Results 1 to 39 of 39
    Account Terminated Four Rings
    Feb 29 2008
    B6/B7 S4 Timing Chain FAQ / Information / Discussion Thread
    The purpose of this thread is to create one central location for information, questions, answers, and discussion concerning the timing chain system used in the Audi B6/B7 S4.
    General Information
    Does my B6/B7 S4 have a Timing Chain or Timing Belt?
    The quick answer is Timing Chain. The B6/B7 S4 4.2 liter power plant is a chain driven system. Other variations of the 4.2 liter V8 are belt driven which can be found in models such as the C5 A6 4.2.
    Location of the Chain Driven System
    Unlike the belt driven system which is located in the forward section of the motor, the chain system used in the B6/B7 S4 is positioned at the REAR of the motor facing the firewall.
    It's not your chain, its the Tensioners / Guides
    When you hear of chain failure in the S4 motor it is in fact the cam adjusters, chain tensioners, and chain guides that wear out / break. There have been no issues to our knowledge of an actual chain snapping. Some cases include:
    • Bad Adjusters
    • Broken Tensioner
    • Worn / Broken Guides
    Cold Start and the Infamous Rattle
    During a cold start-up you might have heard a weird rattle coming from the engine at one point or another. Here is what the Audi TSB states for this issue:
    The Camshaft Adjustment is hydraulically adjusted and controlled by the engine oil pressure. If the engine has been turned off for a long time, the oil pressure drops down and the oil partially flows back into the oil sump. To ensure an efficient camshaft adjustment right after an engine cold start, the oil pressure inside the camshaft adjusters must be built up as fast as possible. During this time, a rattle or knocking noise may be noticeable.
    This noise is normal at engine start and will last until the oil pressure is fully built up, which takes about 1-2 seconds. There is no applicable production solution.
    If you are hearing this noise it is considered "normal" by Audi. Whether us consumers feel it is normal for a 50k sports car, well that is up to you to determine. This does not necessarily mean that you will need your timing system serviced soon. However, it does hint that your tensioners might be worn.
    How to combat the Start-up Rattle / Prolong Life of Timing Components?
    Here are a couple tips to ease the start-up rattle / duration and to get the most out of your vital engine components
    • Frequent Oil Changes: A lot of members change their oil between 3,000-5,000 miles. Try and adopt a similar schedule , anything much over this range is considered too long.
      NOTE: Frequent Oil changes will not PREVENT failure of the timing components, but help reduce wear on the guides
    • High Quality Oil: The oil is the life blood of your motor. It is recommend to use quality oil during oil changes. Our motors use 0w40 or 5w40. A couple popular brands include: Mobile 1 / Lubro Moly / Motul
    • Proper Care: If you want the maximum life out of your motor you have to take the necessary steps to take care of it. Allow proper warm up, don't beat on the car when it is cold and expect it to last forever. Keep up with scheduled maintenance and address issues as they arise.
    Does this failure happen to all of the B6/B7 S4's?
    The short and sweet answer is NO. Out of the thousands of S4's sold between the various platforms, only a small percentage of these cars have seen catastrophic failure resulting in service. However, although only a small number, it is something to consider and think about when purchasing this vehicle.
    I have heard failure occurs at 100k miles, is this true?
    There is no set mileage where failure is imminent. It is a case by case basis on these documented situations. We have seen some engines fail in as little as 40-50k miles and others well over 100k miles. There are a bunch of cars over 140k miles who have had no issues at all. However, several polls have yielded though that the mean average of failures from timing chain components occurs near or around the 100k mark.
    Again, if you are considering a car with 100k miles this does not mean the engine is about to blow, but it is something to consider and keep in mind.
    Symptoms / Codes: What needs to be replaced?
    Cam Over-Advance Codes
    If you are getting this fault code you will only need to replace the cam adjusters. This can be done WITHOUT removing the motor. It will be tight, but the cam adjusters can be replaced by removing the rear timing covers when the motor is still in the car.
    Start-up Rattle
    As stated before, Start-up rattle does not necessarily mean your timing components needs attention. Techniques such as frequent oil changes and quality oil can help this situation. However, if they progressively get worse the chances are they will attention in the near future.
    Possible Causes-> Worn Tensioner, Failing Adjuster
    Mis-Fires / Lack of Performance
    If you start to experience lack of performance and Mis-Fires then the condition is progressively getting worse and will require attention soon.
    Possible Causes-> Failing Tensioner, Failing Adjuster
    Car is in limp mode
    If your condition gets to the point where the car goes into limp mode than you have a serious problem that needs immediate attention. Stop driving the car and have it towed home or to a local dealer / indy shop. Further driving could result in more damage to your motor
    Possible Causes-> Broken Tensioner, Broken Adjuster, Broken Tensioner Guide
    Is you are having any of these symptoms please use this thread to ask any questions or make any comments. We will collectively try and help as much as we can with your issues. It is best to try and narrow down your problem before making decisions or assumptions.
    Supplemental Pictures
    Cracked / Broken Guides
    Bad Cam Adjusters. Take notice to the second picture. The hole should be a perfect circle like the adjuster on the left. Notice the oval shape / wear created on the bad adjusters.
    Timing Chain Service
    Is a motor pull required to service the Chain System?
    If you need to do a full chain service the motor will need to be pulled from the car. Since the chain assembly is located at the rear of the motor is makes it impossible to access while in the car.
    There have been individuals who have only had to replace the Cam Adjusters in their motor. This type of service can be done with the engine still in the car.
    I. DIY Approach
    These guides will help you service your timing chain system if you wish to go the route of doing it yourself. Keep in mind this is not something that you can knock out in a day. Plan accordingly and assume it will take you longer than a full weekend to complete. With a few hands to help and all weekend allocated, I feel this is something that can be done in two days start to finish.
    ENGINE PULL DIY
    TIMING CHAIN DIY (Will be available once i am able to get my hands on one)
    Cost of Parts
    Depending on your situation and your mechanical ability, the timing chain service price can fluctuate. At the bare minimum you are looking at the cost of the new parts if you plan on doing everything yourself. Here is a list of the parts required for a COMPLETE overhaul. Please note that you may not need to do everything listed here, such as the Cam Adjusters.
    079109087N — Cam Adjuster [2]- $975
    N91086201 — Cam Adjuster Bolt [2]- $14
    079109210H — Control Housing [Bank 1]- $650
    079109204L — Control Housing [Bank 2]- $650
    079109092B — Control Housing Gasket [Bank 1]- $3
    079109091B — Control Housing Gasket [Bank 2]- $3
    079109218D — Chain Tensioner [Bank 1]- $100
    079109217J — Chain Tensioner [Bank 2]- $100
    079109510E — Tensioner Chain Guide [Bank 1]- $35
    079109514B — Chain Guide [Bank 1] $30
    079109513C — Chain Guide [Bank 2]- $35
    079109469AD — Center Upper Chain Guide- $32
    079109469AA — Left Lower Chain Guide- $32
    079109510F — Left Lower Chain Guide- $30
    079109507G — Lower Chain Tensioner/Guide assy- $58
    079109467AE — Lower Chain Tensioner- $44
    06E905163 — Cam Position Sensor [Bank 1& 2]- $13 x 2 = $26
    079109293C — Hydraulic Controller Seal [2]- $6
    079131120A — Coolant/SAP Gasket- $8
    079109139A — Center Lower Gasket- $5
    079131120B — Kombi Valve Gasket [Pipe 2 timing cover]- $3
    078131120K — Kombi Valve Gasket [Valve 2 valve]- $3
    079105193 — Diamond Disc Washer [2]- $130
    035906149A — Fuel Injector Seal Set [8]- $10
    077129717Q — Intake Manifold Gaskets [2]- $70
    077198025B — Valve Cover Gasket Kit [Bank 1: 1-4]- $55
    077198025C — Valve Cover Gasket Kit [Bank 2: 5-8]- $55
    079115111A — Oil Filter Housing Seal [Double O-Ring]- $4
    N90959701 — Oil Filter Housing Seal [single O-Ring]- $3
    ********* — Rear Water Manifold O-Rings [2]- $2
    Chains- Optional
    079109229 — Timing Chain Center Upper- $98
    079109229D — Timing Chain Center Lower- $88
    079109229K — Timing Chain Upper Left- $98
    079109229L — Timing Chain Upper Right- $98
    REQUIRED SPECIAL TOOLS
    To complete the timing chain service you will need a few special tools:
    • Crank holder / Pin
    • 2 x Trim Wedge
    • 1 x Multi-point Socket
    • 1 x Pair of Camshaft Locators
    • 1 x Setting Gauge.
    Parts can be purchased HERE for $350 or rented HERE for $150
    Based on the list prices above the Total Cost of a complete overhaul for PARTS ONLY (No Tools) will be:
    A. Slightly above $3,000 with the Cam Adjusters
    B. Right around $2,000 without the Cam Adjusters
    Therefore, if you plan to do all of the work yourself you can have it done for the cost of parts you replace.
    II. Shop / Dealer Approach
    What should i expect to pay to have a shop do the labor?
    The cost of having this job done is going to vary from place to place. Each shop has a different labor rate which will effect the amount you will pay to have it done. We have seen quotes for this service for as little as $5,000 and some quotes over $10,000. Again, it all depends on the shops labor rate and the parts being replaced.
    One recommendation we have is to have this job done by an experienced Indy or Audi dealership who have done this type of work before. It is a very tedious and involved service that should be completed by experienced technicians. This job is far to costly and time consuming to have it done incorrectly or faulty.
    This service seems really expensive, Can't I just buy a used motor for less?
    In some cases it may very well be cheaper to buy a used motor to replace the current engine that needs a timing service done. However, be aware that there is no guarantee that the used motor will or will not need a timing chain service of its own in the future. A lot of people will pay the extra cost of the service for peace of mind knowing that their timing components are freshly updated. In the end it is up to you on which route you want to take.
    Used motors with lower miles can be had in the range of $2500-$5000. The price will reflect the miles, condition, warranty (if applicable), and the components coming with the motor (bare or complete long block).
    Buying a used motor instead?
    • Make sure the motor has a leak-down and compression test
    • Try and find a motor with low miles
    • Warranties are always a plus for used motors
    My motor is out for the Timing Chain Service, what else should / can i do?
    With the motor out of the car there is an opportunity to take care of maintenance, modifications, and other failing parts that are far easier with the motor out. Here are some items to consider with the motor out:
    Maintenance:
    • Clutch and Flywheel
    • Motor Mounts
    • Engine Components (Starter / Compressor / Alternator / PS Pump)
    • Serpentine Belt
    • Valve Cover Gaskets
    • Spark Plugs
    Modifications:
    • JHM Headers / Aftermarket Downpipes
    • JHM Intake Manifold / Spacers
    • JHM Oil Cooler
    • JHM Crank Pulley
    • Snub Mount
    • JHM Shifter Trio
    RESOURCES AND GUIDES
    ENGINE PULL DIY
    Replacing the Bank 2 Cam Adjuster VIDEO
    Please note that a bunch of this information is a collective effort from the community. Thanks to all for the helpful information to make this thread possible. If you would like something added please post up what you would like incorporated. If you feel something needs to be changed, feel free to comment.
    Registered Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    Terminator Cobra
    Chicago NW Burbs
    Awesome Joey. hopefully Anthony will unblock the EA link so people can figure out how to pull their motors
    Active Member Two Rings Hazziar's Avatar
    Oct 03 2010
    04 S4 Black
    Northeast
    Great effort putting this together man, very solid info
    If you want, you can embed my video on documenting the bank2 timing service with engine in chassis for reference on the alternative to removing the engine for timing work on the heads.
    http://www.youtube.com/watch?v=AiTiJ5mnvQ4
    Aug 31 2010
    Aprilia
    San Mateo, CA
    Rated 5 stars
    2004 S4
    Horsepower to the people
    Jul 11 2010
    Wilmington, DE
    Very helpful, thanks!
    2004 S4, 6MT, Magnaflow non-res cat-back, piggie pipes, AVIC X920BT, 20" Asanti ELT 150, DDM 3000k HID Fogs, DDM 6000k Low Beams, JHM Tune.
    Feb 29 2008
    Quote Originally Posted by Hazziar View Post
    Awesome! Thanks for letting me throw this in there.
    Active Member Two Rings kelseysautobody's Avatar
    Mar 03 2009
    07 S4, 99 A4, 99 Camry
    Cape Cod, MA
    Great write up! Informative and to the point. It's too bad there isn't more of this on the site.
    Senior Member Four Rings BCsniper's Avatar
    Jan 29 2010
    north ga
    Really good of you to put this all together.
    It seems everyone not in the B6/7 crowd is out of the loop on this one and don't know quite the specifics.....all they know is that "this one time I read somewhere that S4 chains go bad at 100k miles"
    Mar 30 2010
    buffalo
    Incase anyone is curious i called axis motorsports and they do not have any of the parts in question...
    Senior Member Three Rings UnstableOS's Avatar
    Jul 23 2009
    2012 STi
    Wisconsin
    This is the only place you need to go for any part. The prices are fair and the customer service is great. Obviously better deals may be available on parts, but if you need something and need it to be right, GAP is a good place to go.
    http://www.genuinevwaudiparts.com
    GAMK/JK/ISK/RB
    Zen and the Art of Audi Maintenance
    Feb 29 2008
    Quote Originally Posted by buffalony View Post
    Hmm... Thanks for checking up on that. I took another members word for that as i shuffled through the threads.
    Feb 29 2008
    Does anyone know the part numbers for the required tools for the timing chain service? Would be a great addition to this thread.
    Senior Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    2005 B6 S4 DG, BMW 335i
    a canyon road in SoCal
    Quote Originally Posted by joeycuccaro View Post
    I would point out that frequent oil changes will only help prevent wear to the guides, not the failure of the guides, tensioners or cam adjusters, those are a factory hardware issue not a poor maintenance issue.
    Power: JHM Supercharger Stage I, Intake Manifold Spacers, Carbonio-JHM hybrid Intake, 034 MAF Hose, FI Downpipes & Cat Back, Carbon Fiber Vented Hood
    Power supporting: APR Snub, 034 Engine & Trans Mounts, Apikol Rear Diff Mount, JHM Oil,Power Steering & Trans coolers
    Handling: PSS9 Coilovers, Hotchkis sway bars
    Brakes: B7 RS4 Front & Rear Brakes, StopTech SS lines
    Daily Driver: BMW E92 335i Coupe, JB4 stage 3 piggyback, quaife LSD, 440hp on 100oct
    Feb 29 2008
    ^ Made it more clear. Thanks
    May 09 2012
    New England
    Many thanks to Joey for this very helpful data. A few items on this parts list needs to be updated, however:
    P/N 079109210H has been superceded by 079109210L.
    P/N 079109510F has been superceded by 079109510M
    The Cam Position Sensors for bank 1 & 2 are not the same P/N, they should be:
    06E905163 Camshaft sensor 4.2 LITER Left
    06C905163B Camshaft sensor 4.2 LITER Right
    The Coolant/SAP Gasket for the driver’s (left) side timing chain cover is listed (079131120A), but the similar gasket for the passenger’s (right) side is missing from the list. That part number is 079131120. (for reference, see here)
    The part number for the Rear Water Manifold O-Rings, which is missing in the listing, is N90989503
    In the following, all pricing is from GAP.
    So, the updated parts list is:
    1. 079109087N — Cam Adjuster [2]- $1109.30
    2. N91086201 — Cam Adjuster Bolt [2]- $10.92
    3. 079109210L — Control Housing [Bank 1]- $757.64
    4. 079109204L — Control Housing [Bank 2]- $757.64
    5. 079109092B — Control Housing Gasket [Bank 1]- $7.44
    6. 079109091B — Control Housing Gasket [Bank 2]- $7.44
    7. 079109218D — Chain Tensioner [Bank 1]- $127.22
    8. 079109217J — Chain Tensioner [Bank 2]- $127.22
    9. 079109510E — Tensioner Chain Guide [Bank 1]- $52.27
    10. 079109514B — Chain Guide [Bank 1] $24.92
    11. 079109513C — Chain Guide [Bank 2]- $24.92
    12. 079109469AD — Center Upper Chain Guide- $37.08
    13. 079109469AA — Left Lower Chain Guide- $37.08
    14. 079109510M — Left Lower Chain Guide- $59.15
    15. 079109507G — Lower Chain Tensioner/Guide assy- $59.15
    16. 079109467AE — Lower Chain Tensioner- $50.96
    17. 06E905163 — Cam Position Sensor [Left]- $21.02
    18. 06C905163B — Cam Position Sensor [Right]- $32.18
    19. 079109293C — Hydraulic Controller Seal [2]- $17.60
    20. 079131120A — Coolant/SAP Gasket- $12.70
    21. 079131120 - Coolant/SAP Gasket- $12.70
    22. 079109139A — Center Lower Gasket- $9.90
    23. 079131120B — Kombi Valve Gasket [Pipe 2 timing cover]- $7.87
    24. 078131120K — Kombi Valve Gasket [Valve 2 valve]- $3.72
    25. 079105193 — Diamond Disc Washer [2]- $116.06
    26. 035906149A — Fuel Injector Seal Set [8]- $23.28
    27. 077129717Q — Intake Manifold Gaskets [2]- $36.08
    28. 077198025B — Valve Cover Gasket Kit [Bank 1: 1-4]- $46.13
    29. 077198025C — Valve Cover Gasket Kit [Bank 2: 5-8]- $46.13
    30. 079115111A — Oil Filter Housing Seal [Double O-Ring]- $5.46
    31. N90959701 — Oil Filter Housing Seal [single O-Ring]- $1.24
    32. N90989503 — Rear Water Manifold O-Rings [2]- $3.84
    TOTAL: $3646.26
    In the following illustration, the blue numbers correspond to the numbers in the list above. View Full Size
    Also, make sure you pick up a good supply of your favorite Gasket Silicone Sealant, because you will need it when you replace the various covers. The Audi sealant is P/N D176501A1, $15.07.
    Although it was not in this list, it may be prudent to replace the rear seal, P/N 079103051F, $28.09
    If you have not replaced your Fuel Injector Pintle Caps, you will probably need to since they often break on removal. There are 8 per engine and are available at JHM.
    Note that the Cam Position Sensors, Valve Cover Gasket Kits, Fuel Injector O-Rings, (and perhaps other components) can be purchased from other audizine advertisers at a cost savings. Additionally, JHM has complete timing kits available, see this post.
    Sunset Audi is able to source the Special Tools:
    The complete list of special tools is:
    1. T40237 – Crank Holder - $11.75
    2. 3409 – Trim Wedge (2) - $9.20
    3. T40046 – Camshaft Lock - $155.00
    4. T40047 – Setting Gauge - $99.00
    5. T10035 – Multipoint Socket - $25.00
    6. T40049 – Key Wrench - $54.90
    TOTAL – $354.85
    Total without the Multipoint Socket and Key Wrench (see below): $275.85
    The Multipoint Socket is simply a 14mm Triple Square. A 10mm Triple Square is used for the CV joints, so my advice would be to purchase a triple square set instead of the special tool. This set worked well for me.
    The crankshaft Key Wrench is not necessary if the serpentine belt is installed: the crankshaft can easily be turned by turning the alternator pulley with a 24mm socket.
    I have these tools.
    Now, the following is personal opinion and others will certainly have differing opinions, which is fine. To each his own:
    I believe that replacing this entire list of parts is overkill. I have not read any account of the chains breaking or stretching. I’ve only read of the Electric Cam Adjuster Actuators failure as a result of physical damage resulting from mechanical adjuster. The chains and electric adjusters (along with Diamond disc washers when you replace the electric adjusters) are pricey items, and I would leave them out of a repair job if cost was a concern.
    On the other hand is mechanical cam adjusters and Left Lower Chain Guide (P/N 079109469AA) which often fail. There is also a picture above of the Bank 2 Tensioner (P/N 079109217J) having failed. I would always include these items in a repair job, along with all the new gaskets.
    Now whether the rest of the guides and tensioners need to be replaced is a judgment call. I haven’t seen pictures of the rest of them having failed, so I’m a little dubious about whether they need to be replaced. If there are pictures that I’ve missed of failed guides/tensioners, by all means, post them here for reference.
    And, if you repair budget can handle it and you want the peace of mind, by all means replace everything.
    Of course, I am just a guy on the internet, so you should consult with your Professional Mechanic before taking any of my advice.
    Active Member Two Rings buck15's Avatar
    Aug 01 2011
    Twin Cities
    Joey - Thanks for putting this together!
    Questions:
    Should anybody be concerned if they get the rattle restarting warm car, if you turn off completely warm car and restart it 20 minutes later and get rattle?
    Is there any signs in the timing advance numbers that would provide early detection of timing issue?
    Is there any numbers for amount of miles people have had timing rattle before having failure?
    Senior Member Two Rings Monops87's Avatar
    Feb 16 2009
    Is Using the special tools difficult? Is it hard to adjust the timing to the correct position?
    2004 s4 6mt
    VMR v710, auto speed cat back, Jhm short shifter
    May 09 2012
    New England
    Please not that I added an illustration above that cross references the parts.
    Quote Originally Posted by buck15 View Post
    The chain rattle results from the pressure bleeding off that is supposed to pressurize the tensioners. Each time the chain rattles, it puts some stress on the timing system, so the answer really depends on how you use your car. Let's assume that you start your car twice a day to go to work and back. It's really the same whether you get a rattle after 20 minutes or after 4 hours. It still puts stress on the timing system twice a day. However, if you start your car 10 times a day and your pressure bleeds off in 20 minutes, you'll get chain rattle 10 times. If instead your pressure bled off in 4 hours, starting the car 10 times a day would only results in chain rattle on the first start.
    I think I've read that the VAG-COM can give you the angle that your timing is advanced by.
    Quote Originally Posted by Monops87 View Post
    The Bentley manual gives step by step instructions in adjusting the timing. If you can get the engine out of the car, you won't have any problem using the special tools.
    Active Member Two Rings mlittleton's Avatar
    Nov 21 2011
    2006 S4, 2002 E39
    Atlanta
    Best thread I've seen on this yet. Very thorough and informative. Thanks Joey!!
    2006 Audi S4 / Black on Black / 18" S5 Reps / Akebono Euro Ceramic - R1Concepts drilled/slotted rotors
    Aug 01 2011
    Twin Cities
    "I think I've read that the VAG-COM can give you the angle that your timing is advanced by."
    What numbers would be out of range with timing advance? I have seen -5 to 43
    Feb 16 2009
    If using the vagcom how can I for sure tell that i have a cam adjuster problem. I read something I think it said 091 092 093 and log those. I'm not sure.. The codes I'm getting are p0300 p0301 p0303 an p1340 .. I'm not getting a timing over advance code nor am I getting a whole bank of cyl misfires. Confused
    2004 s4 6mt
    Nov 13 2011
    Tampa Fl
    part number for the exhaust cam sprocket bolt(number 62 in the diagram)? Bently says that has to be free spinning and needs to be replaced if removed. Also where can I find a complete parts diagram for the B6 s4, I read somewhere that you can get an ETKA login for free but can't find it?
    May 09 2012
    New England
    Quote Originally Posted by tampas4 View Post
    The P/N is N90981001, which is part number 62 (numbered in black) in the illustration above. I've had reasonable success looking at the parts diagram available from JimEllisAudiParts.com.
    Sep 13 2008
    Terminator Cobra
    Chicago NW Burbs
    You can get a pirated version of ETKA on eBay. Mine works great
    New Member One Ring
    Oct 25 2012
    New York
    What is the part # for the mechanical cam adjusters?
    Senior Member Three Rings Tropicgreena4's Avatar
    Oct 07 2004
    98.5 Audi A4 2.8 30v qms
    Harrisburg, PA area
    would it be of any value to put a link to the "Solution to chain rattle" thread in this thread?
    -Wes
    May 09 2012
    New England
    Quote Originally Posted by Mrbell845 View Post
    079109087N
    Quote Originally Posted by Tropicgreena4 View Post
    The solution to chain rattle
    New Member One Ring
    Oct 25 2012
    New York
    I need help please. I have 2005 a6 4.2. Left side out of timing. I had shop replace all guides, tensioners and chains. 2 guides were broken. The right side is timed perfectly. But the left side cam isn't moving. They think it's either the cam adjuster, the control housing or the camshaft itselfl. What are your suggestions . Thanks
    May 09 2012
    New England
    You mean the camshaft will not rotate? I assume they have the crank holder installed correctly?
    Remove the cam adjuster and see if the camshaft will rotate. If not, remove the control housing and see if it will rotate. IMHO you should definitely be replacing both camshaft adjusters while you have your engine out.
    Jan 29 2010
    north ga
    Quote Originally Posted by B6JoeS4 View Post
    That's it Joe. I am calling the POlice
    New Member One Ring
    Oct 25 2012
    New York
    Correct. The camshaft will not rotate. They said they believe there is a mechanism inside the control housing that is supposed to lock but isn't. I'll have them do what you've recommended. Before I purchase the control housing.and I also will definitely change both adjusted like you said. Thanks much
    New Member One Ring
    Oct 25 2012
    New York
    Are the cam adjusters for the 2005 s4 the same as the 2005 a6 4.2?
    Senior Member Three Rings EUROSWAGR's Avatar
    Oct 11 2008
    2013 Ford F-150 FX4 (twins) / 2012 Audi Q5 S-line
    Jacksonville, NC
    ETKA shows two part numbers for the adjusters that I assume are suitable substitutes or updated versions
    This is for 4.2l V8 engine code BAS
    079 109 087 E replaced by 079 109 087 J, which genuineaudiparts says the replacement for the J part# is the below N part#
    and the adjuster (079 109 087 N) from above are listed.
    So long story short...YES
    2006 Audi S4 Brilliant Red 6-spd (neutered)
    Jul 31 2012
    Under low throttle I can hear the movement of the chain, not metal on metal but quite simply the sound of a moving chain.. My question is if everything is running efficiently, should I be able to hear this from the cabin? As I get past 3000 rpm the engine sound overpowers the sound of the chain.
    I have not had my S4 for very long, nor have I ever been in a brand new one. So I am unsure as what is normal.
    May 09 2012
    New England
    No, you should not hear chain. If the tensioners are working properly, there will be no slack in the chain. All the movements - pivoting of the links, links meeting sprockets, and chain moving over over the guides/tensioners - should make no chain sounds in the presence of oil.
    However, there are straight cut gears in there that are notoriously noisy, maybe that's what you're hearing?
    I wouldn't get too worked up about it... with a new (to you) engine, it's easy to fret over unrecognized sounds.
    Jul 31 2012
    Its super easy to fret about these engines lol. Thanks for the reply. The engine just rolled over 200,000 kms so I would presume there to be some tension wear. It could very well be the gears if you say they are noisy.
    Just trying to prevent future problems! Not a whole lot one can do, other than oil maintenance, right?
    Feb 13 2007
    2004 S4 1992 Mustang GT v
    PA
    I'm getting some chatter from my clutch at about 85K miles, so I'm thinking of doing the timing chain service with the clutch. Based on the recommendation in this thread, it seems the preferred approach is to skip the electric cam adjuster and chains. That being said, it sounds like JHM's Intermediate kit is the way to go.
    See here.
    Sound right? Any thoughts on the quality of JHM parts?
    Thanks
    Active Member Two Rings MaudiS4's Avatar
    Jan 03 2009
    1999.5 AUDI A4 2005.5 B7 S4
    Silver Spring , Maryland
    Registered Member Two Rings teamraw's Avatar
    May 08 2012
    2005 Audi S4, 98 jetta vr6
    Reno NV
    Question:
    On the Driver side bank, i can move the chain just a little bit and on the passenger-side Bank I can't move it at all ??? Anybody know if these is normal
