OK, got a issue.
little background: i was leaking coolant, ended up being the coolant feed line to the turbo was leaking at the fitting so i replaced the hose it but the car was run with low coolant for about 10 minutes going very easy trying to limp it home in the rain.
got to work fine yesterday, yesterday after work i went out to my car and the battery was dead, got a jump and made it home. started up just fine this morning, but when i went to leave the office same thing happend, the battery was dead, get another jump and go on my way. so i get home, the cars been off for about 30 minutes and i hear the radiator fans kick on. so i scanned it and i found this code:
17698 - coolant temp sensor at radiator outlet (G83): signal too small
P1290 - 002 - lower limit exceeded - intermittent.
I know this was the reason the fan was running which resulted in a dead battery and was most likely from running the engine with low coolant.
on to the question... what sensor is it bitching about? i am guessing it's the one at the bottom of the radiator (next to where the side mount IC normally sits) that is held in by a C clip, is this correct?
if that is the case, will the green top sensor i have that goes into the coolant flange on the back of the engine work there? i only ask because i have a new one floating around somewhere. if not what is the part number of the sensor i need?
Thanks much in advance!
