Page 1 of 5 123 ... LastLast
Results 1 to 40 of 197
    Active Member Two Rings Krys-RS4's Avatar
    Mar 09 2011
    Chicago
    K & N air filter scam
    Just bought the K & N air filter for my RS4 (model 33-2209) and it doesn't fit!
    I guess will have to go with OEM...
    Senior Member Four Rings JoshDub's Avatar
    Oct 09 2008
    My K & N barely fit in my B6 A4. Their stuff is a joke.
    The Awesome™
    Oct 12 2010
    Keswick, Virginia
    One I have fit perfectly...
    Active Member Two Rings dtoys4.2's Avatar
    Oct 01 2007
    Imola RS4/TTZ 500whp/Bagged Corrado VR6
    queens NYC
    Mine fit perfectly. Think u got the wrong one
    Mar 09 2011
    Chicago
    That's weird , I bought mine at auto zone. Both K & N web site and in store K & N catalog says that model 33-2209 fits 2007 RS4. When I unpackaged it and compared to the OEM one I already knew it's going to be bad-it was smaller. When I tried to fit it in,it was loose and didn't fit right (definitely to small).
    Dtoys4.2 do you remember which model did you purchased for your RS4?
    Veteran Member Three Rings jstahmann's Avatar
    Feb 21 2005
    2008 RS4 - Imola/Titanium
    Utah, USA
    33-2209 fit in mine perfectly.
    John
    Piggie Pipes|ECS H Pipe|Flowmasters|Stasis SLs (800/1200)|H-Sport Sways F/R|Suede Euro Steering Wheel|Apikol Rear Diff Mount|034 Track Transmission Mount|SilverRS4 PnP Intake|JHM Intake Spacers|Status Ring Alcantara Seats
    RS4 REGISTRY
    Senior Member Four Rings Retsujou's Avatar
    Dec 07 2008
    08 RS4 Tit/Exec/Prem/Carbon
    Mississauga
    Fits mine perfectly well.
    08 B7 Cherry Black Pearl RS4 + JHM Lightweight Flywheel + JHM Stage III Clutch + VAST Piggie Pipes + K&N High Flow Airfilter + APR Stage II (Testpipe tune) + Hueper Optik 30% + Magnaflow X-Pipe + Centre Resonator Delete + Deflap + HAWK Ceramic front/rear + Stoptech Steel Brake lines + V4 LED Headlights (blackout/clear corner)
    Active Member Four Rings rs4 tony's Avatar
    Sep 13 2010
    2010 S5, 2009 Viper SRT 10, 2010 Ecalade
    Long Island, NY
    mine is perfect
    2007 Audi Rs4 Daytona Pearl/Carbon Fiber Trim/Navigation/20% Tint All Around/PIAA Yellow Fogs/K&n Drop In/Apikol Rear Diff. Mount/034 Street Transmission Mount/Front Plate Delete/Michelin Super Sports 275-30-19/MTM 10mm Spacers/JHM Intake Manifold Spacers/JHM LWFW & Stage 4 Clutch/StopTech Street Performance Pads Front & Rear/JHM L/W Front Rotors
    Senior Member Four Rings WinterRunner's Avatar
    Oct 11 2007
    08' RS4 Ti, 09' Impreza hatch
    Providence, RI
    I use OEM paper that I change 2X a year or when needed.
    08' RS4 Ti/Daytona 51K and counting!
    ~ECS H-pipe~Apikol diff mount~034 trans mount~JHM IM spacers~034 MAF hose~PS2's~SR7 concealed~
    ~MTM 10MM spacers~Stoptech SS lines~Posi-quiet pads~Front plate delete~Euro bumper~Ecodes~
    ~Hoen matched fogs~Lamin-X'd front~20/35% 3M tint~CF trim~LED interior~Clear-Bra~
    Mar 09 2011
    Chicago
    Come on guys that makes me feel so stupid :) does it mean I don't know how to properly install it? Perhaps I did something wrong indeed! But what??? This should be simple,right? K&N seemed to me at least 1-1.5" too short and when i put in place it was LOOSE,WTF? :)
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by Krys-RS4 View Post
    hey. its possible that autozone took the real filter out of that box and put a different filter in your box, causing you to get a small one. thats why i ordered mine off there website, so morons at autozone dont swap it out to save 2 bucks at the registers.
    Oct 01 2007
    queens NYC
    Sorry no idea which I put in
    Active Member Two Rings karsty's Avatar
    Dec 10 2010
    2007 Imola RS4
    Edmonton, Alberta Canada
    Quote Originally Posted by rs4 tony View Post
    This is my guess as well. Either, go to a different store and buy another K&N to see if it's different, or buy online as was mentioned. If you buy from another store and it fits in the car properly, take that first one back to Autozone and slap them with it.
    Mar 09 2011
    Chicago
    Quote Originally Posted by karsty View Post
    I am going to take the exact measurements of my OE filter and compare it with the measurements on K&N web site.
    Will do it on Wednesday,keep you posted...
    Mar 09 2011
    Chicago
    Just got a new K&N air filter (ordered from Amazon.com) and IT DOESN'T FIT. Same model as before: 33-2209,what is going on here :)
    As you can see on the pictures (left the oryginal packaging in case of return),comparing to the OE filter this one is abviously too small. When I put the K&N Filter in place (pic 2) it was loose and didn't cover the whole spot...What do you guys think?
    [IMG]
    Uploaded with ImageShack.us[/IMG]
    [IMG]
    Senior Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    /07' RS4/06' MDX/05'600RR/06'400EX/
    Long Island
    Dude you either have the wrong part# or bad luck. Order the filter from K&N directly - this way you can have a replacement sent without issue if needed. I wish I knew which part# I used when replacing mine but I don't. Of course, mine fit perfectly...
    2007 RS4 : K&N drop in : Hawk HPS up front Stop Tech in the back : DTH CF Engine Cover : 30% Tint : Magnaflow X : Tubi Rumore : JHM L/W FR & RR : Audi Sport Rubber Floor Mats : H-Sport Sways F/R : Stern Links : JHM Intake Spacers : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : 034 Trans Mount : HOEN H11 Fogs : LED City/DRL & Interior : ECS Clear Side Markers : MTM 10MM : Front Plate Delete :
    Senior Member Four Rings Zac's Avatar
    Mar 26 2010
    So Cal
    you have bad luck
    Apr 06 2009
    Edmonton
    Ummm.... thats your cabin filter, not your air filter.
    Aug 14 2009
    Long Island
    Holy crap, I just realized what you're doing...you are trying to place your AIR filter where your CABIN filter goes!!!
    Aug 14 2009
    Long Island
    EKIM just beat me to it. Look in the DIY section to get a better idea of what the air filter box looks like. There is also a DIY for the cabin filter.
    Senior Member Three Rings Hyde's Avatar
    Sep 05 2008
    Northwest Florida
    Quote Originally Posted by Ekim81 View Post
    Ding. Ding. Ding!
    DUH! an Audi
    los angeles, CA
    bahahahaha
    Sep 13 2010
    Long Island, NY
    omg lol
    Oct 11 2007
    Providence, RI
    ahahaha I was gonna say this but you beat me to it... I had to re-read and make sure that K&N din't make a cabin filter....
    Veteran Member Two Rings KMHPaladin's Avatar
    Dec 12 2004
    North Jersey
    Current: 2006 A4 2.0tqm Quartz Gray/Black
    Premium | Sunroof | Bilstein PSS9 | AWE Exhaust | DTM Edition Front Bumper
    EvoMS V-Flow intake | O.Z. Superleggera III 19x8.5 | RNS-E | Hardwired 8500
    Previous: 1997 A4 2.8qm 12v Europa Blue/Gray
    Active Member Two Rings Mr Hyde's Avatar
    Oct 20 2009
    Long Island
    Lol. Sometimes you just have to laugh
    Just call me...........Mr Hyde
    2007 Mugello Blue Pearl RS4
    // RS6 Flatbottom Steering Wheel // Dension Gateway // V1 w/ LI-S4 Concealed Display // Stoptech Brake Pads // Powdercoated Rims // MTM 10mm Spacers // Ventureshield // Full LED Interior & City Lights // PIAA DRL's // Hoen Fogs
    Mar 09 2011
    Chicago
    Come on guys,have some mercy here :) I have no mechanic skill whatsoever ! Although I am laughing my ass off right now lol
    Sep 13 2010
    Long Island, NY
    it's funny. it's one of those moments where you can't get mad at doing something so ridiculous and all that you can do is laugh. lol. I have those moments all the time.
    for example:
    me: dad you think anyone in new York has the same plate as me?
    dad: is it easy? does it come natural or do you have to work on it?
    Senior Member Four Rings 4RingRook.'s Avatar
    Jan 06 2008
    B7 A4 . V36 G37S
    Arizona
    Holy fail batman! haha
    Mine as well replace the cabin filter too since you know where it is now.
    F.T.W.L.T.B.D.W.I.C.T.W.
    Veteran Member Three Rings jasonsowers's Avatar
    Feb 18 2007
    2002 Audi S4 Laser Avant 6mt 1 of 29
    Denver
    That's where I have my cold air intake.
    I'm glad you solved this problem for the 40k plus audizine users that can now remove their filters.
    http://i37.tinypic.com/2u637gk.jpg
    2002 Laser Avant that is amazing
    2000 Brilliant Black Stage 3 K04/RS6 hybrid sedan that was just as amazing (sold)
    aka : johndoes4
    aim : johndoe4742
    Aug 13 2009
    Quote Originally Posted by WinterRunner View Post
    Actually replacing the filter too often is not a good idea. Filtration actually increases as the filter accumulates some dirt as this also acts as filtering material.
    Active Member Two Rings RamŪ's Avatar
    Jan 21 2007
    NJ, USA
    Quote Originally Posted by jasonsowers View Post
    Was here...
    Active Member Two Rings chodemaster's Avatar
    Jun 09 2010
    Flawiduh
    hahahahaha
    Active Member Two Rings PB4UGO's Avatar
    Oct 12 2010
    '07 RS4, '08 A4 Special Edition Quattro
    Earth
    OK...slowly step away from the RS4 and hand me your keys.
    Wow! I mean WOW!! :rofl:
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2004.5 A4 1.8T Quattro 6 speed
    Montreal, Canada.
    Sorry but I can't stop laughing.
    The 1/4 mile in 13.3 sec. @ 107.3 MPH! Possibly the world's fastest K04 motorized A4 power by MTM (that was then...)
    In, Out and Around...
    iconoclast was here.
    Jan 28 2010
    Williamsville, NY
    was here...
    Active Member Two Rings timeboy's Avatar
    Jul 12 2008
    B8 A4, X5 4.4i, B7 S4
    South Bend/ IN
    Thank you form making my day. bahaha
    Active Member Two Rings Meehow's Avatar
    Dec 04 2008
    Baltimore
    Herro WAYOT!
    Feb 16 2008
    Iowa
    LMAO
