Results 1 to 26 of 26
    Registered Member Two Rings
    Feb 02 2011
    CHICAGO IL
    RPM FLUCTUATION -So common there's a TSB on it
    I know there's several posts about this. This TSB came out on 2-3-2012. I have this problem on my car and I'll be changing my trans fluid AND FILTER ASAP. Notice how the TSB does't mention changing the filter.
    Technical Service Bulletin Transaction No.: 0
    32 Shudder or RPM fluctuations while at cruising speed Release date: Feb 3, 2012
    Condition
    Customer may report shudder or RPM fluctuation while at cruising speed in 4th, 5th, or 6th gear.
    Technical Background
    Torque convertor clutches may have excess slippage while cruising.
    Production Solution
    Not applicable.
    Service
    1.
    Check and verify that the software is at the highest level using TSB 2028053, 37 TCM software update for downshift concerns or 2028279, 37 Shift concerns when slowing vehicle. Also, check that the fluid level and condition is clean, full, and matches the required color per the applicable TSB.
    Tip: If needed, update the software of the transmission and change the fluid before proceeding with this TSB.
    2.
    Test drive the vehicle to verify the concern is present.
    If the concern can be duplicated, verify there are no fault codes stored for misfires and watch the Measure Value Blocks in the ECM to verify no misfires are seen when the condition is present.
    3.
    Check MVB 7 from the TCM. Verify Field 3 is reading control and record the slip count from Field 4 while the concern is present. The slippage of the TCC should not exceed 120 RPM in MVB 7 field 4 while the convertor is in control mode. The RPM surge should coincide with TCC slippage. If this reads higher than 120 RPM, the torque convertor should be replaced.
    Tip: The TCC slippage will vary when in open TCC mode and should read 0 when in closed TCC mode, this is normal. Replace the convertor for high slippage when the TCC is in control mode (above 120 RPM) or for any slippage when in closed mode (MVB 7 field 4).
    Tip: It is not necessary to receive a Repair Authorization to perform this TSB.
    2007 Audi A4 Sedan 2.0T S-Line
    Podi Boost and VEI Vaentine One remote display
    APR Stage 1
    Active Member Four Rings wildcat333's Avatar
    Feb 25 2011
    2009 Suzuki GS500F
    Seacoast NH
    Interesting. See my original thread about this (almost a year old, woot!)... http://www.audizine.com/forum/showth...-at-low-speeds
    2008 Audi A4 2.0T | S-Line | Quattro | Automatic-Tiptronic | GIAC 93 | 35% Tint | KW V1 Coilovers | Evolution Thor Skid Plate | 6000K Bi-Xenons (DDM) | Clear-Corner Mod | Clear Sidemarkers | Hoen Endurance Fogs | LED DRL's + 6OHM/50W Resistors (Krauto Parts c/o Emil) | 6000K LED City Lights + 25OHM/25W Resistors (V-LEDS)
    *Pics of my car/ projects/ installs*
    Active Member Three Rings yungcotter's Avatar
    Jun 09 2010
    queens New York
    I hope this turns into a recall/extended warranty as im just out of my CPO.
    06 A4 2.0T, Quartz Gray, Quattro Tiptronic.
    APR Stage 2,RS4 Rear Sway bar, Carbonio Intake, Smoked tails,
    Hawk HPC ceramic pads, Zimmerman cross drilled Rotors, Tyrolsport rigid caliper sliders AWE Exhaust
    S-Line Trunk, Podi Boost gauge, Hard wired Passport 9500ix, HiD Projector Retrofit
    -Theo
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    Quote Originally Posted by yungcotter View Post
    Holy shit this makes me happy. And I agree, being out of CPO myself, if this ever becomes a Recall/Extended Warranty item I'll be ecstatic!
    Would this TSB mean I can take my car to the dealer and they would perform this service for free? Or would I still have to pay...
    The fact that this is a TSB means its one step closer to being a recall.
    -CP
    2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
    Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
    Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
    2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    Active Member Four Rings Inked's Avatar
    Dec 11 2010
    Polaris Outlaw 525 Quad
    Central FL
    Nice I will call my dealer next week when I go on vacation
    Senior Member Two Rings Flexcj5's Avatar
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    TSB just means its a known occurance. You'll still pay full price to get it fixed if there's even a fix for it.
    If we're lucky, the TSB will eventually become a recall on the TC which is our actual issue.
    Sent from my DROID BIONIC using Tapatalk
    Silver 05 2.0t B7 APR stage 2+ w/ RAI DP & Stasis exhaust.
    Debadged and tinted on Eibach/Koni FSDs rolling on Euromesh 3's (245/35 R19 et33)
    Palmetto State Defense
    YouTube PSD
    http://www.jamesfirearm.com
    Active Member Two Rings redcon1's Avatar
    Oct 22 2009
    '99.5 GTI VR6
    South Central PA
    Hell yes! At least this TSB is the first step by AOA to acknowlege the problem... Now they need to sack up and issue a TC recall.
    Dave
    2008 A4 Avant S-line/TI
    1999.5 GTI VR6
    Senior Member Four Rings
    Sep 02 2008
    NoVA
    Same, mine has done this since day 1 of me owning the car as well. It's never gotten any worse, and only happens for the first 5 minutes when cold. But, if I can get it fixed ultimately free, then I will be happy.
    2006 A4 Arctic White Avant
    Active Member Three Rings jmarch1122's Avatar
    Mar 13 2011
    MA, USA
    Why is this allegedly happening only at cruising speeds in higher gears?
    Mauritius Blue 2.0T quattro
    GT3071R, AutoSpeed Tuned, VAST S3 Clutch w/ LWFW, HPFP.com S2, RS4 injectors, V-Flow intake, Hallman MBC, DO's W/M, Forge 008, KW V3, H&R Sway Bars, Neuspeed, AWE, JHM
    DTM front, Deval rear and sides, JL HD750/1, JL 10w7
    Active Member Two Rings multiphrenic's Avatar
    May 15 2010
    toronto, ontario
    Just noticed this today. Surging between 1800-2000 rpm in 4th gear. Still covered under CPO too...wonder if the TSB has made it through Audi Canada yet.
    2007 A4 2.0TQ - Debadged | APR Stage I | LED Interior | RNS-E 2010 Retrofit
    Senior Member Three Rings XCELR8's Avatar
    Jan 23 2008
    NW Indiana
    +1.....
    Enkei Raijin/H&R Sports/Tint/De-badge/No Wink/Needle Sweep/Lap Timer/Ambers Off
    Senior Member Four Rings beantown's Avatar
    Jul 27 2009
    '07 A4 2.0T Quartz
    Guess...
    Luckily I had mine replaced under CPO a few weeks ago.
    Not sure If it will step-up to a full recall in the foreseeable future, seeing as though the TC and the corresponding labor costs are quite pricey.
    Active Member Two Rings robstitzer's Avatar
    Jul 18 2011
    Wilkes-Barre, PA
    Looking forward to this becoming a recall ... I'm still CPO so I'm going to bring it up anyways.
    08 A4 SE. Stage 1 AWE/GIAC Chip. APR Test Pipe. H&R Springs. RWerks LED Tails. Hoen Yellow Fogs. Blacked out front/rear rings. Debadged. 40% Tint all around. H&R Spacers F 10mm R 15mm. Emils LED kit.
    Jul 18 2011
    Wilkes-Barre, PA
    Quote Originally Posted by beantown View Post
    Seeing as that you just had this done... What did you say or bring up to get them to replace it?
    Jun 27 2011
    Quote Originally Posted by jmarch1122 View Post
    I think its most noticeable then. You are rarely "Cruising" in 2nd or 3rd gear and since it happens only under really low load (ie cruising) you'll probably never see it unless you are in 4th or higher. I only see it when I've got my foot just barely on the gas, but its getting quite noticeable.
    I'm thinking of changing out the trans fluid myself since I've got a Vag-Com to monitor temps and I have no warranty. Couldn't hurt since thats what Audi is now specifying as a "potential fix"..
    -CP
    Jun 27 2011
    Quote Originally Posted by robstitzer View Post
    Read Wildcat333's thread about the topic. THe dealer had to run all sorts of tests and spent a ton of diagnostic time in order to rule out everything BUT the TC. It would be a LOT of money out of pocket without a warranty...
    -CP
    Jan 24 2012
    Connecticut
    My car had this same issue and is currently at the dealer. I bought the car used and it came with a 60 day warranty. luckily this happened right away so I am paying nothing out of pocket. My dealer had to run several diagnostic tests and spent some time on the phone with AOA. They replaced the DV and some other hoses to weed out the possibility of a boost leak and now, after 2 weeks of testing, the car is finally supposed to be fixed. They are supposed to be replacing the torque converter and I should hopefully have the car by the end of the week. I will update you guys to let you know how it pans out for me.
    Jul 27 2009
    '07 A4 2.0T Quartz
    Guess...
    Well apart from having a very good rapport with the service manager and being friends with a couple of techs at my dealer, I brought it in due to RPM fluctuations and significant hard up-shifts from 3-4 gear. Apparently, this is caused by the TC not locking-up as it should.
    There weren't any codes stored or a CEL, but fortunately they're willing to diagnose any issues that I bring up to them.
    At the same time they ended up replacing my intake runner motor (or w/e it's called), pcv, fuel pressure sensor, etc.
    Jan 24 2012
    Connecticut
    My car seemed to do it much more when it was cold. As it warmed up, the fluctuating seemed to stop.
    Sep 27 2008
    Phoenix
    This is scary. I'm at 52k miles, should I go out and get a tranny flush? Is there anything else I can do to keep my TC from failing?
    Senior Member Two Rings 2007B7cabrio's Avatar
    Apr 05 2010
    2008 MB R-320 4-Matic, Toyota Prius
    Weston, FL, USA
    ^^^ @ Op, nice post, I'll call my dealer today as my flutuations are back again, they where gone with a ne PCV, but now they cam back.... thanks
    Dec 11 2010
    Central FL
    Have you noticed a difference since being replaced?
    Edit: more curious on the transmission software update....
    Jul 27 2009
    '07 A4 2.0T Quartz
    Guess...
    Quote Originally Posted by Inked View Post
    I'm not even sure if they did update the software, however, after the TC replacement, the car has been driving incredibly well...huge difference.
    Apr 05 2010
    Weston, FL, USA
    OK, so I had my car in for teh TSB yesterday and got it back this morning, I have a CPO so there was no cost to me and here is what they did.
    They found fault P23004 and P3137 so the intake flap motor was replaced (V157) - TSB 2016868/8
    For the TSB (2028053/1);
    They did teh SW updates and confirmed the fluid level, they found fluid level OK, but added "blue/green fluid" not sure what that is, anyway the road test confirmed that the fluctuations are within spec e.g. less than 120rpm, I'll check it tomorrow in cold weather to confirm if it is any better.
    Jun 27 2011
    Quote Originally Posted by 2007B7cabrio View Post
    Within spec? WTF Audi! The Spec should be 0rpms of fluctuation is normal....
    Definitely let us know what the results are. Sounds like they didn't actually flush the fluid as per the TSB, simply topped off the trans.
    -CP
    Apr 05 2010
    Weston, FL, USA
    They did not top off the fluid; they actually checked the level and just confirmed what type of oil was in as the oil type had been changed during the B7 lifetime.
    For the fluctuations, it is not cured, they confirmed within spec e.g. less than 120rpm.
    I did use VAGCOM and measured the slip, most of the times it was 32-64rpm, but I saw 128rpm slip, so I'll log it and email it to the SA to see what they say , most likely they cannot duplicate it
    The tranny oil temp was 23C when started and only 56C when stopped my drive so it newer really warmed up, but I'm in S FL, kind of makes me wonder how it would be acting in northern states and CA where you actually have frost.
