Results 1 to 3 of 3
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Cool No crank lock tool?? No problem!!
    Was dreading taking off the crank pulley for replacement and as part of a timing belt replacement, largely because of the amount of torque on the crank bolt and the fact that I was missing a required tool for the job, VW 2084.
    Of course the only place in town that had one was Southrape (the local stealership). And they flat out refused to loan me the tool even with a $500 deposit. Then they wouldn't even entertain selling me their tool and ordering themselves in another one.
    Best he'd do was order it for me, at retail and I'd still be waiting as long as I would if I'd just went through ZDMack via eBay.
    Now that it was down to principle, I said screw you I'll just make my own.
    Once it was mocked up, only one original hole needed to be notched about 1/16" to fit up nicely.
    The only difference was that using this flat bar tool for a crank lock out device meant you needed a person to watch the crank and make sure it doesn't drift while breaking the crank bolt. For whatever reason, this presented no issues for me and came off nice and easy. Score one for the good guys!
    What did happen was two of the four smaller hex-head bolts that go around the crank bolt rounded during removal, so we drilled the bolt heads off and turned the studs out nice and smooth.
    Same thing happened to the bolts on the outer TB cover, so using the same method to release the others, and... voila! I now have all the access I require for the work I'm about to commence.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Veteran Member Three Rings import automart's Avatar
    Jan 28 2009
    Muskego
    Very creative, good job.
    Jun 11 2010
    1981 Scirocco
    Philly, PENN
    I had a similar "workaround" tool (which required less fabrication) to help install the pressure plate bolts on my Mk2 Scirocco. Nice job!
