this is the best list i have
Full Audi S4 Maintenance Plan
Maintenance Intervals
Service at 5,000 miles (8,000 km) or 6 months after delivery
* Engine: Change oil
* Oil Filter: Replace
* Service reminder indicator display: Reset
* Wheels: Rotate front to rear
* Fluid Levels: Check coolant and windshield washer fluid levels; add if necessary
* Automatic shift lock: Check operation including neutral safety switch (where applicable)
* Brake system: Check thickness of pads
* Manual transmission: Check gearshift mechanism and clutch for proper interlock operation
Service at 10,000 miles (16,000 km) and then at every 10,000 miles (16,000 km) thereafter
* Cooling system: Check coolant level, add if necessary
* Exhaust system: Check for damage and leaks
* Engine: On Board Diagnostic: check Diagnostic Trouble Code memory and purge if necessary (where applicable)
* Doors: Lubricate door hinge mechanism
* Battery: Check electrolyte level and add if necessary
* Windshield wiper and washer: Check fluid level, add if necessary
* Automatic shift lock: Check operation including park/neutral safety switch (where applicable)
* Tires and spare wheel: Check condition and pressure
* Brake system: Check for damage and leaks, thickness of pads and brake fluid level
* Drive shafts: Check boots
* Road test: Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning and power accessories
* Lights: Check
Additional Service intervals
At every 20,000 miles (32,000 km)
* Front axle: Check dust seals on ball joints and tie rod ends, check tie rods
* Haldex clutch: Change oil and filter
* Automatic transmission: Check for leaks
* Manual transmission: Check for leaks
* Transmission final drive: Check oil level and add if necessary
* Dust and pollen filter: Replace
* Head lights: Adjust
At every 40,000 miles (64,000 km)
* Air cleaner: Replace filter element
* Spark plugs: Replace
At every 80,000 miles (120,000 km)
* Ribbed belt: Replace
* V-belt: Replace
At every 105,000 miles (160,000 km)
* Timing belt: Replace (V6 5-valve and V8 engines only)
* Timing belt tensioner roller: Replace (V6 5-valve engine only)
Every 2 years regardless of miles (kilometers)
* Brake fluid: Replace
[edit] Common Problems
* K03 turbos fail - Often replaced with K04 turbos from the B5 RS4. K04 turbos also fail
* Control Arms - Common to the B5 platform.
* Wheel bearings - Common to the B5 platform.
* Dash cluster display LED develops lines - Rebuild kit available.
* Throttle body boot (TBB) leaks - Often replaced with an aftermarket boot.
* Diverter Valves - Often replaced with 710N valves.
* Coolant after run pump fails and leaks - Shine a flashlight under the intake manifold and look for dried pink G12 residue.
* Valve cover and cam tensioner gaskets leak.
* Central lock Pump
* ABS Module
* Seats wobble
* Rearview mirror leaks
* N75 valve
* Window Regulators
* Internal spring in interior door handle fails
* Accessory belt tensioner noise
* Power steering Pump
* Spider hose
* F hose
* Boost Leaks
* Bosch MAF Failure
* Rear calipers seize/stick
* Coil Packs
* Ignition Control Amplifiers
* PCV Valve
* Bose speakers
* EGT Sensors
* o2 sensors
* Climate control fan buzzes
* SAC mechanism on stock and RS4 Clutch Pressure Plates
* Clutch Slave Cylinder
* 1-2 shift collar and bad synchros
* shity borg Warner journal bearing turbos-k03/k04
[edit] "Stage" Descriptions
Stage I
* Chip
Stage II
* Chip
* Catback
Stage II+
* Chip
* Catback
* Downpipes
Stage III-
* Chip
* Catback
* Downpipes
* RS4 K04 Turbos
Stage III
* Fueling
* Catback
* Downpipes
* RS4 K04 Turbos
Stage IV
o
+ Built motor
+ etc.
[edit] Modifications
[edit] Brakes
* Alcon
* Brembo
* Stoptech
* ECS/Porsche
* D2 S8 Brembo
* B6/7 S4
* B7 RS4/C5 RS6
* 034 Rear Brake Upgrade
* JHM 2-Piece Rotors
[edit] Chip Tuning
* APR
* ASP (custom tune)
* AWE
* Eurodyne
* EPL (custom tune)
* GIAC
* MTM
* REVO
* Vast (custom tune)
* SSP (custom tune)
* JHM (custom tune)
* Avalon Motorsports (custom tune)
* Unitronic tuning
* Sportech
[edit] Exhaust
Catback
* APR
* AutoSpeed Performance (ASP) Tru-Dual
* AWE Tuning Twin 1
* AWE Tuning Twin 2
* Borla
* JHMotorsports True Dual
* Milltek SuperDual
* Milltek 3-inch catback
* Neuspeed
* SSAutoChrome
* Vibrant
Downpipes/Testpipes
* 034 Motorsport
* APR
* AWE Tuning
* Fast Intentions/Labree Split
* JHMotorsports
* Milltek
* RAI
* SSAutoChrome
* VAST Performance "Piggie"
[edit] Exterior
Front Bumpers
* AvantGarde
* Caractere
* OEM RS4
* OEM S4 RS4 Mod
* Rieger
* Seidl
* Oettinger
Full Kits
* OEM RS4 Widebody
* Rieger V1
* Rieger V2
* Seidl RS4 Widebody
Hoods
* Fiber Images Carbon (Vented)
* Fiber Images Carbon (OEM)
* Vorsteiner
* VIS Racing
* Eurogear
== Fueling ==
* AWE
* ASP
* APR
* EPL
* JHM
* MTM
* Vast
* SSP
* Dahlbak
* 10SecS4
[edit] Intercoolers
* 034 SMIC
* AWE SMIC
* ASP FMIC
* DUH FMIC
* ER SMIC
* JHM FMIC
* RS4 SMIC
* IPP SMIC
* Racetec FMIC
[edit] Interior
Gauges
* APR Vent
* AWE Vent
* Podi Steering Column Mount
* Stewart warner
* VDO
* EFU 4U info center display
Shift Knobs
* JHM
* OEM RS4
* UUC Rob Knob
[edit] Suspension
Coilovers
* Bilstein
* H&R
* Koni
* KW
* Startup Racing/Vogtland GT
* Stasis
* Tein
* Vogtland
Springs
* H&R
* Tein
* Vogtland
* Eibach
Sway Bar Kits
* H&R
* Hotchkis
* Neuspeed
[edit] Turbo Kits
* AWE RSK04 Kit
* APR Stage III Kit
* ASP GT28RS Kit
* Tial 650 Kit
* Tial 605 Kit
* Tial 770 Kit
* ATP GT28RS Kit
* ATP GT25R Kit
* ATP GT2871R Kit
* Agtronic Motorsports
[edit] Drivetrain & Transmission
Short Throw Shifters
* JHM "Solid" Short Throw Shifter
Transmission
* JHMotorsports
[edit] Water/ Meth Injection
* Aquamist
* Vast/Devil's Own
Cooling Mist
Places to buy methanol:
Online: High Performance Fuels and Additives
PowerMist Distibution Points
World Map
Local:
Name of business address city, state, zip phone wed address if applicable pricing/date/special notes
Bessemer Petroleum Bessemer,AL 205-424-2970 $96 for a 55 gallon drum delivered to your door
Hole Shot Engineering 6584 50th Ave N St. Petersburg, Fl 727-546-3541 3.00 gallon 10/04
Bradenton Motorsport Park 21000 S.R. 64 Bradenton FL, 34202 941-748-1320
http://www.bradentonmotorsports.com 2.50 gallon 4/04
Corrigan Oil Company 744 East South Street Jackson, MI 49203 517-937-4061 Salesman Steve Cell # Minimum 55 Gal $88 quoted price to my driveway.
NVR Racing 5161 N 124th St Butler, WI 53007 (262) 781-5252 2.50/gal. 04/04. Minimum 5 gallons ($12.50). Sprint Car racing Methanol
Update for Houston Raceway Park 2525 FM 565 South Baytown , Texas
$3.00 a gal compared to $ 5.00 a gal 3 months ago guess someone made some extra pocket money 9/23/04
NEW ENGLAND RACING FUEL John Holland / Mike Joy 271 Spielman Highway Burlington, CT 06013 860-673-9555 $28 for a 5 gallon bucket. It's the Sunoco race stuff so It should be good quality.
VP Racing PO Box 3202 Terre Haute, IN 47803 They are just getting ready to move and I don't know the new address, call at 812-232-7253
Briner Oil Co. 325 Beck St. Jonesville, Michigan, 49250 517-849-2144 fax.517-849-2143 800-451-4191 contact, anyone 2.68 gal.
Capital Raceway in Crofton $3.00 a gallon
Socal Performance 9723 washburn road downey, CA 90241 562862-9122 $2.05 a gallon (methanol)
Cox Oil CO. 555 E 8th St. Greeley, CO 80631 (970) 352-9208 (800) 660-2604 $15 for a 5 gallon bucket
AAI racing 5985 Lamar, Arvada, CO 80003 303-422-3571 $2.50 a gallon
Teegarden Motorsports Specialties 11383 Pyrites Way Rancho Cordova, CA 95670 916 - 638 - 7223 (RACE) Fax: 916 - 638 - 2885 Methanol $3.00/ga???
Maryland International Raceway "MIR" (Bud's Creek)
E&R automotive machine 205 W. north ave. Villa Park, IL 630 279 5464
www.enrracing.com Torco methanol 5 gallon bucket for $26.98
Craig Caulk Racing Heads 115 Avenue D South Houston, TX 77587 (713) 947-6787
Lanier's Speed Shop 106 Pueblo Av COLORADO SPRINGS, CO 80903 - 2118 (719) 633-1378 $2.75 a gallon.
Centerville Dragway Track is 11 miles south of Russellville, Arkansas. Take Highway 7 south to Centerville, then go west on Highway 154 for 1 mile. Quote of $2.50 per gallon.
Simons Petroleum Industrial Road Clarksville, Arkansas Take 58 exit off I-40, go north 1 block to Industrial Road turn right just past Johnson Chevrolet Dealership. Just got a quote of $2.00 per gallon for Methanol, less if bought by the 55 gal barrel.
McMurtrys Automotive 3204 B. Ave. Gulfport, MS. 39507 PH# 228-863-4139 Theres also a place in Long Beach, MS. Someone said they buy 55 gal drums of methanol for $99!!!
Dons Hot Rod Shop 2811 N. Stone Ave. Tucson, AZ 85705 602-884-8892 $3.40 a gallon
Smiley's Racing 2017 Peachtree Rd. Balch Springs, TX 75180 Dallas, TX I just called and I was told $2.50 per gallon for methanol. I will go up there later this week to buy some.
grand prix auto sports methanol is 2.15 a gallon tulsa oklahoma phone# 1 918 836 8487
Fairfield CT Grasmere Sunoco 3.50 a gallon for Methanol
ERC racing fuel 610 east lewelling blvd san lorenzo, ca 94580 (510) 276-9334 $2.75 gallon
Conley's Performance Plus 1443-A Aldine Bender Houston, TX 77032 Methanol $3.00 / Gallon
American Motorsports 4130 north orange blossom trail 407-290-6565 3.39 a gallon
Bowers Performance Racing Engines 117 Smokey Street Fort Collins CO 80525 (970) 226-6040 Price $2.50gal as of 11/12/04
Most of the list compiled from TurboBuick
[edit] E85 Corn Power!
[edit] VAG COM (VCDS)
* Rosstech
o General FAQ
o Purchase
[edit] ECUx
[edit] Lemmiwinks
* Lemmiwinks Guide
