Originally Posted by
budfox
This is exactly what I need. I need to order one ASAP! Do you think you could add a few more to make a DIY? That would be freaking baller!
I can write up a little DIY for everyone. To be honest, like I said 9/10 peoples harness are probably cracked but didn't think people would jump on it and order right away. It is a good fix and I have 0 on my misfire counts all the way through my RPM band now.
Most the time when in boost and you get misfires it could be the coilpack itself or the plug. If not then this would be the next place to look.
Give me until tomorrow I will take some more pics and do a DIY. It is very easy. Really there are 4 wires you need to pay attention to. Number 1, 2, 3 and 4 trigger wires need to be installed in the harness in the correct place. After that you just have your constant 12v wire for each plug and ground for each plug. The harness has a built in ground for the valve cover so no need to worry about that.
So number one trigger goes into the number one plug on the new connector (supplied with the kit). Then number 2 goes in the number 2 and so on to number 4. After that it is just constant 12v and ground for each plug. number 5-8 are the ground wires and 9-12 are 12v wires. (on the new connector). There are instructions that come with the kit.
I will post a DIY.
