Results 1 to 26 of 26
    Sep 30 2009
    b
    n/a
    n/a
    Senior Member Three Rings joeyo's Avatar
    Jan 19 2010
    2011 Toyota Highlander Limited
    Suffolk, NY
    Nice, I intend to use this thread as a go-to guide when I put my new grille in, whenever it gets here that is :-(
    2012 Jeep Grand Cherokee Limited
    Sold:
    2010 Audi A4 Premium Quattro Tiptronic: Ibis White/Black
    APR Stage 1, 19" Hyper Silver VMR V708, H&R OE Sport Springs, Halogen-->Bi-Xenon Conversion, Hoen Endurance Yellow Fogs, 20% Tint, Glossy Black 3.2 Grille w/ Plate Delete, A4L Fog Light Grilles, License Plate LEDs, Debadged, OEM Exhaust Tips, VAG-COM'd
    Sep 11 2010
    Orange County
    Good diy
    Veteran Member Three Rings euroazfck's Avatar
    Jul 18 2010
    98 audi a4_ 88 civc hatch "jdm"
    colorado
    y do the rings look like that??
    Mar 02 2007
    Fresno, CA
    Excellent DIY. Hope you don't mind me moving it to the "tech" subforum where DIY's are being placed for reference.
    Mar 02 2007
    Fresno, CA
    Thanks! Sorry, didn't realize this was supposed to go here
    Don't apologize, that's my job. It's why I get paid the big bucks to be a moderator!
    Jun 11 2010
    09' A4 Prestige S-Line Navi, 06' Gixxer 750, 00' GSR
    Westchester, NY
    How do you remove the plastic clip in the wheel well without breaking them?
    Debaged, 20% Tints, LED License Plate Lights, APR, KW V2, 3K HID Fog's, H&R RSB, Satin Black Front Grill, Eurocode HFIP
    Jun 11 2010
    Westchester, NY
    Lets thank the guys that have posted a DIY bumper removal instructions with pictures and step by step instructions for our B8's, including this one and the one I saw for a S4 B8. I love the part when the instructions say to remove the torx screws and clips in the fender well. By how? How do you remove the dam clips?!!!!!!!
    To add to this great write up, thanks again Okan509, I will attempt to explain how to remove those P.I.T.A. fender well clips.
    The clip I'm referring to slides on a pin (Picture 7 & 8 of Okan509 original post). The pin looks like the head of a nail. The clip has a small tab on one side only. The side with the tab, take a flathead screw driver and pull back the edge of the clip away from the fender liner, it will bend up. While holding the tab side up, slide the clip away from the tab.
    Hope this helps.
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    thanks okan
    5 stars - people will need this stuff, it's a huge help. probably be in a lot of bookmark folders
    Established Member Two Rings Ox2gen's Avatar
    Sep 13 2009
    LA
    Peel back liner and locate a vertical thread nut by the fender, and a horizontal screw further in
    Loosen the vertical thread nut and remove the horizontal screw
    I'm not sure if loosening the vertical thread nut is necessary. The audi techs didn't need to do this and in the "DIY bumper removal" in the S4 forum u can clearly see both vertical nuts still there with the bumper completely removed.
    ..:B8 A4 2.0T Quattro Brilliant Black:..
    KW V1 | AWE Catback Quads | VMR V713 | Eurocode USS System | Adam's Rotors [Track] | StopTech PosiQuiets | Rieger-Style Rear Lip Spoiler
    Hoen Fogs | Glossy Black Grill | "V-Code" Amber Delete | Blesk LED plate lights | F1 Tint 35%
    Nov 02 2010
    Vancouver, BC
    Question regarding the re-installation of the bumper. In the picture below, you can see the two square notches cut out of the bumper, where the top of the bumper meets the bottom of the fender. Are there some sort of posts, pins, clips, etc. that these notches lock onto?
    Reason I ask is because after I re-install the bumper, on the passenger side, the bumper can be fairly easily pulled out (looking exactly like the pic below). I'm thinking that the holes are there to lock onto a pin or something to prevent the bumper from being able to move outwards. I can pull the bumper out even though the two nuts (on the vertical bolts) that hold this part of the bumper in place are fully tightened up. This only happens on passenger side, the driver's side is fine.
    Oct 23 2010
    Montréal
    Is it the module for garage door opener ?
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    For reference this is how the fog grills are hooked into the grill, they are very easy to remove from bumper when off the car and decently easy to take off while on the car - Will pst Greg Nelsons DIY on the fog grills soon
    Hey did you ever get a chance to post the fog grill DIY?
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Awesome DIY guide, Okan
    I had to contend w/ the fender liner clips when I installed my Eurocode intercooler pipe, and all I can say is that they SUCK to get unclipped. From what I remember, you have to fold one side over until you can see the nub that it's attached to in the fender (you may have to rotate the clip a bit to see the attachment point). Once you do that, you slide the clip off away from you. The process is a pain to do and a pain to describe IMHO. I can't think of any other way to describe it so sorry if this post is an epic fail haha
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    May 26 2009
    Houston, TX
    ^Ya I was away focusing on other stuff and then the holidays came. The AZ community has too many cool ppl for me to stay away too long I guess Ya lemme know if you need any help w/ the HFIC install. I can tell you right now, be on the lookout for a small ratchet set and/or a high-quality one that ticks over w/ the slightest movement, cuz one of the bolts on the OEM pipe assembly is a PITA!
    Senior Member Three Rings keeva381's Avatar
    Mar 24 2011
    Charlotte, NC
    I purchased the a new glossy black grille. Do I need to buy the "quattro" emblem (it didn't come with it)? Or is there a way to take it off my old grille? Is it difficult to remove and transfer? Thanks!
    Active Member Two Rings zgr024's Avatar
    May 14 2012
    South Jersey
    That little quattro emblem is held on by two small clips that are accessible from right under the emblem itself. I used my fingers and was able to do it without dropping either clip. Takes literally 30 seconds to take off. The harder part is putting it back on but if you have the grille and bumper off car, I'm sure it will take less time than that.
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    What happened to the photos? Does anyone have them or perhaps another DIY removal process?
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Senior Member Three Rings dame drizzo's Avatar
    Sep 15 2009
    1995 Audi URS6
    Finally when I decide to use this, all the pictures are gone :(
    Current- 2013 Volcano Red Metallic B8 2.0 -Frankenturbo F23L, RAI Custom HUGE FMIC, RAI MS Full Turbo Back Exhaust, Hotchkis F&R Sway Bars
    Past - 2010 Audi A4 2.0 EFR 6258 Stage 3 (Total Loss/ Hurricane Sandy)
    2009 Audi A4 2.0 Stage 2 (Total Loss)
    VCDS RossTech NYC Area
    FIRST AUDI B8 WITH EFR - 330whp @ 22psi 93oct
    instagram.com/damedrizzo
    Xclusive Auto Leasing - Sales & Marketing Manager
    [email protected]
    Senior Member Two Rings AUDuffer's Avatar
    May 20 2012
    Hawaii
    Noooooooooooo!
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    ha. same here.
    Senior Member Two Rings simplicity's Avatar
    Aug 24 2011
    SF Bay Area
    can someone please repost the pics?
    2011 Brilliant Black A4 Sedan Quattro | 8 speed tiptronic | P+ | Sports Package
    APR Stage 1, EuroCode Alu Kreuz, Hotchkis F&R Sway Bar, Blesk license plate LED, Hoen Endurance fogs, Reiger Style Trunk Spoiler, RS4 Replica Grill, Podi Boost Gauge
    Established Member Two Rings mxz's Avatar
    Aug 22 2010
    Woodbridge, Ontario
    Quote Originally Posted by phillyquattro View Post
    http://www.a5oc.com/forums/audi-a5-s...rill-swap.html
    S5 but this is what I used (and Okan's guide) when I took off my front end, it is pretty much the same. Good luck.
    Dec 28 2017
    C7 Z, BMW 550i M sport, Hayabusa, 2 Harleys, multiple bikes
    PA
    Why did the OP delete? I was looking to get some info on bumper R&R.
    '9 second C7Z, BMW 550i M Sport, Suzuki Hayabusa, 2 Harleys, & a HUMVEE. If it has wheels, I like it!
    Aug 17 2015
    California
    Quote Originally Posted by Datalogger1 View Post
    Check the ECS intercooler page, they have a pretty good guide for removing the bumper. You could also check Eurocode high flow intercooler pipe, or intercooler. I forget which one, but also a good guide!
    Dec 28 2017
    PA
    Quote Originally Posted by A4x View Post
    Thank you!
