Results 1 to 19 of 19
    Feb 07 2011
    california
    B8 S4 Bumper Removal and Grill Replacement
    Tools needed
    10mm socket
    25 Torx
    15 Torx
    Flathead Screwdriver
    Phillips Screwdriver
    Step 1 open and hood and you will see 4 bolts on either side of the latch remove these.
    Step 2 Remove the panel that the previous bolts were holding onto
    Step 3 Remove the bolts directly behind both left and right side of the grill
    Step 4 Remove the bolts behind the grill panel behind and below the bolts from step 4, you may need an extension for the torx here.
    Step 5 Remove the three silver bolts on the bottom of the bumper under the car closest to the front
    Step 6 Remove the 8 screws inside of wheel wheel located towards the front. You will need to turn your wheels to get to them
    Step 7 Remove the two tabs in the wheel well, use a screwdriver and pop them off.
    Step 8 Remove the three bolts holding on the thermostat behind the grill. Just lay it on top of the motor for now. No need to remove the wiring.
    Step 9 Under the car in front of each wheel there is a bolt on wither side of the engine you must take out. Use a phillips screwdriver.
    Step 10 Pull back the wheel well material and look inside you will see a bolt that takes the 10mm socket. You may need an extension for this piece as well. Turn your wheels and unscrew these on both sides.
    Step 11 I reccomend having someone help you remove the bumper because it is now loose. But there are two wires connected to the fog lights that must be removed to take off the bumper
    Step 11 start from the sides and gently pull bumper away from the car. It should come off very easilly.
    Step 12 Have a padded clean surface to lay bumper down in order to remove the grill.
    Step 13 Remove the 6 silver bolts from the grill that hold it to the bumper and the black foam pad. From here you can wiggle the grill free.
    Step 14 Put in the new grill and follow steps in reverse.
    Step 15 Finished Product
    Veteran Member Four Rings svander's Avatar
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    Quote Originally Posted by james.windle12 View Post
    I urgently need to know the part number for these two screws. Can anyone help?
    Thanks in advance.
    Apr 30 2010
    San Diego
    This DIY will come in handy shortly
    2011 Audi S4 | 6MT | Ibis/Black Silk Nappa | Nav l B&O | Sport Diff | Carbon Inlays | H&R l Strat Intake l Strat SS l Alu Kreuz l AWE Exhaust l AG M510 20x10 et35 l GIAC Stg II l DTM Lip l Eurocode Diff Mounts l SS Clutch Line
    Senior Member Three Rings dame drizzo's Avatar
    Sep 15 2009
    1995 Audi URS6
    My screws were stripped so I have different bolts now
    Current- 2013 Volcano Red Metallic B8 2.0 -Frankenturbo F23L, RAI Custom HUGE FMIC, RAI MS Full Turbo Back Exhaust, Hotchkis F&R Sway Bars
    Past - 2010 Audi A4 2.0 EFR 6258 Stage 3 (Total Loss/ Hurricane Sandy)
    2009 Audi A4 2.0 Stage 2 (Total Loss)
    VCDS RossTech NYC Area
    FIRST AUDI B8 WITH EFR - 330whp @ 22psi 93oct
    instagram.com/damedrizzo
    Xclusive Auto Leasing - Sales & Marketing Manager
    [email protected]
    Senior Member Three Rings motorboatingsob's Avatar
    May 01 2012
    West Chester, PA
    nice DIY. I will be using this for the RS4 grill. Thank you!
    2011 S4 | Pearl Black | Silk Nappa | 6MT | Sport Diff | Nav | ADS | B&O | SC Badges | 20% Tint | Tinted Tails | HID Fogs | int/ext LEDs | RS4 Pedals | STaSIS V2 Tune | Eurocode Shortshifter | APR Carbonio Stage 1 & 2 Intake | Alu Kreuz | E-Code Headlights | AWE Boost Gauge | AWE Non-Res Exhaust |
    Apr 30 2010
    San Diego
    This DIY works well and is a few less steps as well. Just used it to do my RS4 grill.
    http://www.audizine.com/forum/showth...Front-Splitter
    Stage 3 Forum Advertiser Four Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    Quote Originally Posted by svander View Post
    Thanks in advance.
    N-105-514-03
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
    Veteran Member Three Rings S4charged's Avatar
    Oct 11 2012
    West Covina, CA
    Where are all you guys putting your Thermostat after removing it from the OEM grill? My RS4 grill doesn't have bolts to screw on the thermostat.. I took out the thermostat from the plastic housing to make more room, was thinking of 3M taping it to the grill.
    Ibis White - 6MT
    APR Stage 2+ / Eurocode Headers / End Links / Sway Bars / Alu Kruez / Short Shifter /
    Milltek RESONATED. Carbon Tips / Stratmosphere Intake / H&R SS / RS4 Grill / VAG Mods --- SOLD
    2016 Prius 4
    2018 RS3 Nardo Grey - Dynamic Plus / Technology / RS Design / Black optics / Carbon Inlays - APR Stage 1
    Jun 20 2012
    replacement grill
    Hi All,
    i'm trying to find out if i can replace the chrome trim on the grill, or must i replace the entire part? if so, where can i buy it.
    thanks in advance for any feed back.
    Veteran Member Four Rings phillips2024's Avatar
    Mar 03 2011
    Southern NH
    what are you trying to accomplish? May i suggest plastidip. It will save you quite a bit of time and money
    2017 Audi S8+ | 2021 Audi RSQ8 | 2021 Cadillac Escalade Sport Platinum | 2007 Porsche Turbo
    2021 Sea Ray 350 SLX | 2020 Polaris Ranger Crew XP1000 | 2022 Polaris Indy VR1 850/650
    Oct 14 2012
    Empty...for now...
    SE PA
    I removed my bumper yesterday to install an rs4 grille, reinstalled the bumper but now it is uneven where the bumper meets the hood between the grille and the headlights on each side....but it appears to have lined up properly everywhere else. Anyone else have this issue? Pic below for reference:
    SOLD 2015 Daytona Gray S4
    Veteran Member Three Rings motionneon's Avatar
    Feb 09 2011
    Honda Odyssey Turbo S
    St. Petersburg, Florida
    Quote Originally Posted by S4charged View Post
    Don't remember having a thermostat within grill...just home link.
    2011 S4 DSG
    Phantom Black, Black and Magma interior, RS4 Grill, 30% tint all around
    STASIS v1.0 ECU, Strat intake, Milltek non-res exhaust, Deval Rear Valence
    19" Peelers, Michelin Pilot Super Sport A/S
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    Quote Originally Posted by motionneon View Post
    You bet, that is the HomeLink transmitter behind the grille.
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Sep 30 2009
    b
    Quote Originally Posted by SteveYem View Post
    there are screws near the headlights, loosen them, they should have "wiggle" room, meaning they have notches to either go in or out, you can adjust it there.. or should be able to. I'll get a picture sometime..
    Oct 14 2012
    Empty...for now...
    SE PA
    I know the ones you are referring to. In fact, the one on the side that is dropping got stripped out so there currently is no screw there. However the pressure from the clip/tab arrangement there holds the bumper in place, and even if I push/pull the bumper up here I can't get it to line up, i.e. I don't think having the screw in that location would help anything. I think I'm going to have to remove the bumper and try hanging it again, this time taking care to line up those two top sections first, then line up the sides. I will get a larger diameter sheet metal screw to replace the stripped out one while I'm at it.
    Sep 30 2009
    b
    before you do that, you can also adjust the height of the hood.. I'm not sure what component needs adjusting, but taking it off would be the last thing I fiddled around with, there are two black rubber swivel screws on the hood that go in and out, and should change the distant minorly, but will also change the distance from fender to hood.
    Jul 24 2013
    United States
    Can someone help me? new Audi owner and I'm doing this installation. My question is specific to the 10mm bolt that is on the driver side. I can't seem to locate it. the only one I seem to be able to see that resembles this seem to screw the intercooler to the bracket. Is there anybody out there that does this that can maybe take a picture and point out where the 10mm bolt I need to remove is located on the driver side?
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by sjlucky View Post
    If it's the one I think you're referring to, it's sort of below and behind the headlight. I ended up removing my headlights because it made it easier to access that bolt.
    The DIY I read back before doing mine said that the bolt could be accessed up through the front of the wheel well by moving the fender liner out of the way and reaching up in there. I just found it easier to get the headlights out and go in from the front.
    Veteran Member Three Rings jfabes's Avatar
    Feb 05 2012
    H-town
    its on both sides, so if you located the passenger one, you can find the drivers. in the pics above, step 10....once you turn the wheels (do not need to remove) and remove the lower two T25 screws (step 6), you can pull back the fender liner (you do not need to remove the tabs in step 7) and look towards the front of the car, just behind the headlight and you will see the 10mm bolt. you will need about 12-15" worth of socket extensions.
