As topic says, I have a Vag K-Can Commander 3.0 borrowed from a friend. I took it in the attempt to read out my SKC code from my cluster so I can add another key to my car ( I only have one ). My cluster model is BOSCH RB4 ( so not a VDO ). Commander was not able to get that code read out. However the mileage read on the commander was way off : showing something like 428 milion km. My in car cluster was showing the real mileage value : 248.000 km, so I decided to change the one in the Commander. After hitting SAVE, dash turned off-on for 1 sec and then instead of some km, I have ERROR in my dash. Trip mileage works fine, although it started from 0.0 after this little issue. Everything else seems to work perfect with the car. What do I do to get rid of that ERROR ??
Some guy in a forum, said he replaced the first line in the whole code with : 000000: 54 D2 9C BF A7 EC 0F 64 80 96 FB 48 0A 96 25 03. That solved the error problem for him, but that also put a 159.000 km on his dash. To be honest I wouldn't exactly mind to have that as long as I get my ERROR code outta there but right now I am quite afraid to do any more adjustments or code alterations as I am fully aware that I can have my immo not recognise my key or even worst things....
I would really appreciate some help in this matter.
Thanks so much.
