I would suggest you obtain a bentley manual for your A5/S5. Brian has one and it was a big help. You have to do some thinking on your feet through this process. The bentley does not give you the exact directions, but it definitely points you in the right direction and puts your wrench in the right area. As long as you are pretty mechanically inclined and use common sense, you can get this done.
Day 2 : Cleaning
The fun part. Prepare to get dirty. Put some seafoam in a spray bottle and be generous with it. We used nylon pipe cleaners, small nylon and brass brushes, long narrow shafted screwdrivers, q-tips, and many hand towels to get inside the valves. Also, make sure to frequently get a towel inside the valves to pick up the liquid carbon/seafoam as it may be difficult to extract with a brush or screwdriver. I have an air compressor at my house and we would blast compressed air into the valves to blast out any excess liquid residue left over from the mixture of seafoam and carbon deposits.
