cost me about $2000. at this moment they are still working on my car will give feedback when its all sorted out shouldn`t be too long
  2. #82
    Oct 08 2013
    South Africa
    Good News guys mine is sorted now problem was oil pressure to the cct wasn`t enough due to a blocked pick up in the sump replace pick up and oil pump $120 car is much better now
    Hope it works for you all
  3. #83
    Senior Member Three Rings blownb6's Avatar
    Apr 08 2012
    Ontario
    ^^^ most likely the problem was originally in the oil pump , i know vw 1.8ts have a ball that is spring loaded , when you turn the car off it blocks the oil from coming back down into the oil pan , if that is not working properly you will get cold start up noise because all the oil is in the pan
    this is vw AWM engine .. should be same as the AMB
