Results 1 to 20 of 20
    Feb 25 2009
    Mk2 Jetta, B5 S4, B5 A4
    New England
    Speedometer & Vehicle Speed Sensor problems
    I just bought an A4, and the speedometer and odometer don't work.
    The only code it has is Vehicle Speed Sensor - Implausible Signal
    I swapped out the VSS with a new one, still no speedometer, and the code is back.
    If I go into #17 on the diagnostic display (in the heater controls) it shows 0 for vehicle speed all the time.
    I checked the wiring at the plug for the VSS, and it looks fine. One pin tested good for ground and the other must be for signal.
    I'm thinking the only thing left is something inside the tranny... probably a magnet? It's a manual.
    Does anybody have any input on what to replace and how? I've searched but haven't found much info.
    Thanks in advance
    FIXED! Solution is HERE: http://www.audizine.com/forum/showth...ausible-Signal
    Feb 25 2009
    New England
    Bump.. need to make the winter beater roadworthy
    Feb 25 2009
    New England
    bump
    Nov 17 2009
    Golf mk3 winter beater
    Laval Quebec
    I have the exact same problem and I expect to be the thing inside the transmission. I replaced the sensor too and checked the wires and its all good. If someone can chime in for an answer it would be nice
    Senior Member Two Rings shaahid's Avatar
    Jan 06 2007
    Audi A4 1.8T
    Chicago
    I got the same exact problem. I replaced my sensor too. I should mention that this first started happening after I gave my car a jump. At first, the needle would be all over the place. A few days later it stopped working all together.
    2001 A4 1.8tQMS | RNS-e | Clear Cornered | 6000k HID Headlights and Fogs| Matte Black RS4 Grille | Independent Fog Light Mod | "Swiss Cheesed" Airbox | APR Snub Mount |
    Jan 06 2007
    Audi A4 1.8T
    Chicago
    anyone?
    Jan 06 2007
    Audi A4 1.8T
    Chicago
    bump
    Nov 17 2009
    Laval Quebec
    Alright im back with some answers , after checking at the underside of my car i noticed a little leak on my shifter linkage shaft seal. The oil level was pretty low so I ended ajusting the level and now it works pretty good now. Speedometer works 95 % of the time , if i start the car and floor it right away it usually stop working but if im easy with the car at the start up( aroung -15 celcius here) it works fine. Try to fill up the tranny and see what it does.
    If it doest wotk try to do an outpout test with vag-com for your cluster. You should see all the needles work they way together if your cluster is good
    Feb 25 2009
    New England
    interesting... i have a feeling this may be related to another problem I'm having which is that if i leave the car parked in gear when its cold, its really hard to take it out of gear and impossible to put it into any gear until it warms up... also shifting from 1st to 2nd feels a little clunky, but i figured that was the 2nd gear synchro
    i dont see how fluid level could effect the vehicle speed sensor... i wish it was that simple of a fix
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    I pretty sure it has to do with the gear the VSS reads off of. The colder the weather and the colder the trans says the better is works, magnets also perform better in the cold. I have the same issue in my b6 for about 2 years, all summer no speedo, all winter speedo around town until the trans warms up.
    Nov 17 2009
    Laval Quebec
    There you go here's a nice member that did pretty nce little diy.
    Im gonna order the part tomorrow and and try it this week .
    Feb 25 2009
    New England
    Quote Originally Posted by a4t-qtro View Post
    Haha that was me actually... thanks for reminding me about this thread though, its good to have the fix thread linked from here for people searching the archives
    Jun 01 2008
    Apopka, FL
    I would be one of those people acutally, Did your speedometer work at all? Mine will 'dance' about 3" around the acutal speed, ocassionaly displaying the correct speed. I did notice that one of the contact pins on the plug was slightly corroded, however Eletronic connector cleaner has not helped. The car has 155K on it..
    Feb 25 2009
    New England
    Quote Originally Posted by blmlozz View Post
    mine was completely dead, no signs of life. but my magnetic ring was completely destroyed. maybe yours is just cracked...
    in your case the first thing i would try is doing the output tests in vag-com for 17-Instruments and watch your speedometer needle. If it moves properly, then you may have the same issue as I did...
    Apr 14 2011
    Ohio
    My car makes a lot of noise, sounds like throw out bearing? 1st and 2nd gear are fine, sometimes hard to get into 2nd or chirps. Won't go into 3rd or 4th, and will pop out of 5th. reverse is fine, but likes to get stuck. Should I replace this, and put fluid in.. or is the transmission needing replaced? Currently I am prepared to replace the transmission, but if I could avoid that then that would be awesome. Mine is a 2000 A4 1.8T Quattro 5spd Manual with 170k. My speedo doesn't work, sometimes it'll jump to 40? and about all the lights are on on the cluster, like brake, abs, airbag, eds or something like that, and cel.
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Quote Originally Posted by angry12v View Post
    Just sent my friend Fred(last person to post on that thread) one of those rings/gasket for his car since he was having the same problem and he saw your post. LOL
    Those 2 parts aren't even that expensive.
    Dec 27 2011
    Buffalo/NY/NE
    How to remove LF axle stub from quattro Auto trans?
    I am working on a 98 A4 1.8t quattro auto with the ZF 5hp19. This car has a speedometer needle that sticks at certain speeds. I am attempting to replace the speedo pulse ring for the VSS.
    However it appears the Left front stub shaft is a long one that goes all the way through the trans case. It has no center bolt, won't pop out. It looks easy with the manual trans, but the auto stub shaft is different.
    Does the trans need to be fully disassembled to remove this stub? or is there a clip accessible with the trans pan removed?
    Thanks for any tips you might have.
    -Dan
    Established Member Two Rings 98 A4 Quattro's Avatar
    Oct 03 2012
    Midwest, USA
    I bought my audi with the speedo out, I'm 18 and not used to Audi's mechanically yet, where can i find the speedo sensor to change it. I havent been able to find it.
    Feb 08 2011
    Quote Originally Posted by 98 A4 Quattro View Post
    It is on the driver side of the transmission right near the front axle flange.
    Dec 30 2013
    Australia
    Does anyone know how many "pulses per mile" the VSS puts out? I'm trying to find out to program an aftermarket cruise control.
