I'm new to the forum, and looking for additional information. I am doing a Mid-engine GTM supercar
http://www.factoryfive.com/gtmhome.html (give you an idea of the engine/trans layout) and instead of doing the normal Porsche manual mated to an LSX engine, I plan on using an automatic trans. From a ton of research I have done, looks like the 5HP19FL is almost the perfect candidate. I realize this trans is factory rated at 300Nm of Tq used in everyting from 1.8-3.7 V8 engines, but all of the factory vehicles seem to weigh in around 3500-4000lbs, while GTM weighs 2500lbs with driver.
As far as gearing this is what I have, and interesting enough I have found 3 different Final drive ratios. trans code (green label on trans) EZS, DDT, EFP = 3.73 final. DPS, DRD = 3.41 final. And EZZ, CJZ = 3.09 final
1st 3.67 : 1
2nd 2.00 : 1
3rd 1.41 : 1
4th 1.00 : 1
5th 0.74 : 1
Reverse 4.10 : 1
It seems several shops (Trans specialties, IPT, 517) build this transaxle and I have heard 700hp is roughly the top number it can be built up too? I am shooting for around 480-500 to the rear wheels again vehicle weight in my advantage as well.
An adapter seems like it should be pretty easy, I can either build one myself or possible buy the existing Audi 5000-LSX adapter (It appears to share the same bellhousing from pics)
The Tq converter I can approach from a few directions and here I am a little concerned. The 5hp19fl Tq converters dimensions are 9 1/4 bolt circle, diamter 10 7/8, 3 mounting pads (which all is great), but its OAH (overall height from hub to mounting pad) is only 4.380, not a lot of room in there to really beef this thing up with clutches and all IMO? Another option is to use the 4.2 liter Quattro converter (IF POSSIBLE??) which has an OAH of 5.670which is pretty close to what the 4L60E is. Last option and most expensive (about twice as much) is to use a 4L60E converter with the Audi pump and hub (27 spline) welded to the GM converter. This way it will bolt on without any modifiing. Otherwise 3 new holes need to be drilled in flexplate and a adapter over the pilot to fit snug on the crankshaft (no big deal really, mainly worried about them being strong enough).
Controlling it I plan on using the PCS trans control, last time I checked they offer it for the 5hp19 series trans, so getting this to work with a GM engine wouldn't be a big deal. Anyone useing the PCS on here?
Shifter I plan on using probably just a Passat (same trans as the audi) factory shifter with a custom cable (longer) since the trans is cable shifted.
Ive reseached this topic and it seems that with a converter upgrade this trans can take a bit of a beating?
Opinions?? Advice??? info seem correct??
