Results 1 to 12 of 12
    Feb 27 2005
    North Wales, PA
    where does the 4.7uF grounding capacitor go?
    i heard it clink and land on the floor as i was moving my wiring harness around. its part number 0310 025 017. Thanks! this is for an awm.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Next to the Flux Capacitor for the warp drive???
    Feb 27 2005
    North Wales, PA
    i looked everything is there for the flux cap. maybe this goes on the Mr. Fusion?
    Jun 30 2008
    Erie, Pennsylvania
    I'm not aware that my AWM has this capacitor. Pics?
    Feb 27 2005
    North Wales, PA
    Feb 27 2005
    North Wales, PA
    i found it. it goes to the wiring harness to the coil packs to ground to the valve cover
    Jun 30 2008
    Erie, Pennsylvania
    Seems like that wire breaking is pretty common.
    http://forums.audiworld.com/showthread.php?t=2794776
    But the capacitor itself is not really necessary. Most 1.8T's do not have them as far as I have ever seen. Is yours a 2001.5?
    Feb 27 2005
    North Wales, PA
    Mine is a 2001. I'm just going to replace it with a generic capacitor if I can't salvage mine. There is like 1mm of copper I can solder to. it's going to break again eventually unless I add ton of strain relief and potting.
    Jun 30 2008
    Erie, Pennsylvania
    Good Luck. Are you noticing a problem with it removed? I'd just delete it if it were mine.
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    I know the 30v's have these, I wasn't aware the 1.8s had them though. The 40v V8 has 2 of them, and they are bolted to the fuel rail. It is my understanding that they are used to help suppress radio noise/interference.
    Life is too short to drive ugly cars.
    Veteran Member Four Rings thenj3's Avatar
    Dec 25 2009
    North Jersey
    yea all that capacitor does is help with radio noise. not a big deal to not have it, and honestly, i'm sure you wont even notice it.
    2001 2.0l ct-5858 parting out- ringer racing, full race, comp turbo, maestro
    BUY MY STUFF: http://www.audizine.com/classifieds/...partout&cat=20
    http://www.audizine.com/classifieds/...-skirts&cat=54
    Feb 27 2005
    North Wales, PA
    My car isn't even running. I just want to rule that out as potential issues
