Page 1 of 3 123 LastLast
Results 1 to 40 of 99
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    StopTech ST-60 BBK - the results
    Ok, so I have my car in at Achtuning! for the ST-60 front BBK right now. As requested, a weigh in was done, and the results are in:
    Stoptech BBK ST-60:
    Rotor - 18.10 lbs
    Caliper - 8.9 lbs
    Pads - 2.6 lbs
    Caliper Carrier - 1.5 lbs
    Total weight - 31.10 lbs
    Stock entire assembly (caliper, carrier, pads and rotor):
    Total weight - 41 lbs
    Total of 10 pounds PER CORNER unsprung weight savings.
    Pics and impressions (as well as some metrics) later, stay tuned
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Registered User Four Rings primetime's Avatar
    Mar 05 2010
    5 four ring cars and 1 P-car...
    Quote Originally Posted by NWS4Guy View Post
    Stoptech BBK ST-60:
    Rotor - 18.10 lbs
    Caliper - 8.9 lbs
    Pads - 2.6 lbs
    Very nice... You should notice that as it is a nice savings... Looking forward to your impressions and when you get some times pics, please...
    Sep 29 2009
    Thanks Ron, now if I can get some nice lightweight wheels...that will start adding up
    Veteran Member Four Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    Nice! Can't wait to see em on!
    Sep 29 2009
    Quote Originally Posted by PsYkHoTiK View Post
    Here's pics of the parts and weigh in as well as on the car - http://achtuning.com/new-products/st...r-new-audi-s4/
    The clearance was VERY tight between the spokes and caliper (~2mm clearance), there was tons of space on the outside edge, which is where I thought it would be closer (these are on STOCK 18" wheels). While I was ensured that there wouldn't be any issues with heat and expansion, I ended up getting a 3mm spacer on the fronts to give ~5mm clearance for my comfort
    Pedal is very firm now, travel is much more linear and direct. They are only partially bedded in right now but the bite is hard and immediate - the kit has the same compound as I had on my stocks - the StopTech Street Performance compound. Wheels are still very dirty, it'll be a nice day tomorrow so I'll clean the wheels and get some good pics!
    Senior Member Three Rings krunko's Avatar
    May 24 2010
    a broom, old CDs I never listen to, cockroaches
    Los Angeles, CA
    So is it safe to say you could lose a solid 80lb with brakes and wheels?
    Can I ask how much the stoptechs cost?
    2011 Audi S4 / S-tronic / Prestige / Ceramic Tint / Stasis ECU Tune / H&R OE Springs / Fast Intentions full exhaust FOR SALE / 5mm Spacers / Stramosphere Intake / Interior LEDs
    Veteran Member Three Rings 2010S4's Avatar
    Jun 09 2010
    2010 Audi TTS, 2011 Audi Q7 S-Line Prestige
    Virginia Beach
    His were free. But they normally run for around $3100
    DD: 2010 S4 Prestige, Brilliant Black, DSG, ADS, Black Alcantara, Side assist, Carbon inserts
    Mods: APR 93 tune, APR pulley, Strat Intake, StopTech ST-60 BBK, H&R OE Sport springs, H&R rear sway, VAG-COM, tint, LED plate lights, under door LED, lamin-x on tails, Black-optics grill, R8 GT Alcantara steering wheel, Milltek Non-Res exhaust w/ black tips, JL 10" W7, black 19" factory wheels, BFI 10 & 5mm spacers, rear valance in matte black, RS6 shift knob, oCarbon MMI dash surround
    Established Member Two Rings Leo's Avatar
    Oct 03 2009
    2010 S4, 2005 997 Cabriolet, 2008 A6 Avant, 2011 Yamaha Apex SE
    Montreal
    Quote Originally Posted by krunko View Post
    You are correct sir, and that would be a savings of 20lb of unsprung weight per corner which is very significant.
    OP:
    Any chance you ran a before and after with a G-Tech? ie. 0-60 and 60-0? Would be kind of interesting to see what that equates to in the real world.
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    Get some HRE Carbon Fiber rims for uber lightness
    I guess these are one of those products if you have to ask for its price, you can't afford it....
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Mar 05 2010
    Gonna be tough to cut the same off the rears... probably not quite as much IMO...
    Jan 03 2011
    I guess these are one of those types of products if you have to ask for its price, you can't afford it....
    Old cars:
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    We have the StopTech's on special now, the price is too low to advertise but just add it to your cart and you can see the pricing :)
    http://shop.achtuning.com/StopTech-8...udi-B8-S5.aspx
    We're down to only 4 kits remaining at this pricing, once they are sold this pricing will not be available again.
    Mar 05 2010
    Quote Originally Posted by Skyler@Achtuning View Post
    all colors and rotors available or is it a select set? I guess I need to check this template.... or can I assume these will fit given they work on 18's?
    Jun 09 2010
    Virginia Beach
    Can the zinc rotors be added with this deal if the extra cost is added?
    Jan 03 2011
    Skyler, my existing "Evo Shop" installs a lot of Stoptech brakes on Evo's and other Mitusubishi's. Think they can do the BBK easily since they're familiar with Stoptech's? Is their anything quirky with the install or some tools which are german specific to do the brake swap? Most likely, they won't have any tools which are specific to Audi's and/or german cars since they mostly work on Mitsubishi's.
    Old cars:
    Sep 29 2009
    Rears are not as large and wont' weigh as much, but the front rotors were 23.5 lbs stock and 320mm, the Stoptechs are 18.1 lbs and 355mm, have more mass and better cooling. You drop over 5 lbs a corner of rotational AND unsprung mass right there. You could swap out the rear rotors with stock sized Stoptechs (slotted too) and likely kill another 3 lbs a corner there, as they are smaller rotors.
    They have red only in stock, but if you don't mind paying full price (their closeout deal is crazy as hell cheap) you can get them in black for sure and I think gray - http://forums.quattroworld.com/s4b8/msgs/20966.phtml
    I bedded mine in on the way home, by the time I had them up to temp I was rolling slowly in neutral on a gentle slope and a guy yells "Hey dude your brakes are smoking!" I waved and said "Thanks I know!" and he seemed confused. I didn't come to a stop with the brakes applied so it was all good, drove around at 40mph for about 5-8 min with no brake use and got them back down to temp, they smell good now and have not squealed once.
    Sep 29 2009
    Quote Originally Posted by skiracerblah View Post
    Easily, this is made for our cars specifically, it's a 1:1 part swap mounting to existing points on the car. The hardest part is getting the stock rotors to turn loose. Had to give them some umph and lightly scuffed them as a result, so they will need a light turning proir to use again.
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Wow, they clear 18's? That's great because I would definitely like to run 18's in the winter.
    Sep 29 2009
    Quote Originally Posted by Leor604 View Post
    Yes, they clear 18's no problem from the circumference standpoint, it's the spokes where it's damn close. I'll upload my pics now that show the wheels all dirty
    *** Edit - here you go ***
    Clearance shot with spokes, you can see the closest point where the fingerprint in the brake dust on the spoke is moving to the center of the wheel from the "P" on the caliper.
    Veteran Member Three Rings K1speeder's Avatar
    Aug 29 2010
    San Francisco
    I thought the StopTech Kit was just front brakes. How is it 10 lbs a corner then? Or is this kit all 4?
    2017 Q5 3.0T P+, Brilliant Black
    Past: 2015 S3 P+ • 2010 S4 Prestige, Meteor Gray • 2009 Q5 P+, 3.2, NAV, Brilliant Black
    I have HEX-USB+CAN Vag-Com cable if a local member needs some mods
    Mar 05 2009
    Earth
    Not all 18's are created equal....it's best to download/cutout the template to verify.
    Sep 29 2009
    Quote Originally Posted by K1speeder View Post
    Fronts only, don't assume that because I said 10 per corner, that I was meaning all 4 corners were done, just 2 corners were
    Quote Originally Posted by cory_can View Post
    Very true and excellent point. This is why I specified they will be ok with stock 18's. Stoptech lists that a minimum of an 18 is required, but not that all will fit.
    May 24 2010
    Los Angeles, CA
    Awesome price. Just curious...what's the rational behind product sales where they require adding the item to their cart to see the price. The fact that it's already in my cart doesn't mean I'm going to make a $2k+ purchase you know...well it's already in my cart might as well....
    Veteran Member Four Rings apexit1's Avatar
    Jun 04 2010
    northern nj
    There is most likely an agreement between stoptech and their vendors not to advertise a price below MSRP or something.
    May 24 2010
    Los Angeles, CA
    Quote Originally Posted by apexit1 View Post
    If this is true, this would clear up a long time question about online vendors...
    Feb 14 2007
    Redmond WA
    Quote Originally Posted by primetime View Post
    This is just a few select kits that we were able to get a great deal on and pass along the savings, we're unable to change the configuration. We recommend using the template if the wheels you have have not already been verified to clear.
    Quote Originally Posted by 2010S4 View Post
    Unfortunately as these have already been built it's not really something that can be changed easily. A set of replacement zinc coated rotors can be purchased for $590-pr and you could swap them out and sell the non-zinc coated rotor rings. The 355x32mm rings are a universal fit on all StopTech BBK's using a 355x32 rotor so it shouldn't be too hard to sell them.
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    is it possible to upgrade to the larger 385mm rotors in the future. new carrier etc?
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Veteran Member Three Rings vwong's Avatar
    Apr 03 2006
    '10 S4, '09 335i, '98 Prelude
    Quote Originally Posted by richib86 View Post
    I would think that it'll be an entire kit. I used to work for a brake company, while the calipers for a 355mm kit may look the same as those for a 385mm kit, the piston sizes are different to maintain the brake balance.
    2010 Audi S4 6MT
    2009 BMW 335i Coupe 6MT
    YouTube Channel
    Apr 03 2006
    Very nice, NWS4Guy. So what are you doing to the rear calipers? Because now you have red calipers in the front, but black calipers in the rear. You're gonna have the rear calipers powdercoated to match the fronts?
    2010 Audi S4 6MT
    YouTube Channel
    Feb 14 2007
    Redmond WA
    Rotor rings hats and brackets would be necessary, pricing for those components would be $1,350. The bias would be shifted slightly forward as well.
    Sep 29 2009
    Quote Originally Posted by vwong View Post
    Wasn't going to worry too much about it, I wasn't sure I would like the red but I do, I'll see how I feel later and coat them if I can't with with it
    Mar 05 2009
    Earth
    Skyler, my understanding is that there are specific ST-60's for the A4 that are somehow different than the S4 versions. Are the templates the same?
    Feb 14 2007
    Redmond WA
    The templates are the same though the piston sizing in the kits are different and specific to A4 or S4.
    Sep 29 2009
    Ok all clean!
    May 25 2010
    Vancouver
    Show off!
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    Ok all clean!
    dress those tires!!! I'm getting black st-60s in June. :)
    Looks great!
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Sep 29 2009
    dressing tomorrow, we have a Seattle/Vancouver GTG, pics later!
    Registered User Three Rings Watercooledind's Avatar
    Apr 02 2011
    holland/MI
    I can get you guys StopTech or Brembo brake kits if you need them. Also I work with HRE, DPE and Rotiform quiet a bit. Just PM me for pricing
    Jun 09 2010
    Virginia Beach
    I just ordered this BBK a few mins ago, so I am hoping i'll like it. I have done lots of reading on all of the kits and this one seems to be just as good as any of the others. Has anyone had any problems with it on the B8 S4?
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    In my research I haven't found any reviews for the ST BBK on the S4. The reviews I've found have been the A4,A5 & S5. Every review gives the ST kits good reviews and I'm looking forward to upgrading to the ST-40 on my A4.
    Tschüß!
    Šave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hüper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/ÜSS • Hankook V12's • ST-40 BBK
