Originally Posted by
Cards232323
^^Well if your were smelling you clutch you were probably feather ing it for too long, the ONLY reason I would say feather is because all launch control is really doing is regulating rmps and building exhaust gas without you actually having to play with the throttle. So theoretically dumping the clutch at 4k with your right foot holding it there or with LC holding it there would still be dumping the clutch and creating a bit a shock on the tranny.
But I dont want to get too off topic, I havent gotten my chip yet ( only have the car a month) but Im kind of interested in how the LC works on these cars anyway.
That's where JHM's LA (Launch Assist, not LC) is different from every other LC system out there that I've seen. It's more then just holding RPM's and letting you dump it. With their system it's key that you very quickly come off of the clutch. The best driver's are still gonna be able to cut better 60' times, b/c just that, their the best drivers. Vs a LA that's designed to be applicable in a wide range of conditions and power (think about all the different surface conditions, tire conditions, temperatures, power ranges, clutch health/strength etc. We're not talking about the new LC in a 458 that is able to compute those factors to slightly adjust every time for a better launch), but the goal of JHM's system is to be able to create repeatable good launches. Their goal was also to create a LA that would be "safe" on a stock clutch and allow repeated use. My feelings are it's probably easier on the clutch then most people trying to launch on their own (esp when "learning" to launch) as you know what RPM it's engaging at every time and you don't have people get caught up in the moment and feather the clutch and not let it engage till near 4k (as often people will do). And with their design, even if the LA is installed, it still will allow you to launch the car the old fashioned way, so someone like cabracco could play around with it when he wanted, but still go throw out nasty 60' times at the track when he wanted to show what the car and a BA driver can really do!
Again, they're still working to decide if this will even come to the market, and they want to test it on a lot more before they open it up and then have people complained their clutch is trashed b/c they did a bunch a launches (doh. . . ). They
let me have it installed b/c I had already ordered the Stg IV clutch and didn't care what happened to my oem clutch so I was a great candidate to see how it would do and what the aftermath would be (and they would get to see it first hand as well as my history as a customer with them). As of right now I do not have it on my car due to the complexity of the system and them not wanting to add it into my tune with everything else going on (for now only I hope). And there really isn't much point of me having it with a new clutch anyhow, but now that I'm mostly broken in, I'm starting to work on learning to launch the good ole old fashioned way again.
