Yes! I'd been meaning to respond here, in case someone else had this problem, since the solution was tough to find. But then I never got around to posting...
Anyway, I solved it ultimately with a quick VAG-COM recoding!
I found this thread:
http://audiforum.us/threads/problem-...-install.5065/
Where the guy described the problem, and though it wasn't perfectly clear, I figured it out.
He says
Code:
Sat in the car looking around with my vagcom (4.01 with a non-rosstsch cable)
I went into the adaption channels of the instrumet cluster and found some really strange values.
He said he was able to recode and fix the speedo, but I didn't get quite what values he meant, and I didn't know what the values were supposed to look like, so I didn't know which ones were "strange". I tried the command to reset all parameters but it seemed to have no effect.
Later, he describes the rest of his coding:
Code:
instrument cluster (17)
Channel 060: CAN-Databus Powertrain (Installation List)
* +00001 = Engine (Standard)
* +00002 = Automatic Transmission (Optional)
* +00004 = Brake (Standard)
* +00016 = Airbag (Standard)
* +01024 = Instrument Cluster (Standard)
coded 1045
Channel 061: CAN-Databus Comfort (Installation List)
* +00001 = Central Electronics (Standard)
* +00002 = Comfort System (Standard)
* +00064 = Trailer (Optional)
* +00128 = Convertible Top (Optional)
* +00256 = Instrument Cluster (Standard)
* +00512 = Tire Pressure Control (Optional)
* +01024 = Steering Column Electronics (Standard)
* +02048 = Climate Control (Standard)
* +32768 = Auxiliary Heating (Optional)
coded 3331
Channel 062: CAN-Databus Infotainment (Installation List)
* +00001 = Radio (Optional)
* +00002 = Telephone (Optional)
* +00004 = Navigation (Optional)
* +00008 = Telematics (Optional)
* +00016 = Intrument Cluster (Standard - only coded with 2nd Component)
coded 23
Well BAM, that's when I noticed my values were weird!
My coding values for 060, 061, and 062 were all ZERO. That's not even a valid entry! Since those values have to do with the CAN bus, I thought they could be the problem, so I just set my values to what he had, to see what would happen.
I coded it all up, and everything came to life! (I may have had to turn off the key and turn it back on... don't think I did but I don't remember).
So my guess is that basically the weird electrical shorting I did reset some values on a memory chip in the cluster somehow, and it caused the processor to just read back zero. After the recoding, everything works and its been working great for probably a month now! Interestingly, you cannot recode them back to zero, it says its an invalid number. Makes sense. It won't set those values bad on purpose, but I basically brute forced them to zero electrically.
Also note it may put your car in "transport mode". Thats the mode they put your car in when it first ships. It disables some of the electronics like the remote keys I think, and it reduces the amount of time the internal dome lights stay on for. That's all to prevent a dead battery during transportation from the factory to the dealer. Anyway, I think you can turn it off by coding, but it should also turn off after you drive another 100 or 150 miles or something like that, so I didn't mess with it.
I had actually given up and taken my car to a mechanic right before I fixed it. He had no idea what was wrong, and when he said I probably needed a $1200 instrument cluster, I got my googling into high gear and finally found that thread! Man was I excited when it all came to life!
So anyway, I hope that's all the problem was for you, it sure was for me!
Good luck,
-Taylor
