Results 1 to 7 of 7
    Senior Member Two Rings matthewb2795's Avatar
    Mar 13 2010
    2005 Buell XB12s
    Michigan
    A couple torque specs needed to complete my coilover install.
    I installed my Stasis SS coilovers today and I cannot find a few torque specs I need to completely finish up. Tomorrow I plan on dropping the car and adjusting the suspension to height.
    Rear torque specs I need: rear subframe bolts and the bolt that is used to adjust the rear camber
    Front torque specs I need: front sway bar, steering link bolts, and control arm bolts.
    I am sure I could get away with just tightening them up, but if anyone has a bentley manual or has these torque specs, it would be a great help! Stasis' directions dont include all the torque specs and their tech support isn't the most helpful I've ever used. Thank you!
    -2007 Brilliant Black Audi A4 Titanium S-line, 6-Speed-
    STaSIS SS Coilovers / RS4 Rear Sway Bar / Podi Electric Boost Gauge / APR Tune / 034 Turbo Inlet Pipe /18" RS4 Reps (previous owner's mistake, looking to fix this soon)/ H&R TRAK+ Spacers 15f, 20r - Final ET 27f, 22r
    Seeking OEM B7, or B8 Ti wheels, PM me!
    Mar 13 2010
    2005 Buell XB12s
    Michigan
    Nothing?? At least the rear subframe bolts?
    I followed the the Stasis write-up from A4Mods, which is has been extremely helpful with the exception of trimming bumpstops and torque specs.
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Just got my Bentley in the mail yesterday!
    If you can wait till tonight and no one posts them up I will get it for you.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Mar 13 2010
    2005 Buell XB12s
    Michigan
    That would seriously be a huge help! Thank you!
    Veteran Member Four Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT, 2016 Audi SQ5
    Portland, OR
    Threw in a few extras just in case you or anyone else needed them
    Front Torque Specs:
    Upper Link to Strut Mounting Plate: 50 Nm (37ft-lb) then 1/4 turn
    Pinch Bolt, Upper Links to Wheel Bearing Housing: 40 Nm (30 ft-lb)
    Lower Control Link to Subframe: 70 Nm (52 ft-lb) then 1/2 turn
    Strut to Lower Control Link: 90 Nm (66 ft-lb)
    Connecting Link to Front Stabilizer Bar: 40 Nm (30 ft-lb) then 1/4 turn
    Connecting Link to Lower Control Link: 40 Nm (30 ft-lb) then 1/4 turn
    Lower Guide Link to Subframe: 70 Nm (52 ft-lb) then 1/2 turn
    Lower Guide Link to Wheel Bearing Housing: 110 Nm (81 ft-lb)
    Subframe Support to Subframe: 110 Nm (81 ft-lb) then 1/4 turn
    Subframe Support to Body: 55 Nm (41 ft-lb)
    Stabilizer Bar to Subframe: 25 Nm (18 ft-lb)
    Rear Torque Specs:
    Upper Shock Mount to Body: 36 Nm (27 ft-lb)
    Lower Shock Mount to Stub Shaft Carrier/Wheel Bearing Housing: 150 Nm (111 ft-lb) then 1/4 turn
    Stabilizer Bar to Coupling Rod: 45 Nm (33 ft-lb)
    Coupling Rod to Control Arm: 25 Nm (18 ft-lb)
    Stabilizer Bar to Body: 25 Nm (18 ft-lb)
    There is no Torque spec for the bolt that adjusts camber, as it is adjustable.
    Hope this helps!
    F.T.W.L.T.B.D.W.I.C.T.W.
    -Trent
    Senior Member Three Rings Kim's Avatar
    Jan 02 2010
    Over here
    Weren't the torque specs indicated in the manual? Mine were complete although I'm running the Stasis Ohlins SL
    Mar 13 2010
    2005 Buell XB12s
    Michigan
    Front Torque Specs:
    Rear Torque Specs:
    Hope this helps!
    You are a king! Thanks so much. That helps a ton.
    Looking through my instructions, its hard to believe those guys build race cars but can hardly write a legible/logical manual.
