Results 1 to 35 of 35
    Senior Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    Lightbulb AUX RNS-E (pics)
    You must have sw260 and Vagcom
    Pn# 1J0 972 977 G --Housing (x1)
    Check your rns-e before you order this part. You may already have it.
    Pn# 000 979 009 E --Wire set (x2)
    Radio shack 3.5 jack and wires
    Step 1:
    Find a location where for the aux outlet. DO NOT DRILL ANY HOLES YET!!! It will be a PITA if this DIY doesn’t work for you.
    Step 2:
    Cut both of the wire set in half and then measure the length of wire needed to reach the outlet and connect them together.
    Step 3:
    Solder the wires to the aux outlet
    Step 4:
    Push the pins into the housing.
    Aux Right- pin 6
    Aux Left - pin 22
    Aux Ground - pin 21
    Step 5:
    Plug it into the rns-e to test it out.
    Recode the RNS-E to enable Aux input using vag-com
    XXXXX?X
    ? = 5 to enable AUX
    ? = 6 to enable AUX and SAT radio
    Step 6:
    Wrap the wires with black electric tape.
    Step 7:
    Drill a hole for your aux outlet and mount it.
    Veteran Member Four Rings snopyro's Avatar
    '07 Ti DTM Ibis Avant, DC Taco, SV650s, lots of snowboards
    Nice write-up. I will need to do this!
    Active Member Two Rings tecnica's Avatar
    Sep 03 2010
    MN
    great write up
    Senior Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Did you have to remove the center console to mount the AUX there?
    Feb 19 2007
    Louisiana
    I removed the ash tray, shifter trim, the piece under the hand brakes and that power outlet piece is removable
    Senior Member Four Rings Sharkfin's Avatar
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    that's awesome, surprised there wasn't already an OEM harness to buy
    Past: DTM 2005.5 B7 A4 2.0TQT
    Current: 2008 Infiniti G37s Coupe
    Future (2012-13): A5, S5, S4
    Senior Member Two Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    What is sw260?
    2.0T 6MT Q | Revo Stage II | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | NGK Iridium BKR7EIX
    Active Member Four Rings CorneliusRox's Avatar
    Jul 19 2011
    Warrenville, Chicago, IL
    Does this work if you have SAT? Awesome DIY though!
    2008 A4 6MT, Quattro, VAST Stage1 Tune, Cupra R Lip, VAGCOMed, Hawk Pads, RNS-E, 10f/15r Spacers, Eyelids, Black Vinyl, RevD DV, JOM C/O's - 24.75" FTG, 255/35-18 Ventus V12's, 80000miles+
    359awhp/K03-GT
    Thumper - 97 12V Cummins
    Lady Killer - 03 600rr
    Feb 19 2007
    Louisiana
    Quote Originally Posted by vwnobby View Post
    What is sw260?
    software update
    Feb 19 2007
    Louisiana
    Quote Originally Posted by CorneliusRox View Post
    yes
    Senior Member Three Rings layzie's Avatar
    May 14 2008
    A4 USP
    Buffalo, NY
    how do you get sw260? Wouldnt that just be the vag-com to change the settings in the rns-e?
    USP CLUB MEMBER #113
    WHITNEY AKA B7 S-LINE
    Feb 19 2007
    Louisiana
    Quote Originally Posted by layzie View Post
    you can get it with the 2009-up navi disc
    Active Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    You have the b7 seal of approval.
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    May 14 2008
    A4 USP
    Buffalo, NY
    anyone have or know where to get the 09+ navi disc ansd sw260?
    Mar 30 2009
    Quote Originally Posted by plokm View Post
    software update
    Thanks. In other words, if you have the 2009+ Nav disc, it automatically loads the software update?
    Can you just buy this kit from Kufatec to do the same thing?
    http://kufatec.com/index.php?main_pa...oducts_id=1443
    Feb 19 2007
    Louisiana
    yes
    Feb 19 2007
    Louisiana
    if you want the oem aux plug the part number is 8J0 035 475
    you also have to get 8E0 973 754
    Senior Member Two Rings philaboy's Avatar
    Jul 24 2007
    07' Avant, 04' B6 sportline
    Phila, Pa
    yes
    If you don't want to get the new nav disc can you just vag it? My disc tray won't eject but it works fine, note it has been unlocked by the dealer a few years back. I don't want to send the unit out.
    (Black-on-Black) B7 07' Avant 6mt every option ex- S-Line, But got MMI | Debadged | Euro Plate Holder | Oem Blue Tooth | more to come
    (Black-on-Black) B6 04' 6mt with sport package | Apr tuned stage 1 | Debadged
    Senior Member Four Rings BASARAB's Avatar
    Mar 01 2010
    2004 Audi A4, 2004 Saab 9-3
    Farmington Hills,Mi
    dont really understand what you are asking. What u mean by vag it and unlocked by dealer?
    R.I.P DG B6. Apr stage 1+,710n DV,Podi boost gauge,e-codes,hardwired escort 8500 x50,single mass flywheel clutch,icelink ipod integration,rns-e
    Jul 24 2007
    Phila, Pa
    Quote Originally Posted by BASARAB View Post
    yeah was sending that from my phone it did not come out the way I wanted, but what I mean is that my disc tray is not working (will not eject) I had the dealer unlock the eject button a few years ago it worked fine when they did it. I got a new copy of the nav disc 2009, pushed the button and it tried to eject but would not come out. So my question is can I just do the mod and vag it so aux comes up on the unit? or will I need that new disc?
    Jul 24 2007
    Phila, Pa
    Quote Originally Posted by philaboy View Post
    Funny thing is the nav works fine, just will not eject the disc....smh
    Mar 01 2010
    Farmington Hills,Mi
    I think there is a function in vag-com to enable/disable eject button
    Jul 24 2007
    Phila, Pa
    yeah i had the dealer do that, the disc just won't come
    Jul 24 2007
    Phila, Pa
    all i want is aux in my car, i have Sw0150 just checked. is sw260 the only why I can get the aux to show up. If it is I have to get the unit fixed....wtf
    Jul 24 2007
    Phila, Pa
    Could I update the software using a SD card
    Mar 01 2010
    Farmington Hills,Mi
    No and I dont think there is anything to fix, just enable eject button with vag-com, very easy
    Jul 24 2007
    Phila, Pa
    that was done, it shows the cd is ejected on the screen. But it won't come out.
    Feb 19 2007
    Louisiana
    you need sw260
    I think you can use vag-com to force ejection
    Jul 19 2011
    So for 'Pn# 000 979 009 E --Wire set (x2)' do you actually need three? Left, Right,Ground?
    359awhp/K03-GT
    Apr 01 2005
    dfw
    You only need 2 as you can cut one in half and have 2 pins, then do the same with the other and have an extra pin.
    ACNA Member
    03 RS 6
    08 A4 2.0TQ
    Jul 19 2011
    Quote Originally Posted by marklar182 View Post
    ahh that makes sense.
    359awhp/K03-GT
    Mar 30 2009
    Finally did this mod tonight. Here is what I had to do in addition to what is mentioned above:
    - Recode the RNS-E to enable Aux input using vag-com
    XXXXX?X
    ? = 7 to enable AUX and SAT radio - As per Ross-Tech site (here)
    - I also had to reboot the RNSe - hold down FM/AM (or Radio) and Setup at the same time for 15+ seconds. The unit will reboot.
    After doing the above 2 steps, I finally got everything to work.
    Active Member Three Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    I tried this but couldn't get it to work with my RNSE. Couldn't get the RNSE to take the new code.
    I've got a Euro spec RNSE that a fellow AZ'er hacked with North American software. I have no idea how he did it, but I belive that whatever he did is preventing this mod to work. My other buddy what full Rosstec VAG COM couldn't get the RNSE to take the new code. It kept coming back with an error message about invalid software or something.
    So I've got this setup that I don't need. Selling it in classifieds here.
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi. Ready: 034 Catch Can Go: Still Stage Zero
    Active Member Three Rings mec's Avatar
    Jul 25 2010
    Denver, Colorado
    I installed an Aux on a 2007 RS4 with SW250 and it all worked smoothly, so for those of you trying to keep the video hack, it may not be necessary to upgrade to 260.
    2006 / A4 Brilliant Red / 2.0TQM /
    AG M310 19x8.5 / KONI FSD / APR / 034HFC OEM RS4 catback/
    HPFP /s1 pump 145 PRV/ A3 RNS-E Retrofit/
