Still with "AIR
BAG" on speedo and "Parking Brake Failure" center top.
yycools many thanks for this photo, guys ignore the connector,
i reused the S4 one, the bumpy orange springloaded clip is replaced
by a flat green snappy one:
S4 Steering Wheel 12-pin Yellow Connector:
1. Horn ground. Connector rests on the body of horn, united in the harness
with pin #3 on flat black MFC 6-pin connector.
2. Horn (wire rests on depresible disc)
3. R wire on Green connector
4. L wire on Green connector
5. R wire on Orange connector
6. L wire on Orange connector
7. Empty
8. Flat black 6-pin MFC Pin #2
9 Flat black 6-pin MFC Pin #1
BTW above connector's steering wheel female is blank at pos. 4-6 in both S4
and R8 steering wheel.
10-12 hook to pins 4-6 onto the MFC male, but blank on the female
steering wheel side, so no function.
TT Airbag pinout to S4 12-pin, thx God for the RS multimeter's
continuity function and patience:
1. Brown, horn and airbag ground, joins pin #3 on MFC)
Note here that the TT Airbags #8J0 880 201 J(or K, or L) 6PS have two
ground plugs on the body of the airbag:
2. Yellow (horn)
3. Green (R pin on the Green aibag connector)
4. Black (L .................................................. ....)
5. White (R pin on the Orange airbag connector)
6. Blue (L................................................ ............)
7. Empty
8 Red (MFC Pin 2)
9 Purple (MFC Pin 1)
So the car is super fun to drive, but potentially trouble without airbag.
Please give me some more ideas guys, shall i get a new airbag or repin it?
Some ideas:
1. Short in 12-pin connector, will check for it. After all, even with a decent terminal
connector tool i still beat the xxx out of it.
2. If none, looking at the pinout photo, i will try to swap 3 and 4, and 5 and 6. Maibe,
just maibe i did the pins for the Green (3,4) and Orange (5,6) in reverse, after
all pins are read from L to R and i did it the other way.
3. Poor connection at clockspring.
LMFAO this mod is driving me insane:)
