Just wanted to post up about an issue we were chatting about in another thread. Particularly to get the attention of people who are more knowledgable and to get some vendor support.
A few of us were having a conversation in a recent thread that had to do with high altitude performance of supercharged vs turbo vs NA cars. It was generally agreed upon that FI cars lose less power at altitude than NA, which is long been recognized, but do supercharged applications lose more power with altitude than their turbocharged counterparts? A fixed rotor speed with a supercharger may only allow it to compress a certain ratio of air as compared to the ambient pressure/temp. Whereas a turbo may be able to spin it's compressor blades faster in thinner air to create a higher compression factor than a supercharger for a given ambient pressure (altitude). So feel free to debate that at your leisure.
My question in regards to the ECU tuning of the B8 S4 is this: if the ECU parameters are changed to keep the boost bypass valve shut at higher rpm based on a programmed boost pressure what happens if that Pre-programmed pressure is never met? In other words, what if the altitude is high enough that even under stock conditions the pressure at which the bypass is opens is never met, so the bypass never opens? This implies that any ECU tune that is based on closing the bypass valve later in the rpm range is essentially doing the same thing as stock - save for maybe a few timing or air-fuel parameters. Under this assertion, would it be true that an ECU tune may make little or no power over stock at high altitudes?
Just throwing that out there...othe than just a general idea of the logic, I really have no idea how the tunes work. Thanks!
