Page 1 of 4 123 ... LastLast
Results 1 to 40 of 121
    Senior Member Two Rings BlakMarketKlash's Avatar
    Apr 18 2009
    00 S4 ,350 SIERRA, 98 GTI
    Calgary
    BlakMarketClash's TiAL S605 Thread
    Here's my build. No internals yet, but that will come next.:p
    Car: 2000 Brillant Black 6 speed w/ 120 000Km
    Camera: Canon Rebel XSI wide angle w/85mm lens
    Engine Size: 2.7L
    Rods: Stock
    Pistons: Stock
    Cams: Stock
    Heads: you guest it
    MAF: 85mm EPL
    Injectors: Bosch EV14 72lb
    Fuel Pump: 044 Bosch with gay basket
    Intake: Stock Airbox
    Intercooler: ER
    Shifter: JHM early short
    Exhaust: 034 3" DP to single 3.5" one muffler
    Brakes: Stock until i can sell my body enough to get some better ones quick!
    Deletes:
    A/C(all lines condensor and evaporator, + the pulley)
    Secondary Firewall
    AUX coolant pump
    Spider Hose
    Trunk lining
    Cats
    Now i know how much you like pics!!!!!!
    As she sits
    Next to the 928
    bumper off, rad off
    random TB shot, carbonated
    Fuel line off, plugged, harness being labeled
    Another 928 shot ha
    Accessories
    Now these come out
    Arsenal Readied
    Im labeling all the bits for ease
    Whats missing?
    Badge Glory
    I cant resist
    Wheel Sensor bolt is F'ed, watch out!
    Upright Pincer bolt aswell, ill take care of it
    Axles out
    Driveshaft and straight pipes unbuckled
    Just put the ball in the hole!
    My ECU, to be sent to Dave @ EPL because im to archaic to update the ancient algorythm, Thanks Dave!
    A/C now gone(its Canada, theres already igloos next to starbucks so i think im good)
    Shifter Box no un-inconste (sp?)
    Corrado Kirk builds some big diesels, call him up
    Mounts un-done and motor lifted
    Engine Out! I'm going to get it on the stand and freshin it up a tiny bit
    More pics to come after i get home from nightshift! yeah
    Registered Member Two Rings CaptainMorganS4's Avatar
    Apr 18 2011
    B5 S4 6SPD
    College Station, Texas
    haha is that you holding the beers?
    cheers bro. porsche looks like a beast.
    Senior Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago.
    more of the 928 please! I've had two over the years
    Senior Member Three Rings morris400's Avatar
    Dec 18 2008
    2001 Audi S4 2007 Jeep Grand Cherokee
    Alberta, Canada
    get er done bro. cant wait to see it when your done. ps i got your msg on eurodrivers. thanks for holding the exhaust for me nate.
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    unitronic Stage 2+ (3-) with BW K04s, 034 inlet pipes, 710n DVs, 034 trans and motor mounts (track density), Podi boost gauge, SSAC full exhaust, OEM RS4 Grille, silcone TBB and hose kit, JHM FMIC, custom spider hose, Stern power ring rear dif mount Not installed yet.
    Senior Member Four Rings Hyphy's Avatar
    Jan 09 2009
    Ft. Lauderdale
    can u take normal pics? :)
    gl on the build.
    Nick
    PM me if you need any B5 work done in south Florida.
    I'd rather be flying
    Registered Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    Looks great! Where did you get your a/c delete belt?
    Aug 05 2008
    Chicago
    All you need is some better beer and a pair of shoes(picture 9), and you set. Good luck. Be ready to break random shit lol.
    Active Member Two Rings highspeeds4's Avatar
    Oct 26 2010
    MRAP
    Gardendale, AL
    My eyes hurt!
    Good luck
    2001 BB S4 6spd.......all stock 140k
    2003 Mazdaspeed Protege.......some mods but being sold
    2007 Chevy Tahoe 4wd........keeps wife and kids safe
    Senior Member Three Rings MLJS4's Avatar
    Jan 06 2010
    Stg2 Nogaro, Stg3 Imola, Mk2 gtis X3, volvo s70 turbo
    Michigan
    Quote Originally Posted by nthusiastt View Post
    ben, you can get it from anywhere any part stores, you just need the size which i forgot what it was when we did it to my friends s4
    2001.5 Stage 2 Nogaro
    2001 Vast Stage 3 Imola
    Oct 27 2008
    B5 S4 Avant
    Quote Originally Posted by MLJS4 View Post
    That's what I did with my prelude a/c delete. Just don't want to measure. I want to have all the parts ready (or as much as possible) when I take it apart
    Nov 14 2006
    '02 911 C4S, '00 Passat Variant
    Renton, WA
    For the love of god, please use a regular lens on your camera.
    -Darrick
    No more Audis, but can't leave this place alone.
    Apr 18 2009
    Calgary
    LOLZ i just sent you guys through a wild optical adventure!
    Apr 18 2009
    Calgary
    Quote Originally Posted by CaptainMorganS4 View Post
    Thanks! Thats my good friend kirk, we just finished putting a lysholm 1.8L into his corrado before this
    Apr 18 2009
    Calgary
    Quote Originally Posted by KNaudi View Post
    I will do that.
    Apr 18 2009
    Calgary
    I will do that.
    Apr 18 2009
    Calgary
    Quote Originally Posted by wan2play View Post
    lol, i stepped in axle grease when i took that
    Apr 18 2009
    Calgary
    Apr 18 2009
    Calgary
    6pk1725 ftw. When it stretches its perfect
    Apr 18 2009
    Calgary
    Okay, so now is when the fun starts....
    Parts:
    FX400
    TiAL 605 From EPL
    Meth
    Water Pump
    605 housing
    Tranny out
    parts are adding up quick
    fuel rail off
    Engine bay cleaned
    turbos off!
    motor on stand
    Lines and brackets out
    Deep in the valley
    Timing belt off
    Old T-stat still doin alright
    Cam bolts out
    Some germans got shot at dawn because of these
    End-Cap bolts were broken, then replaced
    I fabbed and sealed a new spider assembly
    Tensioner installed
    Aux pump deleted
    One end cap had cracks, still okay though
    Caps installed
    New seals all the way around
    Jan 11 2007
    SLC,UT
    I vote no more fish-eye. I love how you put the camera in the build specs
    Good luck with it!
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
    Jan 11 2007
    SLC,UT
    What size of red hose is that that fits right on the valve cover breather nipples?
    --RS4 AIRBOX--
    LOOKING FOR:
    Apr 18 2009
    Calgary
    Quote Originally Posted by jibberjive View Post
    It's 3/4". It fit very snug, and i plan on updating that when i find some better material. I just did a shit-load of work done on the car and took, (what i thought at the time) were alright photos lol. Maybe ill get better here before its done for your eyes sake
    Apr 18 2009
    Calgary
    And thanks!
    May 23 2008
    birth place of land speed reco
    I like your normal mode on the camera too instead of the fish eye. Keep up with your steam, do not end up like me, my car has been piece for over 8 month now. Good luck...
    BTW, how did you clean your engine bay? your floor looks spotless. What cleaner and method did you use?
    Senior Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Parts
    Your Computer Screen
    BB Hotness.
    StrictlyEuros ::: Web
    J-Fonz Tuning
    Apr 18 2009
    Calgary
    Quote Originally Posted by chinaren View Post
    Thanks man! I would help you work on your car if i lived anywhere near, i seem to be a work robot right now. ha
    I cleaned the engine bay with first 2 cans of Brakleen, then some WD40, then just soap and water. I bought it off the original owner with low-ish miles but the guy never cleaned the bay because it was gross!
    Apr 18 2009
    Calgary
    Parts to acquire: One bumper alignment bolt, one wiperblade nut, and some deodorant.
    Now for the timing, I find the approximate bentley manual way the best for me. Plus, it takes like ten minutes aswell as does a good job of keeping everything in pin point timing.
    After i replaced the seals in the heads i cleaned the front of the block up a bit which was surprisingly clean already and installed the cam lock bar.
    I then installed two 'saftey nets' of tiewraps and rope to insure nothing will fall off.
    I also installed the crank lock pin which i guess is a mystery in location to some, but, HERE IT IS right underneath the driverside motor mount bracket. This will hold the crank in perfect TDC for me.
    I left the cam-pulleys off slightly so i can spin them when i tension the belt for even tension. (the cam bar works by connecting to the end of the camshafts onto two tabs which go in one way)
    The cambolt is just threaded in half way so it doesn't stiffen up the pulleys.
    I then could start to prime the tensioner before i pull the pin and that tenses the belt, and spins the pulleys into good positions.
    Then bottom of the wrench is pulled into the snub mount bracket
    The belt is now tense and i can pull the pin and tighten the pulleys
    Got all the torque specs written on that piece of paper by my feet.
    I sealed the valve covers and put on my new spider assembly. Plus i put the fuel rail on with the new injectors.
    Sep 16 2009
    Parts
    Nice work!!
    J-Fonz Tuning
    Apr 18 2009
    Calgary
    Quote Originally Posted by DiscoPotato View Post
    Nice work!!
    Thanks! My floor went from pristine to dirty very quickly during that
    Apr 18 2009
    Calgary
    Quote Originally Posted by morris400 View Post
    Anytime Kenny.
    Apr 18 2009
    Calgary
    Next step, turbos. I had to buy some coolant supply lines, turbo gaskets, and modify a couple things which went okay.
    I used a marker to guide my angle grinder here, AND shot an in focus photo at the same time.
    Had to break out the copper anti-seize
    I had to mock it up a couple times to get the approximate mount modifications right.
    Driver side
    Passenger side
    Apr 18 2009
    Calgary
    I also just went ahead and took it upon myself to install the signal and wastegate lines, which look 'very nice'
    Here they are on the turbo(s). Use threadlocker and dont forget anything.
    With the turbos wrapped up i cut over to my shifter linkage and went ahead and installed the 'trio' early package! I'm very happy about how this will feel.
    Here's the other end of that:
    I really dislike the plastic crosspiece
    And my APR bipipe needed heavy modification to clear my fan! Anyone else get that?
    Aug 05 2008
    Chicago
    this is coming along nicely and very quick...unlike most build threads. Props to you
    Apr 18 2009
    Calgary
    Big up's Thanks i appreciate the energy
    Veteran Member Three Rings RusS4's Avatar
    Nov 14 2006
    2000 Audi S4,1980 VW Caddy,05 R1
    VA
    Nice build man, youll enjoy
    Tial 605's EPL Tuned
    Lots of other goodies.
    Apr 18 2009
    Calgary
    Quote Originally Posted by RusS4 View Post
    Thanks a lot. Lets hope it will tide me over for a little while!!
    Apr 18 2009
    Calgary
    Most of the time i spend on this build is done at 5:00AM after i get home from wiring (electrician) this shitty department store in the south of town. But it's all good, i can almost see the light at the end of the tunnel. ordered the AFR G3 and LC-1 today, i like the analog display, parallax error time!
    Started by cleaning the bellhousing, inspecting the clutch fork, installing the CM TOB, and greasing the flanges.
    The light weight steel, SMFW (that rhymes) didnt come with a torque plate, but i consulted Kevin@ CM about using the OEM torque plate and he said it was okay. I used caution torquing the FW bolts up while using threadlocker because they dont look like stretch bolt. Instead of a full 180*, i went 60*. They were solid. The rest was also bolted up.
    Here a picture i found of the coolant, oil lines, with the EGT probes installed i forgot to post. (Sorry, a little blurry)
    I took out my stock fuel pump, and bench tested my 044. ITS ALIVE! Here's a comparison
    There something interesting i found in the trunk when it comes to the sunroof that will save ppl a lot of time when it comes to cleaning the lines. Just take the lining on either side part way out and you will expose the drain lines. I might just be discovering this now, and you already know.
    Got my Lobro kits, and REIN kits(thanks kenny!) and disassembled my front axles and cleaned them up. CAREFUL , this shit has lead in it.... That could harsh your nervous systems buzz
    J1 AR Driverside shaft all naked
    Inspected end hub, and cleaned it up, (photo pre-cleaning)
    Shaft all done and burped, i did passenger right after
    To the break of DAWN! The sun came out and I opened the garage to give me room to work in my new office. welcome to my new office (im delirious)
    BTW i had Depeche Mode, and the new White Lies records on the stereo. I tried that new Band Of Horses record and promptly threw it in the trash, along with my old IC brackets!
    Got the harness out carefully and wired the motor after i gapped the spark plugs to .025 and installed coil packs
    Thats it for now.
    Apr 18 2009
    Calgary
    Does anyone run a in cabin FP gauge? or recommend one, its going to look like Vin Diesels car with all these gauges
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by BlakMarketKlash View Post
    I'm going to run an in-cabin gauge. What I'm going to do is use a pressure transducer and wire it into one of the auxiliary inputs of my Zeitronix ZT2 LCD gauge (that way I avoid the Vin Diesel look. I'll only have an analog boost gauge in the vent and the LCD gauge, but I'll be measuring Wideband O2's, EGT's, Boost (electronic and analog), and fuel pressure. And I'll be measuring Ethanol content in the glovebox.
    Do you by chance know the inner diameter of the stock basket?
    --RS4 AIRBOX--
    LOOKING FOR:
    Apr 18 2009
    Calgary
    The stock basket has ridges running vertically to hold the pump away from the diameter of the actual inner basket wall , i didnt have any calipers on hand but i used my tape. 1" 11/16 with ridges and 1" 7/8's w/o.
    + I really wish i bought the Zeitronix now! I think i'm going to source a sending unit from something to make use of a digital gauge. I guess 4 gauges isnt that bad ;)
