Results 1 to 28 of 28
    Veteran Member Three Rings eboosted's Avatar
    Jul 17 2009
    lima
    AWE FMIC install day
    I installed the FMIC today after several months keeping it off the desk, I really thought it was going to be much harder that that but it really was a piece of cake. The main issue was the 19mm hole you need to drill at the crashbar, easy if you have a drill with 19mm drill bit or otherwise you will have to take it to the machine shop as I did. The rest was a piece of cake, I took almost 2 hours to install it with no major issues.
    BTW I have ADS but no addaptive steering
    Stage II+ customer reflash is going in tomorrow, here are some crappy iPhone pics:
    Veteran Member Three Rings ddun's Avatar
    Jun 06 2009
    Stanton, CA
    its a breeze! fyi for anyone doing this mod in the future. you don't need a massive ass drill bit. use a small pilot drill bit to drill through as marked in the instructions, then on the front of the crash bar use the step drill to enlargen it enough for the head of the bolt to go through. then on the back side of crash bar, englargen it enough for the thread of the bolts to go through! mount up the brackets and then the FMIC then reassemble and enjoy the IAT's.
    if you're using some battery operated hand drill trying to drill through steel with a big ass bit like that will take forever.
    2014 S4 IE DP
    2009 A4 APR K04 100oct water/meth
    Dec 03 2010
    SF
    Is there any noticeable difference in terms of power after install?
    Veteran Member Three Rings quality_sound's Avatar
    Jan 29 2005
    Ramstein AB, Germany
    Quote Originally Posted by Kevins350z View Post
    +1
    More lag? Better IATs? Higher coolant temps?
    Senior Member Two Rings SupFly's Avatar
    May 07 2010
    2023 Tuono Factory
    Plano, TX
    nicely done taking the gig on yourself!
    2010 A4 S-Line Avant | Phantom Black | Huper Op Tint | V-1 Hardwired |AWE FMIC | KW V1's | H&R Rear Sway | K04 - Unitronic Software | APR HFC-Resonator ~ AWE Exhaust | Eurocode High Flow Intercooler Pipe | Carbonio CIA | VAG'ed
    Senior Member Two Rings fredjones's Avatar
    Apr 24 2009
    Mobile, Al
    I did this myself in my garage. You don't have to have all of the professional equipment like used above. AWE has excellent instructions available at their site. The only really key piece of equipment needed to do this is the step drill bit they recommend. That and cool head and a load of patience and a couple hours. I wouldn't say exactly that a caveman can do it though.
    2009 Audi A4 Prestige, Brilliant Black
    Mods: APR Stage 2, APR Downpipe, H & R Rear Sway Bar, License Plate LED.
    Jul 17 2009
    lima
    Well, the car feels much more powerful and it's much much fun to floor it now, the power uptop is pretty impressive, I would say the most benefit comes at the top end.
    I'll upload some before and after IATs charts tomorrow, as well as ignition timing logs
    Jan 06 2011
    NC
    AWE states on their website that the FMIC doesn't affect the radiator or the A/C system....
    I am concerned about that statement considering the FMIC essentially blocks the radiator. I admittedly have very minimal experience with FMICs, so it would be interesting to hear from people who have had this installed for a decent amount of time. I read through some older posts AWE FMIC related posts, and didn't find anything negative...
    Veteran Member Four Rings A5MD's Avatar
    May 21 2009
    2009 Acura MDX Tech, 2015 X5, 2014 Police Interceptor, 2018 Civic Sport Hatchback
    MD
    eboosted: What else do you have done on your car? I am contemplating between an FMIC or Exhaust in the next couple months. I know thw FMIC would give me more power but the exhaust would give me the look since I willl be doing the dual exhausts
    Jul 17 2009
    lima
    I found some post that stated surging on the awe fmic for being that large, nevertheless I went ahead and bought it and I'm quite happy wityh the results, this will allow me to raise the boost a little bit more, increase ignition timing and lean the AFR to get smoother extra power uptop.
    At the end, for me, being able to increase these parameters was the main purpose of a FMIC
    Jul 17 2009
    lima
    Quote Originally Posted by PG2373 View Post
    Well I'm not into looks much, so I focused myself on power mods, from my point of view I think it much more rewarding, I get a smile on my face everytime I press the gas pedal.
    I'd go with 3" catless DP, sound is grumpy and mean but only when you push it hard, otherwise is quite as stock
    Besides that I have a custom tune, cat defeated, speed limit off, inmediate throttle response and 4 programs to choose from, 93, 100oct, stock and economic, I use economic most of the time and 93 on the weekends. I have the eurocode IC pipe as well.
    May 21 2009
    MD
    Thanks. Of course we all want both (power and looks) but I still have to decide. I currently have APR Stage 2 and a Ecode HFC
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by eboosted View Post
    Could you explain how you can increase the boost and ignition timing with an FMIC? Is this done via VAGCOM?
    2010 A4 quattro, Tiptronic, Ibis White
    Jun 02 2009
    San Francisco
    Quote Originally Posted by Bairum View Post
    No issues here as far as IAT.
    Jun 02 2009
    San Francisco
    I agree with this assessment. The car continues to pull longer and more consistently versus stock.
    Jul 17 2009
    lima
    you mean as far as water temps
    Veteran Member Three Rings NickZag's Avatar
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    It's good to hear all the postive reviews on this. This is probably going to be one of the next mods on my car. I'm just concerned about it blocking the radiator. I know they claim that it doesn't effect the engine temp, but as much tracking as I do awith my A4 mixed with the heat in the California summer I think I might be an extreme case.
    Deactivated Four Rings
    Apr 09 2008
    Willow Grove, PA
    Quote Originally Posted by NickZag View Post
    Nick,
    That's a valid concern and we had the same concerns when we were testing this FMIC. Let me assure you that if it had any negative effect on the cooling system we would not have released it to the public.
    Take a look at this: http://www.youtube.com/watch?v=UsQ0_SUSC6M.
    The video is of our in-house B7 A4, with our FMIC and GT Turbo Kit, undergoing testing at Thurderbolt Road Course at New Jersey Motorsports Park. During numerous hard sessions at the track in the scorching heat, we never found evidence that the cars cooling system was effected by our FMIC. The car in the video is not a B8 however the testing still holds true for our B8 FMIC since the heart of the kit is similar.
    In addition to the track testing, we did a lot of street testing to ensure that our large face FMIC would have no negative effects.
    Does that help?
    If you have any additional questions, please let me know.
    Apr 09 2008
    Willow Grove, PA
    Quote Originally Posted by quality_sound View Post
    +1
    While our FMIC is much larger than stock, the turbo is able to pump air so quickly that lag is not an issue.
    The factory IC heat soaks very quickly. Our testing showed a 30% reduction in IATs (resulting in an additional +21 crank hp +20 crank tq on a car with aftermarket software and a catback exhaust). That is massive!
    Have you had a chance to check out the B8 FMIC section of our website? http://www.awe-tuning.com/products/a...we-b8fmic.html
    If not, check it out when time allows. It might answer some of your questions.
    Let me know if I can help in any way.
    Jul 17 2009
    lima
    Quote Originally Posted by dracolnyte View Post
    No VAG-COM is not a flasher, if you need to program the ECU yourself you will need an EBF this device will allow you to reflash and tune your car according to your mods.
    Jun 02 2009
    San Francisco
    Overall, no issues noticeable with heat.
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    Thanks for the info Alex. This mod is high on my to do list.
    Apr 09 2008
    Willow Grove, PA
    No problem Nick. Let me know when if you have any other questions down the road. I'm here to help.
    Veteran Member Three Rings rippin'av's Avatar
    Nov 18 2009
    '00 S4 Stage 3, '05 LR3, '08 ML63 AMG, '02 BMW 1150GS, '71 BMW R75/5
    CA
    IMO, thats all the more reason to get the FMIC...heat sucks power and 30% reduction is solid!
    2015 Jeep Unlimited Rubicon
    2000 S4 6MT ASP Stage 3
    Dec 03 2010
    SF
    i just got an email that i will be receiving my fmic from awe in a few days. =)
    Apr 09 2008
    Willow Grove, PA
    Be sure to post up pictures and impressions once you've had it installed Kevin.
    Dec 03 2010
    SF
    Quote Originally Posted by Alex/AWE View Post
    of course. i will do a full review on that.. =)
    Senior Member Three Rings brettj20's Avatar
    Nov 20 2010
    everett pa
    very nice
