Results 1 to 23 of 23
    Jun 12 2011
    Fort Myers, FL
    No Response From Controller VAG
    Hey guys, I'm trying to get into the 01 Engine Control Module in VagCom 409-1 but every time I try I get an error message that says:
    "No Response from Controller!"
    I've already got the eBay cable connected with all drivers installed and the correct COM Port. Same thing happens when I run 311.2 version.
    Any thoughts? I am trying to do throttle adaptation on my B7. I replaced the battery and rpms are dropping.
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    It's probably because you're using the ebay cable. I don't think all the modules were accessible with that
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Jun 12 2011
    Fort Myers, FL
    Can anybody confirm that?
    Veteran Member Three Rings dubzackvr6's Avatar
    Oct 18 2010
    Stage 2 C7 A6, Tahoe for the kiddos
    SLC, UT
    Is your computer plugged into AC power?
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    I think Codered is right on that one, I DL'd VCDS Lite and did all the basic vag com codes (haven't tried throttle adaptation as I didn't know about it at the time) also used the eBay cable
    RIP QG TI B7 A4
    Jun 12 2011
    Fort Myers, FL
    Quote Originally Posted by dubzackvr6 View Post
    No, why does it matter?
    Jun 12 2011
    Fort Myers, FL
    Quote Originally Posted by Leo14 View Post
    Can you recommend a cable that will work on my car?
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by bumere46 View Post
    The real deal would.
    Oct 18 2010
    SLC, UT
    With certain laptops yes. I have a genuine ross-tech cable and it wasn't communicating because my laptop wasn't plugged in... But some laptops don't have this issue. Just a thought.
    Jun 12 2011
    Fort Myers, FL
    some folks with eBay cables were successfully able to use this cable.
    Jan 07 2011
    Decatur, IL
    I know it's very long but if you read this thread: http://www.audizine.com/forum/showth...gh-*Revisited* You'll see that most all of the eBay cables will not allow you to get to that controller.
    Jun 12 2011
    Fort Myers, FL
    Shoot! What are my other options besides taking it to dealer?
    Jun 12 2011
    Fort Myers, FL
    Will Hex USB Can cable work for my car?
    Mar 09 2010
    North E. Jerz
    Read through the ebay vag com thread.. Yes I know 25 pages might seem like a lot but you find the answers you need in there, if not get the real thing
    RIP QG TI B7 A4
    Jun 12 2011
    Fort Myers, FL
    I don't have time to read 25 pages. I just want to align throttle and sell my car asap.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    If you have APR you can run it through the cruise control stalk. Otherwise, here is the manual process to do it.
    Put the car in Park.
    Pull the handbrake up.
    Put the key in and turn it to the position just before the starter turns but DO NOT start the car.
    Push the gas pedal all the way to the floor for 3 seconds.
    Turn the key to the off position, but not remove it from the ignition cylinder.
    Release the gas pedal and wait 2 minutes.
    Remove the key from the ignition cylinder, wait 30 seconds, then reinsert the key and start the car.
    Done.
    Sep 15 2005
    Norwalk, CA
    I just got my hands on some knock-off cable that works on the CAN bus. It is a replicated version of Vag 9.08. When I plug it into the computer, Windows actually recognized it as a Ross-Tech branded cable.
    I bought the batch because I needed one for my 2010 golf (which is ALL CAN bus), and just confirmed that it can access the b7 engine control module as well.
    If you want, I can get one to you for $40 shipped in the continental US. Let me know.
    Peter
    Aug 26 2005
    Yes
    Vorsprung durch Technik
    Aug 26 2005
    Low battery voltage will effect connectivity to various modules on some cars. Hook up a battery charger while doing diagnostics or module coding.
    Feb 04 2012
    UK
    I had this problem with an Ebay cable and VCDS lite (and VAGCom 409) - here's how I fixed it. In VagCom setup COM3 reported as seeing the cable succesfully but like you got no response when connected to the car. In windows only COM1 and COM4 existed. So I went to the VAG COM setup chose COM3 and confirm it identifies the cable. Then do not save settings instead change the selection radio button to COM4 then save without testing (which is would fail anyway!)
    It should now work - mine did after doing this. Obviously use whatever COM port windows reports if you don't have COM4.
    Oct 16 2013
    Washington State
    Quote Originally Posted by jmb1963 View Post
    what does this mean?
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Seems like more and more of these are popping up.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Jun 02 2016
    San Angelo, TX
    M
    Mkk m k bnk b nnn m n.mkm
